RTEMS 6.1-rc5
Data Structures | Macros | Typedefs | Enumerations
Gpc
struct  _gpc_tran_step_config
 Configuration for GPC transition step. More...
#define GPC_RESERVED_USE_MACRO   0xFFFFFFFFU
#define GPC_CM_SLEEP_SSAR_CTRL_OFFSET   (0x200)
#define GPC_CM_SLEEP_LPCG_CTRL_OFFSET   (0x208)
#define GPC_CM_SLEEP_PLL_CTRL_OFFSET   (0x210)
#define GPC_CM_SLEEP_ISO_CTRL_OFFSET   (0x218)
#define GPC_CM_SLEEP_RESET_CTRL_OFFSET   (0x220)
#define GPC_CM_SLEEP_POWER_CTRL_OFFSET   (0x228)
#define GPC_CM_WAKEUP_POWER_CTRL_OFFSET   (0x290)
#define GPC_CM_WAKEUP_RESET_CTRL_OFFSET   (0x298)
#define GPC_CM_WAKEUP_ISO_CTRL_OFFSET   (0x2A0)
#define GPC_CM_WAKEUP_PLL_CTRL_OFFSET   (0x2A8)
#define GPC_CM_WAKEUP_LPCG_CTRL_OFFSET   (0x2B0)
#define GPC_CM_WAKEUP_SSAR_CTRL_OFFSET   (0x2B8)
#define GPC_SP_SSAR_SAVE_CTRL_OFFSET   (0x100)
#define GPC_SP_LPCG_OFF_CTRL_OFFSET   (0x110)
#define GPC_SP_GROUP_DOWN_CTRL_OFFSET   (0x120)
#define GPC_SP_ROOT_DOWN_CTRL_OFFSET   (0x130)
#define GPC_SP_PLL_OFF_CTRL_OFFSET   (0x140)
#define GPC_SP_ISO_ON_CTRL_OFFSET   (0x150)
#define GPC_SP_RESET_EARLY_CTRL_OFFSET   (0x160)
#define GPC_SP_POWER_OFF_CTRL_OFFSET   (0x170)
#define GPC_SP_BIAS_OFF_CTRL_OFFSET   (0x180)
#define GPC_SP_BG_PLDO_OFF_CTRL_OFFSET   (0x190)
#define GPC_SP_LDO_PRE_CTRL_OFFSET   (0x1A0)
#define GPC_SP_DCDC_DOWN_CTRL_OFFSET   (0x1B0)
#define GPC_SP_DCDC_UP_CTRL_OFFSET   (0x2B0)
#define GPC_SP_LDO_POST_CTRL_OFFSET   (0x210)
#define GPC_SP_BG_PLDO_ON_CTRL_OFFSET   (0x220)
#define GPC_SP_BIAS_ON_CTRL_OFFSET   (0x230)
#define GPC_SP_POWER_ON_CTRL_OFFSET   (0x240)
#define GPC_SP_RESET_LATE_CTRL_OFFSET   (0x250)
#define GPC_SP_ISO_OFF_CTRL_OFFSET   (0x260)
#define GPC_SP_PLL_ON_CTRL_OFFSET   (0x270)
#define GPC_SP_ROOT_UP_CTRL_OFFSET   (0x280)
#define GPC_SP_GROUP_UP_CTRL_OFFSET   (0x290)
#define GPC_SP_LPCG_ON_CTRL_OFFSET   (0x2A0)
#define GPC_SP_SSAR_RESTORE_CTRL_OFFSET   (0x2B0)
#define GPC_STBY_LPCG_IN_CTRL_OFFSET   (0xF0)
#define GPC_STBY_PLL_IN_CTRL_OFFSET   (0x100)
#define GPC_STBY_BIAS_IN_CTRL_OFFSET   (0x110)
#define GPC_STBY_PLDO_IN_CTRL_OFFSET   (0x120)
#define GPC_STBY_BANDGAP_IN_CTRL_OFFSET   (0x128)
#define GPC_STBY_LDO_IN_CTRL_OFFSET   (0x130)
#define GPC_STBY_DCDC_IN_CTRL_OFFSET   (0x140)
#define GPC_STBY_PMIC_IN_CTRL_OFFSET   (0x150)
#define GPC_STBY_PMIC_OUT_CTRL_OFFSET   (0x200)
