RTEMS 6.1-rc5
Modules | |
Lpi2c_slave_driver | |
struct | _lpi2c_master_config |
Structure with settings to initialize the LPI2C master module. More... | |
struct | _lpi2c_match_config |
LPI2C master data match configuration structure. More... | |
struct | _lpi2c_master_transfer |
Non-blocking transfer descriptor structure. More... | |
struct | _lpi2c_master_handle |
Driver handle for master non-blocking APIs. More... | |
Typedefs | |
typedef enum _lpi2c_direction | lpi2c_direction_t |
Direction of master and slave transfers. | |
typedef enum _lpi2c_master_pin_config | lpi2c_master_pin_config_t |
LPI2C pin configuration. | |
typedef enum _lpi2c_host_request_source | lpi2c_host_request_source_t |
LPI2C master host request selection. | |
typedef enum _lpi2c_host_request_polarity | lpi2c_host_request_polarity_t |
LPI2C master host request pin polarity configuration. | |
typedef struct _lpi2c_master_config | lpi2c_master_config_t |
Structure with settings to initialize the LPI2C master module. | |
typedef enum _lpi2c_data_match_config_mode | lpi2c_data_match_config_mode_t |
LPI2C master data match configuration modes. | |
typedef struct _lpi2c_match_config | lpi2c_data_match_config_t |
LPI2C master data match configuration structure. | |
typedef struct _lpi2c_master_transfer | lpi2c_master_transfer_t |
typedef struct _lpi2c_master_handle | lpi2c_master_handle_t |
typedef void(* | lpi2c_master_transfer_callback_t) (LPI2C_Type *base, lpi2c_master_handle_t *handle, status_t completionStatus, void *userData) |
Master completion callback function pointer type. | |
typedef void(* | lpi2c_master_isr_t) (LPI2C_Type *base, void *handle) |
Typedef for master interrupt handler, used internally for LPI2C master interrupt and EDMA transactional APIs. | |
Initialization and deinitialization | |
void | LPI2C_MasterGetDefaultConfig (lpi2c_master_config_t *masterConfig) |
Provides a default configuration for the LPI2C master peripheral. | |
void | LPI2C_MasterInit (LPI2C_Type *base, const lpi2c_master_config_t *masterConfig, uint32_t sourceClock_Hz) |
Initializes the LPI2C master peripheral. | |
void | LPI2C_MasterDeinit (LPI2C_Type *base) |
Deinitializes the LPI2C master peripheral. | |
void | LPI2C_MasterConfigureDataMatch (LPI2C_Type *base, const lpi2c_data_match_config_t *matchConfig) |
Configures LPI2C master data match feature. | |
status_t | LPI2C_MasterCheckAndClearError (LPI2C_Type *base, uint32_t status) |
Convert provided flags to status code, and clear any errors if present. | |
status_t | LPI2C_CheckForBusyBus (LPI2C_Type *base) |
Make sure the bus isn't already busy. | |
Bus operations | |
void | LPI2C_MasterSetBaudRate (LPI2C_Type *base, uint32_t sourceClock_Hz, uint32_t baudRate_Hz) |
Sets the I2C bus frequency for master transactions. | |
status_t | LPI2C_MasterStart (LPI2C_Type *base, uint8_t address, lpi2c_direction_t dir) |
Sends a START signal and slave address on the I2C bus. | |
status_t | LPI2C_MasterSend (LPI2C_Type *base, void *txBuff, size_t txSize) |
Performs a polling send transfer on the I2C bus. | |
status_t | LPI2C_MasterReceive (LPI2C_Type *base, void *rxBuff, size_t rxSize) |
Performs a polling receive transfer on the I2C bus. | |
status_t | LPI2C_MasterStop (LPI2C_Type *base) |
Sends a STOP signal on the I2C bus. | |
status_t | LPI2C_MasterTransferBlocking (LPI2C_Type *base, lpi2c_master_transfer_t *transfer) |
Performs a master polling transfer on the I2C bus. | |
