RTEMS 6.1-rc5
system_conf.h File Reference
System configuration. More...
#define UART_BAUD_RATE   (115200)
#define MM_FREQUENCY   (0xe0001074)
#define FMLBRG_FLUSH_BASE   (0xc8000000)
#define FMLBRG_LINE_LENGTH   (32)
#define FMLBRG_LINE_COUNT   (512)
#define MM_UART_RXTX   (0xe0000000)
#define MM_UART_DIV   (0xe0000004)
#define MM_UART_STAT   (0xe0000008)
#define MM_UART_CTRL   (0xe000000c)
#define UART_STAT_THRE   (0x1)
#define UART_STAT_RX_EVT   (0x2)
#define UART_STAT_TX_EVT   (0x4)
#define UART_CTRL_RX_INT   (0x1)
#define UART_CTRL_TX_INT   (0x2)
#define UART_CTRL_THRU   (0x4)
#define MM_TIMER1_COMPARE   (0xe0001024)
#define MM_TIMER1_COUNTER   (0xe0001028)
#define MM_TIMER1_CONTROL   (0xe0001020)
#define MM_TIMER0_COMPARE   (0xe0001014)
#define MM_TIMER0_COUNTER   (0xe0001018)
#define MM_TIMER0_CONTROL   (0xe0001010)
#define TIMER_ENABLE   (0x01)
#define TIMER_AUTORESTART   (0x02)
#define MM_GPIO_IN   (0xe0001000)
#define MM_GPIO_OUT   (0xe0001004)
#define MM_GPIO_INTEN   (0xe0001008)
#define GPIO_BTN1   (0x00000001)
#define GPIO_BTN2   (0x00000002)
#define GPIO_BTN3   (0x00000004)
#define GPIO_PCBREV0   (0x00000008)
#define GPIO_PCBREV1   (0x00000010)
#define GPIO_PCBREV2   (0x00000020)
#define GPIO_PCBREV3   (0x00000040)
#define GPIO_LED1   (0x00000001)
#define GPIO_LED2   (0x00000002)
#define MM_SYSTEM_ID   (0xe000107c)
#define MM_ICAP   (0xe0001040)
#define ICAP_READY   (0x01)
#define ICAP_CE   (0x10000)
#define ICAP_WRITE   (0x20000)
#define MM_VGA_RESET   (0xe0003000)
#define MM_VGA_HRES   (0xe0003004)
#define MM_VGA_HSYNC_START   (0xe0003008)
#define MM_VGA_HSYNC_END   (0xe000300C)
#define MM_VGA_HSCAN   (0xe0003010)
#define MM_VGA_VRES   (0xe0003014)
#define MM_VGA_VSYNC_START   (0xe0003018)
#define MM_VGA_VSYNC_END   (0xe000301C)
#define MM_VGA_VSCAN   (0xe0003020)
#define MM_VGA_BASEADDRESS   (0xe0003024)
#define MM_VGA_BASEADDRESS_ACT   (0xe0003028)
#define MM_VGA_BURST_COUNT   (0xe000302C)
#define MM_VGA_DDC   (0xe0003030)
#define MM_VGA_CLKSEL   (0xe0003034)
#define VGA_RESET   (0x01)
#define VGA_DDC_SDAIN   (0x1)
#define VGA_DDC_SDAOUT   (0x2)
#define VGA_DDC_SDAOE   (0x4)
#define VGA_DDC_SDC   (0x8)
#define MM_MINIMAC_SETUP   (0xe0008000)
#define MM_MINIMAC_MDIO   (0xe0008004)
#define MM_MINIMAC_STATE0   (0xe0008008)
#define MM_MINIMAC_COUNT0   (0xe000800C)
#define MM_MINIMAC_STATE1   (0xe0008010)
#define MM_MINIMAC_COUNT1   (0xe0008014)
#define MM_MINIMAC_TXCOUNT   (0xe0008018)
#define MINIMAC_RX0_BASE   (0xb0000000)
#define MINIMAC_RX1_BASE   (0xb0000800)
#define MINIMAC_TX_BASE   (0xb0001000)
#define MINIMAC_SETUP_PHYRST   (0x1)