#define GPC_STBY_DCDC_OUT_CTRL_OFFSET   (0x210)
#define GPC_STBY_LDO_OUT_CTRL_OFFSET   (0x220)
#define GPC_STBY_BANDGAP_OUT_CTRL_OFFSET   (0x238)
#define GPC_STBY_PLDO_OUT_CTRL_OFFSET   (0x238)
#define GPC_STBY_BIAS_OUT_CTRL_OFFSET   (0x240)
#define GPC_STBY_PLL_OUT_CTRL_OFFSET   (0x250)
#define GPC_STBY_LPCG_OUT_CTRL_OFFSET   (0x260)
#define GPC_CM_STEP_REG_OFFSET
#define GPC_SP_STEP_REG_OFFSET
#define GPC_STBY_STEP_REG_OFFSET
#define GPC_STAT(mask, shift)   (uint32_t)(((uint32_t)(shift) << 16UL) + ((uint32_t)(mask) >> (uint32_t)(shift)))
#define GPC_CM_ALL_INTERRUPT_STATUS
typedef enum _gpc_cm_standby_mode_status gpc_cm_standby_mode_status_t
 CPU standby mode status.
typedef enum _gpc_cm_tran_step gpc_cm_tran_step_t
 CPU mode transition step in sleep/wakeup sequence.
typedef enum _gpc_tran_step_counter_mode gpc_tran_step_counter_mode_t
 Step counter work mode.
typedef enum _gpc_sp_tran_step gpc_sp_tran_step_t
 GPC set point transition steps.
typedef enum _gpc_cpu_mode gpc_cpu_mode_t
 CPU mode.
typedef struct _gpc_tran_step_config gpc_tran_step_config_t
typedef enum _gpc_cm_wakeup_sp_sel gpc_cm_wakeup_sp_sel_t
 CPU wakeup sequence setpoint options.
typedef enum _gpc_stby_tran_step gpc_stby_tran_step_t
 GPC standby mode transition steps.
enum  { kGPC_CM_EventWakeupRequest , kGPC_CM_DebugWakeupRequest }
 _gpc_cm_non_irq_wakeup_request GPC Non-IRQ wakeup request. More...
enum  {
  kGPC_SetPoint0 = 1UL << 0UL , kGPC_SetPoint1 = 1UL << 1UL , kGPC_SetPoint2 = 1UL << 2UL , kGPC_SetPoint3 = 1UL << 3UL ,
  kGPC_SetPoint4 = 1UL << 4UL , kGPC_SetPoint5 = 1UL << 5UL , kGPC_SetPoint6 = 1UL << 6UL , kGPC_SetPoint7 = 1UL << 7UL ,
  kGPC_SetPoint8 = 1UL << 8UL , kGPC_SetPoint9 = 1UL << 9UL , kGPC_SetPoint10 = 1UL << 10UL , kGPC_SetPoint11 = 1UL << 11UL ,
  kGPC_SetPoint12 = 1UL << 12UL , kGPC_SetPoint13 = 1UL << 13UL , kGPC_SetPoint14 = 1UL << 14UL , kGPC_SetPoint15 = 1UL << 15UL
enum  { kGPC_CM_SoftSPNotAllowedStatusFlag = GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_MASK , kGPC_CM_WaitSPNotAllowedStatusFlag = GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_MASK , kGPC_CM_SleepSPNotAllowedStatusFlag = GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_MASK }
 _gpc_cm_interrupt_status_flag
enum  _gpc_cm_standby_mode_status { kGPC_CM_SleepBusy , kGPC_CM_WakeupBusy }
 CPU standby mode status. More...