Non-blocking | |
void | LPI2C_MasterTransferCreateHandle (LPI2C_Type *base, lpi2c_master_handle_t *handle, lpi2c_master_transfer_callback_t callback, void *userData) |
Creates a new handle for the LPI2C master non-blocking APIs. | |
status_t | LPI2C_MasterTransferNonBlocking (LPI2C_Type *base, lpi2c_master_handle_t *handle, lpi2c_master_transfer_t *transfer) |
Performs a non-blocking transaction on the I2C bus. | |
status_t | LPI2C_MasterTransferGetCount (LPI2C_Type *base, lpi2c_master_handle_t *handle, size_t *count) |
Returns number of bytes transferred so far. | |
void | LPI2C_MasterTransferAbort (LPI2C_Type *base, lpi2c_master_handle_t *handle) |
Terminates a non-blocking LPI2C master transmission early. | |
IRQ handler | |
void | LPI2C_MasterTransferHandleIRQ (LPI2C_Type *base, void *lpi2cMasterHandle) |
Reusable routine to handle master interrupts. | |
typedef struct _lpi2c_master_config lpi2c_master_config_t |
This structure holds configuration settings for the LPI2C peripheral. To initialize this structure to reasonable defaults, call the LPI2C_MasterGetDefaultConfig() function and pass a pointer to your configuration structure instance.
The configuration structure can be made constant so it resides in flash.
typedef void(* lpi2c_master_transfer_callback_t) (LPI2C_Type *base, lpi2c_master_handle_t *handle, status_t completionStatus, void *userData) |
This callback is used only for the non-blocking master transfer API. Specify the callback you wish to use in the call to LPI2C_MasterTransferCreateHandle().
base | The LPI2C peripheral base address. |
completionStatus | Either kStatus_Success or an error code describing how the transfer completed. |
userData | Arbitrary pointer-sized value passed from the application. |
enum _lpi2c_master_flags |
LPI2C master peripheral flags.
The following status register flags can be cleared:
All flags except kLPI2C_MasterBusyFlag and kLPI2C_MasterBusBusyFlag can be enabled as interrupts.
Transfer option flags.
status_t LPI2C_CheckForBusyBus | ( | LPI2C_Type * | base | ) |
A busy bus is allowed if we are the one driving it.
kStatus_Success | |
kStatus_LPI2C_Busy |
status_t LPI2C_MasterCheckAndClearError | ( | LPI2C_Type * | base, |
uint32_t | status | ||
status | Current status flags value that will be checked. |
void LPI2C_MasterConfigureDataMatch | ( | LPI2C_Type * | base, |
const lpi2c_data_match_config_t * | matchConfig | ||
matchConfig | Settings for the data match feature. |
brief Configures LPI2C master data match feature.
param base The LPI2C peripheral base address. param matchConfig Settings for the data match feature.
void LPI2C_MasterDeinit | ( | LPI2C_Type * | base | ) |
This function disables the LPI2C master peripheral and gates the clock. It also performs a software reset to restore the peripheral to reset conditions.
brief Deinitializes the LPI2C master peripheral.
void LPI2C_MasterGetDefaultConfig | ( | lpi2c_master_config_t * | masterConfig | ) |
This function provides the following default configuration for the LPI2C master peripheral:
After calling this function, you can override any settings in order to customize the configuration, prior to initializing the master driver with LPI2C_MasterInit().
[out] | masterConfig | User provided configuration structure for default values. Refer to lpi2c_master_config_t. |
brief Provides a default configuration for the LPI2C master peripheral.