#define MINIMAC_STATE_EMPTY   (0x0)
#define MINIMAC_STATE_LOADED   (0x1)
#define MINIMAC_STATE_PENDING   (0x2)
#define MM_AC97_CRCTL   (0xe0005000)
#define AC97_CRCTL_RQEN   (0x01)
#define AC97_CRCTL_WRITE   (0x02)
#define MM_AC97_CRADDR   (0xe0005004)
#define MM_AC97_CRDATAOUT   (0xe0005008)
#define MM_AC97_CRDATAIN   (0xe000500C)
#define MM_AC97_DCTL   (0xe0005010)
#define MM_AC97_DADDRESS   (0xe0005014)
#define MM_AC97_DREMAINING   (0xe0005018)
#define MM_AC97_UCTL   (0xe0005020)
#define MM_AC97_UADDRESS   (0xe0005024)
#define MM_AC97_UREMAINING   (0xe0005028)
#define AC97_SCTL_EN   (0x01)
#define AC97_MAX_DMASIZE   (0x3fffc)
#define MM_SOFTUSB_CONTROL   (0xe000f000)
#define SOFTUSB_CONTROL_RESET   (0x1)
#define MM_SOFTUSB_PMEM_BASE   (0xa0000000)
#define MM_SOFTUSB_DMEM_BASE   (0xa0020000)
#define SOFTUSB_PMEM_SIZE   (1 << 13)
#define SOFTUSB_DMEM_SIZE   (1 << 13)
#define MM_PFPU_CTL   (0xe0006000)
#define PFPU_CTL_START   (0x01)
#define PFPU_CTL_BUSY   (0x01)
#define MM_PFPU_MESHBASE   (0xe0006004)
#define MM_PFPU_HMESHLAST   (0xe0006008)
#define MM_PFPU_VMESHLAST   (0xe000600C)
#define MM_PFPU_CODEPAGE   (0xe0006010)
#define MM_PFPU_DREGBASE   (0xe0006400)
#define MM_PFPU_CODEBASE   (0xe0006800)
#define PFPU_PAGESIZE   (512)
#define PFPU_SPREG_COUNT   (2)
#define PFPU_REG_X   (0)
#define PFPU_REG_Y   (1)
#define MM_TMU_CTL   (0xe0007000)
#define TMU_CTL_START   (0x01)
#define TMU_CTL_BUSY   (0x01)
#define TMU_CTL_CHROMAKEY   (0x02)
#define MM_TMU_HMESHLAST   (0xe0007004)
#define MM_TMU_VMESHLAST   (0xe0007008)
#define MM_TMU_BRIGHTNESS   (0xe000700C)
#define MM_TMU_CHROMAKEY   (0xe0007010)
#define MM_TMU_VERTICESADR   (0xe0007014)
#define MM_TMU_TEXFBUF   (0xe0007018)
#define MM_TMU_TEXHRES   (0xe000701C)
#define MM_TMU_TEXVRES   (0xe0007020)
#define MM_TMU_TEXHMASK   (0xe0007024)
#define MM_TMU_TEXVMASK   (0xe0007028)
#define MM_TMU_DSTFBUF   (0xe000702C)
#define MM_TMU_DSTHRES   (0xe0007030)
#define MM_TMU_DSTVRES   (0xe0007034)
#define MM_TMU_DSTHOFFSET   (0xe0007038)
#define MM_TMU_DSTVOFFSET   (0xe000703C)
#define MM_TMU_DSTSQUAREW   (0xe0007040)
#define MM_TMU_DSTSQUAREH   (0xe0007044)
#define MM_TMU_ALPHA   (0xe0007048)
#define MM_MEMCARD_CLK2XDIV   (0xe0004000)
#define MM_MEMCARD_ENABLE   (0xe0004004)
#define MEMCARD_ENABLE_CMD_TX   (0x1)
#define MEMCARD_ENABLE_CMD_RX   (0x2)
#define MEMCARD_ENABLE_DAT_TX   (0x4)
#define MEMCARD_ENABLE_DAT_RX   (0x8)
#define MM_MEMCARD_PENDING   (0xe0004008)
#define MEMCARD_PENDING_CMD_TX   (0x1)
#define MEMCARD_PENDING_CMD_RX   (0x2)
#define MEMCARD_PENDING_DAT_TX   (0x4)
#define MEMCARD_PENDING_DAT_RX   (0x8)
#define MM_MEMCARD_START   (0xe000400c)