enum  _gpc_cm_tran_step {
  kGPC_CM_SleepSsar = 0UL , kGPC_CM_SleepLpcg = 1UL , kGPC_CM_SleepPll = 2UL , kGPC_CM_SleepIso = 3UL ,
  kGPC_CM_SleepReset = 4UL , kGPC_CM_SleepPower = 5UL , kGPC_CM_SleepSP = 6UL , kGPC_CM_SleepSTBY = 7UL ,
  kGPC_CM_WakeupSTBY = 8UL , kGPC_CM_WakeupSP = 9UL , kGPC_CM_WakeupPower = 10UL , kGPC_CM_WakeupReset = 11UL ,
  kGPC_CM_WakeupIso = 12UL , kGPC_CM_WakeupPll = 13UL , kGPC_CM_WakeupLpcg = 14UL , kGPC_CM_WakeupSsar = 15UL
 CPU mode transition step in sleep/wakeup sequence. More...
enum  _gpc_tran_step_counter_mode { kGPC_StepCounterDisableMode , kGPC_StepCounterDelayMode , kGPC_StepCounterIgnoreResponseMode = 2UL , kGPC_StepCounterTimeOutMode = 3UL }
 Step counter work mode. More...
enum  _gpc_sp_tran_step {
  kGPC_SP_SsarSave = 0UL , kGPC_SP_LpcgOff = 1UL , kGPC_SP_GroupDown = 2UL , kGPC_SP_RootDown = 3UL ,
  kGPC_SP_PllOff = 4UL , kGPC_SP_IsoOn = 5UL , kGPC_SP_ResetEarly = 6UL , kGPC_SP_PowerOff = 7UL ,
  kGPC_SP_BiasOff = 8UL , kGPC_SP_BandgapPllLdoOff = 9UL , kGPC_SP_LdoPre = 10UL , kGPC_SP_DcdcDown = 11UL ,
  kGPC_SP_DcdcUp = 12UL , kGPC_SP_LdoPost = 13UL , kGPC_SP_BandgapPllLdoOn = 14UL , kGPC_SP_BiasOn = 15UL ,
  kGPC_SP_PowerOn = 16UL , kGPC_SP_ResetLate = 17UL , kGPC_SP_IsoOff = 18UL , kGPC_SP_PllOn = 19UL ,
  kGPC_SP_RootUp = 20UL , kGPC_SP_GroupUp = 21UL , kGPC_SP_LpcgOn = 22UL , kGPC_SP_SsarRestore = 23UL
 GPC set point transition steps. More...
enum  _gpc_cpu_mode { kGPC_RunMode = 0x0UL , kGPC_WaitMode = 0x1UL , kGPC_StopMode = 0x2UL , kGPC_SuspendMode = 0x3UL }
 CPU mode. More...
enum  _gpc_cm_wakeup_sp_sel { kGPC_CM_WakeupSetpoint , kGPC_CM_RequestPreviousSetpoint = 1UL }
 CPU wakeup sequence setpoint options. More...
enum  _gpc_stby_tran_step {
  kGPC_STBY_LpcgIn = 0UL , kGPC_STBY_PllIn = 1UL , kGPC_STBY_BiasIn = 2UL , kGPC_STBY_PldoIn = 3UL ,
  kGPC_STBY_BandgapIn = 4UL , kGPC_STBY_LdoIn = 5UL , kGPC_STBY_DcdcIn = 6UL , kGPC_STBY_PmicIn = 7UL ,
  kGPC_STBY_PmicOut = 8UL , kGPC_STBY_DcdcOut = 9UL , kGPC_STBY_LdoOut = 10UL , kGPC_STBY_BandgapOut = 11UL ,
  kGPC_STBY_PldoOut = 12UL , kGPC_STBY_BiasOut = 13UL , kGPC_STBY_PllOut = 14UL , kGPC_STBY_LpcgOut = 15UL
 GPC standby mode transition steps. More...