This function provides the following default configuration for the LPI2C master peripheral: code masterConfig->enableMaster = true; masterConfig->debugEnable = false; masterConfig->ignoreAck = false; masterConfig->pinConfig = kLPI2C_2PinOpenDrain; masterConfig->baudRate_Hz = 100000U; masterConfig->busIdleTimeout_ns = 0U; masterConfig->pinLowTimeout_ns = 0U; masterConfig->sdaGlitchFilterWidth_ns = 0U; masterConfig->sclGlitchFilterWidth_ns = 0U; masterConfig->hostRequest.enable = false; masterConfig->hostRequest.source = kLPI2C_HostRequestExternalPin; masterConfig->hostRequest.polarity = kLPI2C_HostRequestPinActiveHigh; endcode
param[out] masterConfig User provided configuration structure for default values. Refer to lpi2c_master_config_t.
void LPI2C_MasterInit | ( | LPI2C_Type * | base, |
const lpi2c_master_config_t * | masterConfig, | ||
uint32_t | sourceClock_Hz | ||
This function enables the peripheral clock and initializes the LPI2C master peripheral as described by the user provided configuration. A software reset is performed prior to configuration.
masterConfig | User provided peripheral configuration. Use LPI2C_MasterGetDefaultConfig() to get a set of defaults that you can override. |
sourceClock_Hz | Frequency in Hertz of the LPI2C functional clock. Used to calculate the baud rate divisors, filter widths, and timeout periods. |
brief Initializes the LPI2C master peripheral.
param base The LPI2C peripheral base address. param masterConfig User provided peripheral configuration. Use LPI2C_MasterGetDefaultConfig() to get a set of defaults that you can override. param sourceClock_Hz Frequency in Hertz of the LPI2C functional clock. Used to calculate the baud rate divisors, filter widths, and timeout periods.
status_t LPI2C_MasterReceive | ( | LPI2C_Type * | base, |
void * | rxBuff, | ||
size_t | rxSize | ||
rxBuff | The pointer to the data to be transferred. |
rxSize | The length in bytes of the data to be transferred. |
kStatus_Success | Data was received successfully. |
kStatus_LPI2C_Busy | Another master is currently utilizing the bus. |
kStatus_LPI2C_Nak | The slave device sent a NAK in response to a byte. |
kStatus_LPI2C_FifoError | FIFO under run or overrun. |
kStatus_LPI2C_ArbitrationLost | Arbitration lost error. |
kStatus_LPI2C_PinLowTimeout | SCL or SDA were held low longer than the timeout. |
brief Performs a polling receive transfer on the I2C bus.
param base The LPI2C peripheral base address. param rxBuff The pointer to the data to be transferred. param rxSize The length in bytes of the data to be transferred. retval kStatus_Success Data was received successfully. retval kStatus_LPI2C_Busy Another master is currently utilizing the bus. retval kStatus_LPI2C_Nak The slave device sent a NAK in response to a byte. retval kStatus_LPI2C_FifoError FIFO under run or overrun. retval kStatus_LPI2C_ArbitrationLost Arbitration lost error. retval kStatus_LPI2C_PinLowTimeout SCL or SDA were held low longer than the timeout.
status_t LPI2C_MasterSend | ( | LPI2C_Type * | base, |
void * | txBuff, | ||
size_t | txSize | ||
Sends up to txSize number of bytes to the previously addressed slave device. The slave may reply with a NAK to any byte in order to terminate the transfer early. If this happens, this function returns kStatus_LPI2C_Nak.
txBuff | The pointer to the data to be transferred. |
txSize | The length in bytes of the data to be transferred. |
kStatus_Success | Data was sent successfully. |
kStatus_LPI2C_FifoError | FIFO under run or over run. |
brief Performs a polling send transfer on the I2C bus.
