RTEMS 6.1-rc5
This module provides functions to manage partitions of a disk device. More...
Files | |
file | bdpart.h |
Block Device Partition Management. | |
file | bdpart-create.c |
Manage Partitions of a Disk Device. | |
file | bdpart-dump.c |
Prints the Partition Table Partitions with Count Partitions. | |
file | bdpart-read.c |
file | bdpart-register.c |
file | bdpart-sort.c |
file | bdpart-write.c |
file | show_bdbuf.c |
Enable the Monitor to Show bdbuf Information. | |
struct | rtems_bdpart_partition |
union | rtems_bdpart_format |
#define | RTEMS_BDPART_PARTITION_NUMBER_HINT 16 |
Typedefs | |
typedef struct rtems_bdpart_partition | rtems_bdpart_partition |
Enumerations | |
enum | rtems_bdpart_format_type { RTEMS_BDPART_FORMAT_MBR , RTEMS_BDPART_FORMAT_GPT } |
rtems_status_code | rtems_bdpart_read (const char *disk_name, rtems_bdpart_format *format, rtems_bdpart_partition *partitions, size_t *count) |
Reads the partition information from the physical disk device with name disk_name. | |
void | rtems_bdpart_sort (rtems_bdpart_partition *partitions, size_t count) |
Sorts the partition table partitions with count partitions to have ascending begin blocks. | |
rtems_status_code | rtems_bdpart_write (const char *disk_name, const rtems_bdpart_format *format, const rtems_bdpart_partition *partitions, size_t count) |
Writes the partition table to the physical disk device with name disk_name. | |
rtems_status_code | rtems_bdpart_create (const char *disk_name, const rtems_bdpart_format *format, rtems_bdpart_partition *partitions, const unsigned *distribution, size_t count) |
Creates a partition table in partitions with count partitions for the physical disk device with name disk_name. | |
rtems_status_code | rtems_bdpart_register (const char *disk_name, const rtems_bdpart_partition *partitions, size_t count) |
Registers the partitions as logical disks for the physical disk device with name disk_name. | |
rtems_status_code | rtems_bdpart_register_from_disk (const char *disk_name) |
rtems_status_code | rtems_bdpart_unregister (const char *disk_name, const rtems_bdpart_partition *partitions, size_t count) |
Deletes the logical disks associated with the partitions of the disk device with name disk_name. | |
void | rtems_bdpart_dump (const rtems_bdpart_partition *partitions, size_t count) |
Prints the partition table partitions with count partitions to standard output. | |
void | rtems_bdpart_to_partition_type (uint8_t mbr_type, uuid_t type) |
Returns the partition type for the MBR partition type value mbr_type in type. | |
bool | rtems_bdpart_to_mbr_partition_type (const uuid_t type, uint8_t *mbr_type) |
Converts the partition type in type to the MBR partition type. | |
A disk is a set of blocks which are identified by a consecutive set of non-negative integers starting at zero. There are also logical disks which contain a subset of consecutive disk blocks. The logical disks are used to represent the partitions of a disk. The disk devices are accessed via the block device buffer module.
The partition format on the physical disk will be converted to an internal representation. It is possible to convert the internal representation into a specific output format and write it to the physical disk. One of the constrains for the internal representation was to support the GPT format easily.
Currently two physical partition formats are supported. These are the MBR and the GPT format. Please note that the GPT support is not implemented. With MBR format we mean the partition format of the wide spread IBM PC-compatible systems. The GPT format is defined in the Extensible Firmware Interface (EFI).
The most common task will be to read the partition information of a disk and register logical disks for each partition. This can be done with the rtems_bdpart_register_from_disk() function. Afterwards you can mount the file systems within the partitions.
You can read the partition information from a disk with rtems_bdpart_read() and write it to the disk with rtems_bdpart_write().
To create a partition table from scratch for a disk use rtems_bdpart_create().
You can access some disk functions with the shell command fdisk
References used to create this module:
#define RTEMS_BDPART_PARTITION_NUMBER_HINT 16 |
Recommended maximum partition table size.
typedef struct rtems_bdpart_partition rtems_bdpart_partition |
Partition description.
rtems_status_code rtems_bdpart_create | ( | const char * | disk_name, |
const rtems_bdpart_format * | format, | ||
rtems_bdpart_partition * | partitions, | ||
const unsigned * | distribution, | ||
size_t | count | ||
The array of positive integer weights in distribution must have exactly count elements. The weights in the distribution array are summed up. Each weight is then divided by the sum to obtain the disk fraction which forms the corresponding partition. The partition boundaries are generated with respect to the output format in format.
rtems_status_code rtems_bdpart_read | ( | const char * | disk_name, |
size_t * | count | ||
The partition information will be stored in the partition table partitions with a maximum of count partitions. The number of actual partitions will be stored in count. If there are more partitions than space for storage an error status will be returned. The partition table format recognized on the disk will be stored in format.
rtems_status_code rtems_bdpart_register | ( | const char * | disk_name, |
const rtems_bdpart_partition * | partitions, | ||
size_t | count | ||
For each partition of the partition table partitions with count partitions a logical disk is registered. The partition number equals the partition table index plus one. The name of the logical disk device is the concatenation of the physical disk device name and the partition number.
rtems_status_code rtems_bdpart_register_from_disk | ( | const char * | disk_name | ) |
brief Reads the partition table from the disk device with name disk_name and registers the partitions as logical disks.
bool rtems_bdpart_to_mbr_partition_type | ( | const uuid_t | type, |
uint8_t * | mbr_type | ||
The result will be stored in mbr_type. Returns true
in case of a successful convertion and otherwise false
. Both arguments must not be NULL
rtems_status_code rtems_bdpart_unregister | ( | const char * | disk_name, |
size_t | count | ||
The partition table partitions with count partitions will be used to determine which disks need to be deleted. It may be obtained from rtems_bdpart_read().
rtems_status_code rtems_bdpart_write | ( | const char * | disk_name, |
size_t | count | ||
The partition table partitions with count partitions will be written to the disk. The output format for the partition table on the disk is specified by format. There are some consistency checks applied to the partition table. The partition table must be sorted such that the begin blocks are in ascending order. This can be done with the rtems_bdpart_sort() function. The partitions must not overlap. The partitions must have a positive size. The partitions must be within the disk. Depending on the output format there are additional constrains.