CPU mode control
void GPC_CM_EnableIrqWakeup (GPC_CPU_MODE_CTRL_Type *base, uint32_t irqId, bool enable)
 Enable IRQ wakeup request.
bool GPC_CM_GetIrqWakeupStatus (GPC_CPU_MODE_CTRL_Type *base, uint32_t irqId)
 Get the status of the IRQ wakeup request.
void GPC_CM_ConfigCpuModeTransitionStep (GPC_CPU_MODE_CTRL_Type *base, gpc_cm_tran_step_t step, const gpc_tran_step_config_t *config)
 Config the cpu mode transition step.
void GPC_CM_RequestSleepModeSetPointTransition (GPC_CPU_MODE_CTRL_Type *base, uint8_t setPointSleep, uint8_t setPointWakeup, gpc_cm_wakeup_sp_sel_t wakeupSel)
 Request a set point transition before the CPU transfers into a sleep mode.
void GPC_CM_RequestRunModeSetPointTransition (GPC_CPU_MODE_CTRL_Type *base, uint8_t setPointRun)
 Request a set point transition during run mode.
void GPC_CM_SetCpuModeSetPointMapping (GPC_CPU_MODE_CTRL_Type *base, gpc_cpu_mode_t mode, uint32_t map)
 Set the set point mapping value for each cpu mode.
void GPC_CM_RequestStandbyMode (GPC_CPU_MODE_CTRL_Type *base, const gpc_cpu_mode_t mode)
 Request the chip into standby mode.
void GPC_CM_ClearStandbyModeRequest (GPC_CPU_MODE_CTRL_Type *base, const gpc_cpu_mode_t mode)
 Clear the standby mode request.
void GPC_CM_ClearInterruptStatusFlags (GPC_CPU_MODE_CTRL_Type *base, uint32_t mask)
 Clears CPU module interrut status flags.
Set point request control
void GPC_SP_ConfigSetPointTransitionStep (GPC_SET_POINT_CTRL_Type *base, gpc_sp_tran_step_t step, const gpc_tran_step_config_t *config)
 Config the set point transition step.
Standby mode control
void GPC_STBY_ConfigStandbyTransitionStep (GPC_STBY_CTRL_Type *base, gpc_stby_tran_step_t step, const gpc_tran_step_config_t *config)
 Config the standby transition step.
Driver version
void GPC_EnableIRQ (GPC_Type *base, uint32_t irqId)
 Enable the IRQ.
void GPC_DisableIRQ (GPC_Type *base, uint32_t irqId)
 Disable the IRQ.
bool GPC_GetIRQStatusFlag (GPC_Type *base, uint32_t irqId)
 Get the IRQ/Event flag.
#define FSL_GPC_DRIVER_VERSION   (MAKE_VERSION(2, 1, 1))
 GPC driver version 2.1.1.
Driver version
#define FSL_GPC_RIVER_VERSION   (MAKE_VERSION(2, 2, 0))
 GPC driver version 2.2.0.
◆ GPC_CM_ALL_INTERRUPT_STATUS
Value:
(GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SLEEP_INT_MASK | \
GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_WAKEUP_INT_MASK | \
GPC_CPU_MODE_CTRL_CM_INT_CTRL_SP_REQ_NOT_ALLOWED_SOFT_INT_MASK)
◆ GPC_CM_STEP_REG_OFFSET