Sends up to a txSize number of bytes to the previously addressed slave device. The slave may reply with a NAK to any byte in order to terminate the transfer early. If this happens, this function returns kStatus_LPI2C_Nak.
param base The LPI2C peripheral base address. param txBuff The pointer to the data to be transferred. param txSize The length in bytes of the data to be transferred. retval kStatus_Success Data was sent successfully. retval kStatus_LPI2C_Busy Another master is currently utilizing the bus. retval kStatus_LPI2C_Nak The slave device sent a NAK in response to a byte. retval kStatus_LPI2C_FifoError FIFO under run or over run. retval kStatus_LPI2C_ArbitrationLost Arbitration lost error. retval kStatus_LPI2C_PinLowTimeout SCL or SDA were held low longer than the timeout.
void LPI2C_MasterSetBaudRate | ( | LPI2C_Type * | base, |
uint32_t | sourceClock_Hz, | ||
uint32_t | baudRate_Hz | ||
The LPI2C master is automatically disabled and re-enabled as necessary to configure the baud rate. Do not call this function during a transfer, or the transfer is aborted.
sourceClock_Hz | LPI2C functional clock frequency in Hertz. |
baudRate_Hz | Requested bus frequency in Hertz. |
brief Sets the I2C bus frequency for master transactions.
note Please note that the second parameter is the clock frequency of LPI2C module, the third parameter means user configured bus baudrate, this implementation is different from other I2C drivers which use baudrate configuration as second parameter and source clock frequency as third parameter.
param base The LPI2C peripheral base address. param sourceClock_Hz LPI2C functional clock frequency in Hertz. param baudRate_Hz Requested bus frequency in Hertz.
status_t LPI2C_MasterStart | ( | LPI2C_Type * | base, |
uint8_t | address, | ||
lpi2c_direction_t | dir | ||
This function is used to initiate a new master mode transfer. First, the bus state is checked to ensure that another master is not occupying the bus. Then a START signal is transmitted, followed by the 7-bit address specified in the address parameter. Note that this function does not actually wait until the START and address are successfully sent on the bus before returning.
address | 7-bit slave device address, in bits [6:0]. |
dir | Master transfer direction, either kLPI2C_Read or kLPI2C_Write. This parameter is used to set the R/w bit (bit 0) in the transmitted slave address. |
kStatus_Success | START signal and address were successfully enqueued in the transmit FIFO. |
brief Sends a START signal and slave address on the I2C bus.
This function is used to initiate a new master mode transfer. First, the bus state is checked to ensure that another master is not occupying the bus. Then a START signal is transmitted, followed by the 7-bit address specified in the a address parameter. Note that this function does not actually wait until the START and address are successfully sent on the bus before returning.
param base The LPI2C peripheral base address. param address 7-bit slave device address, in bits [6:0]. param dir Master transfer direction, either kLPI2C_Read or kLPI2C_Write. This parameter is used to set the R/w bit (bit 0) in the transmitted slave address. retval kStatus_Success START signal and address were successfully enqueued in the transmit FIFO. retval kStatus_LPI2C_Busy Another master is currently utilizing the bus.
status_t LPI2C_MasterStop | ( | LPI2C_Type * | base | ) |
This function does not return until the STOP signal is seen on the bus, or an error occurs.
kStatus_Success | The STOP signal was successfully sent on the bus and the transaction terminated. |
brief Sends a STOP signal on the I2C bus.
param base The LPI2C peripheral base address. retval kStatus_Success The STOP signal was successfully sent on the bus and the transaction terminated. retval kStatus_LPI2C_Busy Another master is currently utilizing the bus. retval kStatus_LPI2C_Nak The slave device sent a NAK in response to a byte. retval kStatus_LPI2C_FifoError FIFO under run or overrun. retval kStatus_LPI2C_ArbitrationLost Arbitration lost error. retval kStatus_LPI2C_PinLowTimeout SCL or SDA were held low longer than the timeout.
void LPI2C_MasterTransferAbort | ( | LPI2C_Type * | base, |
lpi2c_master_handle_t * | handle | ||
handle | Pointer to the LPI2C master driver handle. |
kStatus_Success | A transaction was successfully aborted. |
kStatus_LPI2C_Idle | There is not a non-blocking transaction currently in progress. |
brief Terminates a non-blocking LPI2C master transmission early.
note It is not safe to call this function from an IRQ handler that has a higher priority than the LPI2C peripheral's IRQ priority.