#define MEMCARD_START_CMD_RX   (0x1)
#define MEMCARD_START_DAT_RX   (0x2)
#define MM_MEMCARD_CMD   (0xe0004010)
#define MM_MEMCARD_DAT   (0xe0004014)
#define MM_DMX_TX(x)   (0xe000c000+4*(x))
#define MM_DMX_THRU   (0xe000c800)
#define MM_DMX_RX(x)   (0xe000d000+4*(x))
#define MM_MIDI_RXTX   (0xe000b000)
#define MM_MIDI_DIV   (0xe000b004)
#define MM_MIDI_STAT   (0xe000b008)
#define MM_MIDI_CTRL   (0xe000b00c)
#define MIDI_STAT_THRE   (0x1)
#define MIDI_STAT_RX_EVT   (0x2)
#define MIDI_STAT_TX_EVT   (0x4)
#define MIDI_CTRL_RX_INT   (0x1)
#define MIDI_CTRL_TX_INT   (0x2)
#define MIDI_CTRL_THRU   (0x4)
#define MM_IR_RX   (0xe000e000)
#define MM_BT656_I2C   (0xe000a000)
#define MM_BT656_FILTERSTATUS   (0xe000a004)
#define MM_BT656_BASE   (0xe000a008)
#define MM_BT656_MAXBURSTS   (0xe000a00c)
#define MM_BT656_DONEBURSTS   (0xe000a010)
#define BT656_I2C_SDAIN   (0x1)
#define BT656_I2C_SDAOUT   (0x2)
#define BT656_I2C_SDAOE   (0x4)
#define BT656_I2C_SDC   (0x8)
#define BT656_FILTER_FIELD1   (0x1)
#define BT656_FILTER_FIELD2   (0x2)
#define BT656_FILTER_INFRAME   (0x4)
#define MM_IRQ_UART   (0)
#define MM_IRQ_GPIO   (1)
#define MM_IRQ_TIMER0   (2)
#define MM_IRQ_TIMER1   (3)
#define MM_IRQ_AC97CRREQUEST   (4)
#define MM_IRQ_AC97CRREPLY   (5)
#define MM_IRQ_AC97DMAR   (6)
#define MM_IRQ_AC97DMAW   (7)
#define MM_IRQ_PFPU   (8)
#define MM_IRQ_TMU   (9)
#define MM_IRQ_ETHRX   (10)
#define MM_IRQ_ETHTX   (11)
#define MM_IRQ_VIDEOIN   (12)
#define MM_IRQ_MIDI   (13)
#define MM_IRQ_IR   (14)
#define MM_IRQ_USB   (15)
#define FLASH_BASE   (0x80000000)
#define FLASH_OFFSET_STANDBY_BITSTREAM   (0x80000000)
#define FLASH_OFFSET_RESCUE_BITSTREAM   (0x800A0000)
#define FLASH_OFFSET_RESCUE_BIOS   (0x80220000)
#define FLASH_OFFSET_MAC_ADDRESS   (0x802200E0)
#define FLASH_OFFSET_RESCUE_SPLASH   (0x80240000)
#define FLASH_OFFSET_RESCUE_APP   (0x802E0000)
#define FLASH_OFFSET_REGULAR_BITSTREAM   (0x806E0000)
#define FLASH_OFFSET_REGULAR_BIOS   (0x80860000)
#define FLASH_OFFSET_REGULAR_SPLASH   (0x80880000)
#define FLASH_OFFSET_REGULAR_APP   (0x80920000)
#define MM_READ(reg)   (*((volatile unsigned int *)(reg)))
#define MM_WRITE(reg, val)   *((volatile unsigned int *)(reg)) = val
#define FLASH_SECTOR_SIZE   (128*1024)
#define FLASH_PARTITION_COUNT   (5)
#define FLASH_PARTITIONS
◆ FLASH_PARTITIONS
Value:
{ .start_address = 0x806E0000, .length = 0x0180000 }, \
{ .start_address = 0x80860000, .length = 0x0020000 }, \
{ .start_address = 0x80880000, .length = 0x00A0000 }, \
{ .start_address = 0x80920000, .length = 0x0400000 }, \
{ .start_address = 0x80D20000, .length = 0x12E0000 }, \