Value:
GPC_CM_SLEEP_SSAR_CTRL_OFFSET, GPC_CM_SLEEP_LPCG_CTRL_OFFSET, GPC_CM_SLEEP_PLL_CTRL_OFFSET, \
GPC_CM_SLEEP_ISO_CTRL_OFFSET, GPC_CM_SLEEP_RESET_CTRL_OFFSET, GPC_CM_SLEEP_POWER_CTRL_OFFSET, \
GPC_RESERVED_USE_MACRO, GPC_RESERVED_USE_MACRO, GPC_RESERVED_USE_MACRO, GPC_RESERVED_USE_MACRO, \
GPC_CM_WAKEUP_POWER_CTRL_OFFSET, GPC_CM_WAKEUP_RESET_CTRL_OFFSET, GPC_CM_WAKEUP_ISO_CTRL_OFFSET, \
GPC_CM_WAKEUP_PLL_CTRL_OFFSET, GPC_CM_WAKEUP_LPCG_CTRL_OFFSET, GPC_CM_WAKEUP_SSAR_CTRL_OFFSET, \
◆ GPC_SP_STEP_REG_OFFSET
Value:
GPC_SP_SSAR_SAVE_CTRL_OFFSET, GPC_SP_LPCG_OFF_CTRL_OFFSET, GPC_SP_GROUP_DOWN_CTRL_OFFSET, \
GPC_SP_ROOT_DOWN_CTRL_OFFSET, GPC_SP_PLL_OFF_CTRL_OFFSET, GPC_SP_ISO_ON_CTRL_OFFSET, \
GPC_SP_RESET_EARLY_CTRL_OFFSET, GPC_SP_POWER_OFF_CTRL_OFFSET, GPC_SP_BIAS_OFF_CTRL_OFFSET, \
GPC_SP_BG_PLDO_OFF_CTRL_OFFSET, GPC_SP_LDO_PRE_CTRL_OFFSET, GPC_SP_DCDC_DOWN_CTRL_OFFSET, \
GPC_SP_DCDC_UP_CTRL_OFFSET, GPC_SP_LDO_POST_CTRL_OFFSET, GPC_SP_BG_PLDO_ON_CTRL_OFFSET, \
GPC_SP_BIAS_ON_CTRL_OFFSET, GPC_SP_POWER_ON_CTRL_OFFSET, GPC_SP_RESET_LATE_CTRL_OFFSET, \
GPC_SP_ISO_OFF_CTRL_OFFSET, GPC_SP_PLL_ON_CTRL_OFFSET, GPC_SP_ROOT_UP_CTRL_OFFSET, \
GPC_SP_GROUP_UP_CTRL_OFFSET, GPC_SP_LPCG_ON_CTRL_OFFSET, GPC_SP_SSAR_RESTORE_CTRL_OFFSET, \
◆ GPC_STBY_STEP_REG_OFFSET
Value:
GPC_STBY_LPCG_IN_CTRL_OFFSET, GPC_STBY_PLL_IN_CTRL_OFFSET, GPC_STBY_BIAS_IN_CTRL_OFFSET, \
GPC_STBY_PLDO_IN_CTRL_OFFSET, GPC_STBY_BANDGAP_IN_CTRL_OFFSET, GPC_STBY_LDO_IN_CTRL_OFFSET, \
GPC_STBY_DCDC_IN_CTRL_OFFSET, GPC_STBY_PMIC_IN_CTRL_OFFSET, GPC_STBY_PMIC_OUT_CTRL_OFFSET, \
GPC_STBY_DCDC_OUT_CTRL_OFFSET, GPC_STBY_LDO_OUT_CTRL_OFFSET, GPC_STBY_BANDGAP_OUT_CTRL_OFFSET, \
GPC_STBY_PLDO_OUT_CTRL_OFFSET, GPC_STBY_BIAS_OUT_CTRL_OFFSET, GPC_STBY_PLL_OUT_CTRL_OFFSET, \
GPC_STBY_LPCG_OUT_CTRL_OFFSET, \
◆ anonymous enum
anonymous enum
Event wakeup request.
Debug wakeup request.
◆ anonymous enum
anonymous enum
kGPC_SetPoint0
GPC set point 0.
kGPC_SetPoint1
GPC set point 1.
kGPC_SetPoint2
GPC set point 2.
kGPC_SetPoint3
GPC set point 3.
kGPC_SetPoint4
GPC set point 4.
kGPC_SetPoint5
GPC set point 5.
kGPC_SetPoint6
GPC set point 6.
kGPC_SetPoint7
GPC set point 7.
kGPC_SetPoint8
GPC set point 8.
kGPC_SetPoint9
GPC set point 9.
kGPC_SetPoint10
GPC set point 10.
kGPC_SetPoint11
GPC set point 11.
kGPC_SetPoint12
GPC set point 12.
kGPC_SetPoint13
GPC set point 13.
kGPC_SetPoint14
GPC set point 14.
kGPC_SetPoint15
GPC set point 15.
