RTEMS 6.1-rc5
Input/output module definitions. More...
struct | lpc176x_module_entry |
Defines the module entry. More... | |
#define | LPC176X_PLL0CON 0XAAU |
#define | LPC176X_PLL0CFG 0X55U |
#define | LPC176X_CCLK_PRESCALER_DIVISOR 1000000U |
#define | LPC176X_PINSEL ( &PINSEL0 ) |
#define | LPC176X_PINMODE ( &PINMODE0 ) |
#define | LPC176X_PIN_SELECT(index) ( ( index ) >> 4U ) |
#define | LPC176X_PIN_SELECT_SHIFT(index) ( ( ( index ) & 0xFU ) << 1U ) |
#define | LPC176X_PIN_SELECT_MASK 0x3U |
#define | LPC176X_PIN_SELECT_MASK_SIZE 2U |
#define | LPC176X_PIN_UART_0_TXD 2U |
#define | LPC176X_PIN_UART_0_RXD 3U |
#define | LPC176X_PIN_UART_1_TXD 15U |
#define | LPC176X_PIN_UART_1_RXD 16U |
#define | LPC176X_PIN_UART_2_TXD 10U |
#define | LPC176X_PIN_UART_2_RXD 11U |
#define | LPC176X_PIN_UART_3_TXD 0U |
#define | LPC176X_PIN_UART_3_RXD 1U |
#define | LPC176X_MODULE_BITS_COUNT 32U |
#define | LPC176X_MODULE_COUNT ( LPC176X_MODULE_USB + 1U ) |
#define | LPC176X_IO_PORT_COUNT 5U |
#define | LPC176X_IO_INDEX_MAX |
#define | LPC176X_IO_INDEX_BY_PORT(port, bit) ( ( ( port ) << 5U ) + ( bit ) ) |
#define | LPC176X_IO_PORT(index) ( ( index ) >> 5U ) |
#define | LPC176X_IO_PORT_BIT(index) ( ( index ) & 0x1FU ) |
#define | LPC176X_MODULE_ENTRY(mod, pwr, clk, idx) |
Enumerations | |
enum | lpc176x_pin_function { LPC176X_PIN_FUNCTION_00 , LPC176X_PIN_FUNCTION_01 , LPC176X_PIN_FUNCTION_10 , LPC176X_PIN_FUNCTION_11 , LPC176X_PIN_FUNCTION_COUNT } |
Defines the functions according to the pin. More... | |
enum | lpc176x_pin_mode { LPC176X_PIN_MODE_PULLUP , LPC176X_PIN_MODE_REPEATER , LPC176X_PIN_MODE_NONE , LPC176X_PIN_MODE_PULLDOWN , LPC176X_PIN_MODE_COUNT } |
Defines the pin modes. More... | |
enum | lpc176x_pin_type { LPC176X_PIN_TYPE_DEFAULT , LPC176X_PIN_TYPE_ADC , LPC176X_PIN_TYPE_DAC , LPC176X_PIN_TYPE_OPEN_DRAIN } |
Defines all type of pins. More... | |
enum | lpc176x_scb_value_pclksel { LPC176X_SCB_PCLKSEL0 , LPC176X_SCB_PCLKSEL1 , LPC176X_SCB_PCLKSEL_COUNT } |
Represents each pclksel number. More... | |
#define LPC176X_IO_INDEX_MAX |
#define LPC176X_MODULE_ENTRY | ( | mod, | |
pwr, | |||
clk, | |||
idx | |||
enum lpc176x_pin_function |
Enumerated type to define the set of pin function for a io device.
enum lpc176x_pin_mode |
enum lpc176x_pin_type |
Enumerated type to define the set of pin type for a io device.
Enumerated type to define the set of values for a pcklsel.