param base The LPI2C peripheral base address. param handle Pointer to the LPI2C master driver handle. retval kStatus_Success A transaction was successfully aborted. retval kStatus_LPI2C_Idle There is not a non-blocking transaction currently in progress.
status_t LPI2C_MasterTransferBlocking | ( | LPI2C_Type * | base, |
lpi2c_master_transfer_t * | transfer | ||
transfer | Pointer to the transfer structure. |
brief Performs a master polling transfer on the I2C bus.
note The API does not return until the transfer succeeds or fails due to error happens during transfer.
param base The LPI2C peripheral base address. param transfer Pointer to the transfer structure. retval kStatus_Success Data was received successfully. retval kStatus_LPI2C_Busy Another master is currently utilizing the bus. retval kStatus_LPI2C_Nak The slave device sent a NAK in response to a byte. retval kStatus_LPI2C_FifoError FIFO under run or overrun. retval kStatus_LPI2C_ArbitrationLost Arbitration lost error. retval kStatus_LPI2C_PinLowTimeout SCL or SDA were held low longer than the timeout.
void LPI2C_MasterTransferCreateHandle | ( | LPI2C_Type * | base, |
lpi2c_master_handle_t * | handle, | ||
lpi2c_master_transfer_callback_t | callback, | ||
void * | userData | ||
The creation of a handle is for use with the non-blocking APIs. Once a handle is created, there is not a corresponding destroy handle. If the user wants to terminate a transfer, the LPI2C_MasterTransferAbort() API shall be called.
base | The LPI2C peripheral base address. | |
[out] | handle | Pointer to the LPI2C master driver handle. |
callback | User provided pointer to the asynchronous callback function. | |
userData | User provided pointer to the application callback data. |
brief Creates a new handle for the LPI2C master non-blocking APIs.
note The function also enables the NVIC IRQ for the input LPI2C. Need to notice that on some SoCs the LPI2C IRQ is connected to INTMUX, in this case user needs to enable the associated INTMUX IRQ in application.
param base The LPI2C peripheral base address. param[out] handle Pointer to the LPI2C master driver handle. param callback User provided pointer to the asynchronous callback function. param userData User provided pointer to the application callback data.
status_t LPI2C_MasterTransferGetCount | ( | LPI2C_Type * | base, |
size_t * | count | ||
handle | Pointer to the LPI2C master driver handle. | |
[out] | count | Number of bytes transferred so far by the non-blocking transaction. |
kStatus_Success | |
kStatus_NoTransferInProgress | There is not a non-blocking transaction currently in progress. |
brief Returns number of bytes transferred so far. param base The LPI2C peripheral base address. param handle Pointer to the LPI2C master driver handle. param[out] count Number of bytes transferred so far by the non-blocking transaction. retval kStatus_Success retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress.
void LPI2C_MasterTransferHandleIRQ | ( | LPI2C_Type * | base, |
void * | lpi2cMasterHandle | ||
lpi2cMasterHandle | Pointer to the LPI2C master driver handle. |
brief Reusable routine to handle master interrupts. note This function does not need to be called unless you are reimplementing the nonblocking API's interrupt handler routines to add special functionality. param base The LPI2C peripheral base address. param lpi2cMasterHandle Pointer to the LPI2C master driver handle.
status_t LPI2C_MasterTransferNonBlocking | ( | LPI2C_Type * | base, |
transfer | The pointer to the transfer descriptor. |
kStatus_Success | The transaction was started successfully. |
kStatus_LPI2C_Busy | Either another master is currently utilizing the bus, or a non-blocking transaction is already in progress. |
brief Performs a non-blocking transaction on the I2C bus.
param base The LPI2C peripheral base address. param handle Pointer to the LPI2C master driver handle. param transfer The pointer to the transfer descriptor. retval kStatus_Success The transaction was started successfully. retval kStatus_LPI2C_Busy Either another master is currently utilizing the bus, or a non-blocking transaction is already in progress.