◆ _gpc_cm_standby_mode_status
kGPC_CM_SleepBusy
Indicate the CPU is busy entering standby mode.
kGPC_CM_WakeupBusy
Indicate the CPU is busy exiting standby mode.
◆ _gpc_cm_tran_step
kGPC_CM_SleepSsar
SSAR (State Save And Restore) sleep step.
kGPC_CM_SleepLpcg
LPCG (Low Power Clock Gating) sleep step.
kGPC_CM_SleepPll
PLL sleep step.
kGPC_CM_SleepIso
ISO (Isolation) sleep step.
kGPC_CM_SleepReset
Reset sleep step.
kGPC_CM_SleepPower
Power sleep step.
kGPC_CM_SleepSP
Setpoint sleep step. Note that this step is controlled by setpoint controller.
kGPC_CM_SleepSTBY
Standby sleep step. Note that this step is controlled by standby controller.
kGPC_CM_WakeupSTBY
Standby wakeup step. Note that this step is controlled by standby controller.
kGPC_CM_WakeupSP
Setpoint wakeup step. Note that this step is controlled by setpoint countroller.
kGPC_CM_WakeupPower
Power wakeup step.
kGPC_CM_WakeupReset
Reset wakeup step.
kGPC_CM_WakeupIso
ISO wakeup step.
kGPC_CM_WakeupPll
PLL wakeup step.
kGPC_CM_WakeupLpcg
LPCG wakeup step.
kGPC_CM_WakeupSsar
SSAR wakeup step.
◆ _gpc_cm_wakeup_sp_sel
Request SP transition to CPU_SP_WAKEUP (param "setPointWakeup" in gpc_cm_sleep_sp_tran_config_t).
Request SP transition to the set point when the sleep event happens.
◆ _gpc_cpu_mode
CPU mode.
kGPC_RunMode
Stay in RUN mode.
kGPC_WaitMode
Transit to WAIT mode.
kGPC_StopMode
Transit to STOP mode.
kGPC_SuspendMode
Transit to SUSPEND mode.
◆ _gpc_sp_tran_step
kGPC_SP_SsarSave
SSAR save step.
kGPC_SP_LpcgOff
LPCG off step.
kGPC_SP_GroupDown
Group down step.
kGPC_SP_RootDown
Root down step.
kGPC_SP_PllOff
PLL off step.
kGPC_SP_IsoOn
ISO on.
kGPC_SP_ResetEarly
Reset early step.
kGPC_SP_PowerOff
Power off step.
kGPC_SP_BiasOff
Bias off step.
Bandgap and PLL_LDO off step.
kGPC_SP_LdoPre
LDO (Low-Dropout) pre step.
kGPC_SP_DcdcDown
DCDC down step.
kGPC_SP_DcdcUp
DCDC up step.
kGPC_SP_LdoPost
LDO post step.
Bandgap and PLL_LDO on step.
kGPC_SP_BiasOn
Bias on step.
kGPC_SP_PowerOn
Power on step.
kGPC_SP_ResetLate
Reset late step.
kGPC_SP_IsoOff
ISO off step.
kGPC_SP_PllOn
PLL on step
kGPC_SP_RootUp
Root up step.
kGPC_SP_GroupUp
Group up step.
kGPC_SP_LpcgOn
LPCG on step.
kGPC_SP_SsarRestore
SSAR restore step.
◆ _gpc_stby_tran_step
kGPC_STBY_LpcgIn
LPCG in step.
kGPC_STBY_PllIn
PLL in step.
kGPC_STBY_BiasIn
Bias in step.
kGPC_STBY_PldoIn
PLDO in step.
kGPC_STBY_BandgapIn
Bandgap in step.
kGPC_STBY_LdoIn
LDO in step.
kGPC_STBY_DcdcIn
DCDC in step.
kGPC_STBY_PmicIn
PMIC in step.
kGPC_STBY_PmicOut
PMIC out step.
kGPC_STBY_DcdcOut
DCDC out step.
kGPC_STBY_LdoOut
LDO out step.
