RTEMS 6.1-rc5
#define | MU_CR_NMI_MASK 0U |
Driver version | |
enum | _mu_status_flags { kMU_Tx0EmptyFlag = (1U << (MU_SR_TEn_SHIFT + 3U)) , kMU_Tx1EmptyFlag = (1U << (MU_SR_TEn_SHIFT + 2U)) , kMU_Tx2EmptyFlag = (1U << (MU_SR_TEn_SHIFT + 1U)) , kMU_Tx3EmptyFlag = (1U << (MU_SR_TEn_SHIFT + 0U)) , kMU_Rx0FullFlag = (1U << (MU_SR_RFn_SHIFT + 3U)) , kMU_Rx1FullFlag = (1U << (MU_SR_RFn_SHIFT + 2U)) , kMU_Rx2FullFlag = (1U << (MU_SR_RFn_SHIFT + 1U)) , kMU_Rx3FullFlag = (1U << (MU_SR_RFn_SHIFT + 0U)) , kMU_GenInt0Flag = (1U << (MU_SR_GIPn_SHIFT + 3U)) , kMU_GenInt1Flag = (1U << (MU_SR_GIPn_SHIFT + 2U)) , kMU_GenInt2Flag = (1U << (MU_SR_GIPn_SHIFT + 1U)) , kMU_GenInt3Flag = (1U << (MU_SR_GIPn_SHIFT + 0U)) , kMU_EventPendingFlag = MU_SR_EP_MASK , kMU_FlagsUpdatingFlag = MU_SR_FUP_MASK } |
MU status flags. More... | |
enum | _mu_interrupt_enable { kMU_Tx0EmptyInterruptEnable = (1U << (MU_CR_TIEn_SHIFT + 3U)) , kMU_Tx1EmptyInterruptEnable = (1U << (MU_CR_TIEn_SHIFT + 2U)) , kMU_Tx2EmptyInterruptEnable = (1U << (MU_CR_TIEn_SHIFT + 1U)) , kMU_Tx3EmptyInterruptEnable = (1U << (MU_CR_TIEn_SHIFT + 0U)) , kMU_Rx0FullInterruptEnable = (1U << (MU_CR_RIEn_SHIFT + 3U)) , kMU_Rx1FullInterruptEnable = (1U << (MU_CR_RIEn_SHIFT + 2U)) , kMU_Rx2FullInterruptEnable = (1U << (MU_CR_RIEn_SHIFT + 1U)) , kMU_Rx3FullInterruptEnable = (1U << (MU_CR_RIEn_SHIFT + 0U)) , kMU_GenInt0InterruptEnable = (int)(1U << (MU_CR_GIEn_SHIFT + 3U)) , kMU_GenInt1InterruptEnable = (1U << (MU_CR_GIEn_SHIFT + 2U)) , kMU_GenInt2InterruptEnable = (1U << (MU_CR_GIEn_SHIFT + 1U)) , kMU_GenInt3InterruptEnable = (1U << (MU_CR_GIEn_SHIFT + 0U)) } |
MU interrupt source to enable. More... | |
enum | _mu_interrupt_trigger { kMU_NmiInterruptTrigger = MU_CR_NMI_MASK , kMU_GenInt0InterruptTrigger = (1U << (MU_CR_GIRn_SHIFT + 3U)) , kMU_GenInt1InterruptTrigger = (1U << (MU_CR_GIRn_SHIFT + 2U)) , kMU_GenInt2InterruptTrigger = (1U << (MU_CR_GIRn_SHIFT + 1U)) , kMU_GenInt3InterruptTrigger = (1U << (MU_CR_GIRn_SHIFT + 0U)) } |
MU interrupt that could be triggered to the other core. More... | |
enum | _mu_msg_reg_index { kMU_MsgReg0 = 0 , kMU_MsgReg1 , kMU_MsgReg2 , kMU_MsgReg3 } |
MU message register. | |
typedef enum _mu_msg_reg_index | mu_msg_reg_index_t |
#define | FSL_MU_DRIVER_VERSION (MAKE_VERSION(2, 1, 1)) |
MU driver version. | |
MU initialization. | |
void | MU_Init (MU_Type *base) |
Initializes the MU module. | |
void | MU_Deinit (MU_Type *base) |
De-initializes the MU module. | |
MU Message | |
void | MU_SendMsg (MU_Type *base, uint32_t regIndex, uint32_t msg) |
Blocks to send a message. | |
uint32_t | MU_ReceiveMsg (MU_Type *base, uint32_t regIndex) |
Blocks to receive a message. | |
MU Flags | |
void | MU_SetFlags (MU_Type *base, uint32_t flags) |
Blocks setting the 3-bit MU flags reflect on the other MU side. | |
Status and Interrupt. | |
status_t | MU_TriggerInterrupts (MU_Type *base, uint32_t mask) |
Triggers interrupts to the other core. | |
MU misc functions | |
void | MU_BootCoreB (MU_Type *base, mu_core_boot_mode_t mode) |
Boots the core at B side. | |
void | MU_BootOtherCore (MU_Type *base, mu_core_boot_mode_t mode) |
Boots the other core. | |
void | MU_HardwareResetOtherCore (MU_Type *base, bool waitReset, bool holdReset, mu_core_boot_mode_t bootMode) |
Hardware reset the other core. | |
enum _mu_interrupt_enable |
enum _mu_status_flags |
MU status flags.
