RTEMS 6.1-rc5
nvdisk.c File Reference
Non-Volatile Disk Block Device Implementation. More...
#include <rtems/libio.h>
#include <inttypes.h>
#include <rtems/blkdev.h>
#include <rtems/nvdisk.h>
#include <rtems/thread.h>
struct  rtems_nvdisk_device_ctl
struct  rtems_nvdisk
#define RTEMS_NVDISK_TRACE   0
#define rtems_nvdisk_calc_crc16(_b, _c)    rtems_nvdisk_crc16_factor[((_b) ^ ((_c) & 0xff)) & 0xff] ^ (((_c) >> 8) & 0xff)
typedef struct rtems_nvdisk_device_ctl rtems_nvdisk_device_ctl
rtems_device_driver rtems_nvdisk_initialize (rtems_device_major_number major RTEMS_UNUSED, rtems_device_minor_number minor RTEMS_UNUSED, void *arg RTEMS_UNUSED)
◆ rtems_nvdisk_calc_crc16
#define rtems_nvdisk_calc_crc16 (   _b,
  _c
Calculate the CRC16 checksum.
Parameters
_bThe byte to checksum.
_cThe current checksum.
◆ RTEMS_NVDISK_TRACE
Note
The use of pages can vary. The rtems_nvdisk_*_page set routines use an absolute page number relative to the segment while all other page numbera are relative to the number of page descriptor pages a segment has. You need to add the number of page descriptor pages (pages_desc) to the page number when call the rtems_nvdisk_*_page functions.
You must always show the page number as relative in any trace or error message as device-page and if you have to the page number as absolute use device~page. This can be seen in the page copy routine.
The code is like this to avoid needing the pass the pages_desc value around. It is only used in selected places and so the extra parameter was avoided. Control tracing. It can be compiled out of the code for small footprint targets. Leave in by default.
Typedef Documentation
◆ rtems_nvdisk_device_ctl
NV Device Control holds the segment controls
◆ rtems_nvdisk_initialize()
rtems_device_driver rtems_nvdisk_initialize ( rtems_device_major_number major  RTEMS_UNUSED,
NV disk device driver initialization.
Todo:
Memory clean up on error is really badly handled.
Parameters
majorNV disk major device number.
minorMinor device number, not applicable.
argInitialization argument, not applicable.