Bandgap out step.
kGPC_STBY_PldoOut
PLDO out step.
kGPC_STBY_BiasOut
Bias out step.
kGPC_STBY_PllOut
PLL out step.
kGPC_STBY_LpcgOut
LPCG out step.
◆ _gpc_tran_step_counter_mode
Counter disable mode: not use step counter, step completes once receiving step_done.
Counter delay mode: delay after receiving step_done, delay cycle number is STEP_CNT
Ignore step_done response, the counter starts to count once step begins, when counter reaches STEP_CNT value, the step completes.
Time out mode, the counter starts to count once step begins, the step completes when either step_done received or counting to STEP_CNT value.
◆ GPC_CM_ClearInterruptStatusFlags()
void GPC_CM_ClearInterruptStatusFlags ( GPC_CPU_MODE_CTRL_Type base,
uint32_t  mask
Parameters
baseGPC CPU module base address.
maskThe interrupt status flags to be cleared. Should be the OR'ed value of _gpc_cm_interrupt_status_flag.
brief Clears CPU module interrut status flags.
param base GPC CPU module base address. param mask The interrupt status flags to be cleared. Should be the OR'ed value of _gpc_cm_interrupt_status_flag.
◆ GPC_CM_ClearStandbyModeRequest()
void GPC_CM_ClearStandbyModeRequest ( GPC_CPU_MODE_CTRL_Type base,
Parameters
modeCPU mode. Refer to "gpc_cpu_mode_t".
◆ GPC_CM_ConfigCpuModeTransitionStep()
void GPC_CM_ConfigCpuModeTransitionStep ( GPC_CPU_MODE_CTRL_Type base,
const gpc_tran_step_config_t config
Note
This function can not config the setpoint sleep/wakeup operation for those operation is controlled by setpoint control. This funcion can not config the standby sleep/wakeup too, because those operation is controlled by standby controlled.
Parameters
stepstep type, refer to "gpc_cm_tran_step_t".
configtransition step configuration, refer to "gpc_tran_step_config_t".
brief Config the cpu mode transition step.
note This function can not config the setpoint sleep/wakeup operation for those operation is controlled by setpoint control. This funcion can not config the standby sleep/wakeup too, because those operation is controlled by standby controlled.
param base GPC CPU module base address. param step step type, refer to "gpc_cm_tran_step_t". param config transition step configuration, refer to "gpc_tran_step_config_t".
◆ GPC_CM_EnableIrqWakeup()
void GPC_CM_EnableIrqWakeup ( GPC_CPU_MODE_CTRL_Type base,
uint32_t  irqId,
bool  enable
This function enables the IRQ request which can wakeup the CPU platform.
Parameters
irqIdID of the IRQ, accessible range is 0-255.
enableEnable the IRQ request or not.
brief Enable IRQ wakeup request.
param base GPC CPU module base address. param irqId ID of the IRQ, accessible range is 0-255. param enable Enable the IRQ request or not.
◆ GPC_CM_GetIrqWakeupStatus()
bool GPC_CM_GetIrqWakeupStatus ( GPC_CPU_MODE_CTRL_Type base,
uint32_t  irqId
Parameters
Returns
Indicate the IRQ request is asserted or not.
brief Get the status of the IRQ wakeup request.
param base GPC CPU module base address. param irqId ID of the IRQ, accessible range is 0-255. return Indicate the IRQ request is asserted or not.
◆ GPC_CM_RequestRunModeSetPointTransition()
void GPC_CM_RequestRunModeSetPointTransition ( GPC_CPU_MODE_CTRL_Type base,
uint8_t  setPointRun
This function triggers the set point transition and selects which one the CMC want to transfer to.
Parameters
setPointRunThe set point CPU want the system to transit in the run mode.
brief Request a set point transition during run mode.
param base GPC CPU module base address. param setPointRun The set point CPU want the system to transit in the run mode.