void MU_BootCoreB | ( | MU_Type * | base, |
mu_core_boot_mode_t | mode | ||
This function sets the B side core's boot configuration and releases the core from reset.
base | MU peripheral base address. |
mode | Core B boot mode. |
brief Boots the core at B side.
param base MU peripheral base address. param mode Core B boot mode. note Only MU side A can use this function.
void MU_BootOtherCore | ( | MU_Type * | base, |
This function boots the other core with a boot configuration.
mode | The other core boot mode. |
brief Boots the other core.
param base MU peripheral base address. param mode The other core boot mode.
void MU_Deinit | ( | MU_Type * | base | ) |
This function disables the MU clock only.
brief De-initializes the MU module.
void MU_HardwareResetOtherCore | ( | MU_Type * | base, |
bool | waitReset, | ||
bool | holdReset, | ||
mu_core_boot_mode_t | bootMode | ||
This function resets the other core, the other core could mask the hardware reset by calling MU_MaskHardwareReset. The hardware reset mask feature is only available for some platforms. This function could be used together with MU_BootOtherCore to control the other core reset workflow.
Example 1: Reset the other core, and no hold reset
In this example, the core at MU side B will reset with the specified boot mode.
Example 2: Reset the other core and hold it, then boot the other core later.
waitReset | Wait the other core enters reset.
holdReset | Hold the other core reset or not.
bootMode | Boot mode of the other core, if holdReset is true, this parameter is useless. |
brief Hardware reset the other core.
This function resets the other core, the other core could mask the hardware reset by calling ref MU_MaskHardwareReset. The hardware reset mask feature is only available for some platforms. This function could be used together with MU_BootOtherCore to control the other core reset workflow.
Example 1: Reset the other core, and no hold reset code MU_HardwareResetOtherCore(MU_A, true, false, bootMode); endcode In this example, the core at MU side B will reset with the specified boot mode.
Example 2: Reset the other core and hold it, then boot the other core later. code Here the other core enters reset, and the reset is hold MU_HardwareResetOtherCore(MU_A, true, true, modeDontCare); Current core boot the other core when necessary. MU_BootOtherCore(MU_A, bootMode); endcode
param base MU peripheral base address. param waitReset Wait the other core enters reset.
void MU_Init | ( | MU_Type * | base | ) |
This function enables the MU clock only.
brief Initializes the MU module.
uint32_t MU_ReceiveMsg | ( | MU_Type * | base, |
uint32_t | regIndex | ||
This function waits until the RX register is full and receives the message.
regIndex | MU message register, see mu_msg_reg_index_t |
brief Blocks to receive a message.
param base MU peripheral base address. param regIndex RX register index. return The received message.
void MU_SendMsg | ( | MU_Type * | base, |
uint32_t | regIndex, | ||
uint32_t | msg | ||
This function waits until the TX register is empty and sends the message.
msg | Message to send. |
brief Blocks to send a message.
param base MU peripheral base address. param regIndex TX register index. param msg Message to send.
void MU_SetFlags | ( | MU_Type * | base, |
uint32_t | flags | ||
This function blocks setting the 3-bit MU flags. Every time the 3-bit MU flags are changed, the status flag kMU_FlagsUpdatingFlag
asserts indicating the 3-bit MU flags are updating to the other side. After the 3-bit MU flags are updated, the status flag kMU_FlagsUpdatingFlag
is cleared by hardware. During the flags updating period, the flags cannot be changed. This function waits for the MU status flag kMU_FlagsUpdatingFlag
cleared and sets the 3-bit MU flags.
flags | The 3-bit MU flags to set. |
brief Blocks setting the 3-bit MU flags reflect on the other MU side.
param base MU peripheral base address. param flags The 3-bit MU flags to set.
This function triggers the specific interrupts to the other core. The interrupts to trigger are passed in as bit mask. See _mu_interrupt_trigger. The MU should not trigger an interrupt to the other core when the previous interrupt has not been processed by the other core. This function checks whether the previous interrupts have been processed. If not, it returns an error.
mask | Bit mask of the interrupts to trigger. See _mu_interrupt_trigger. |
kStatus_Success | Interrupts have been triggered successfully. |
kStatus_Fail | Previous interrupts have not been accepted. |
brief Triggers interrupts to the other core.
code if (kStatus_Success != MU_TriggerInterrupts(base, kMU_GenInt0InterruptTrigger | kMU_GenInt2InterruptTrigger)) { Previous general purpose interrupt 0 or general purpose interrupt 2 has not been processed by the other core. } endcode
param base MU peripheral base address. param mask Bit mask of the interrupts to trigger. See _mu_interrupt_trigger. retval kStatus_Success Interrupts have been triggered successfully. retval kStatus_Fail Previous interrupts have not been accepted.