◆ GPC_CM_RequestSleepModeSetPointTransition()
void GPC_CM_RequestSleepModeSetPointTransition ( GPC_CPU_MODE_CTRL_Type base,
This function triggers the set point transition during a CPU Sleep/wakeup event and selects which one the CMC want to transfer to.
Parameters
setPointSleepThe set point CPU want the system to transit to on next CPU platform sleep sequence.
setPointWakeupThe set point CPU want the system to transit to on next CPU platform wakeup sequence.
wakeupSelSelect the set point transition on the next CPU platform wakeup sequence.
brief Request a set point transition before the CPU transfers into a sleep mode.
param base GPC CPU module base address. param setPointSleep The set point CPU want the system to transit to on next CPU platform sleep sequence. param setPointWakeup The set point CPU want the system to transit to on next CPU platform wakeup sequence. param wakeupSel Select the set point transition on the next CPU platform wakeup sequence.
◆ GPC_CM_RequestStandbyMode()
void GPC_CM_RequestStandbyMode ( GPC_CPU_MODE_CTRL_Type base,
Parameters
◆ GPC_CM_SetCpuModeSetPointMapping()
void GPC_CM_SetCpuModeSetPointMapping ( GPC_CPU_MODE_CTRL_Type base,
uint32_t  map
This function configures which set point is allowed when CPU enters RUN/WAIT/STOP/SUSPEND. If there are multiple setpoints, use:
map = kkGPC_SetPoint0 | kGPC_SetPoint1 | ... | kGPC_SetPoint15;
@ kGPC_SetPoint15
Definition: fsl_gpc.h:159
@ kGPC_SetPoint1
Definition: fsl_gpc.h:145
Definition: mm.c:60
Parameters
mapMap value of the set point. Refer to "_gpc_setpoint_map".
◆ GPC_DisableIRQ()
void GPC_DisableIRQ ( GPC_Type base,
uint32_t  irqId
Disable the IRQ.
Parameters
baseGPC peripheral base address.
irqIdID number of IRQ to be disabled, available range is 32-159. 0-31 is available in some platforms.
brief Disable the IRQ.
param base GPC peripheral base address. param irqId ID number of IRQ to be disabled, available range is 32-159. 0-31 is available in some platforms.
◆ GPC_EnableIRQ()
void GPC_EnableIRQ ( GPC_Type base,
uint32_t  irqId
Enable the IRQ.
Parameters
irqIdID number of IRQ to be enabled, available range is 32-159. 0-31 is available in some platforms.
brief Enable the IRQ.
param base GPC peripheral base address. param irqId ID number of IRQ to be enabled, available range is 32-159. 0-31 is available in some platforms.
◆ GPC_GetIRQStatusFlag()
bool GPC_GetIRQStatusFlag ( GPC_Type base,
uint32_t  irqId
Parameters
Returns
Indicated IRQ/Event is asserted or not.
brief Get the IRQ/Event flag.
param base GPC peripheral base address. param irqId ID number of IRQ to be enabled, available range is 32-159. 0-31 is available in some platforms. return Indicated IRQ/Event is asserted or not.
◆ GPC_SP_ConfigSetPointTransitionStep()
void GPC_SP_ConfigSetPointTransitionStep ( GPC_SET_POINT_CTRL_Type base,
Parameters
baseGPC Setpoint controller base address.
stepstep type, refer to "gpc_sp_tran_step_t".
brief Config the set point transition step.
param base GPC Setpoint controller base address. param step step type, refer to "gpc_sp_tran_step_t". param config transition step configuration, refer to "gpc_tran_step_config_t".
◆ GPC_STBY_ConfigStandbyTransitionStep()
void GPC_STBY_ConfigStandbyTransitionStep ( GPC_STBY_CTRL_Type base,
Parameters
stepstep type, refer to "gpc_stby_tran_step_t".
brief Config the standby transition step.
param base GPC Setpoint controller base address. param step step type, refer to "gpc_stby_tran_step_t". param config transition step configuration, refer to "gpc_tran_step_config_t".
