RTEMS 6.1-rc5
Data Structures | Enumerator | Variables
Flexio_i2c_master
struct  _flexio_i2c_type
 Define FlexIO I2C master access structure typedef. More...
struct  _flexio_i2c_master_config
 Define FlexIO I2C master user configuration structure. More...
struct  _flexio_i2c_master_transfer
 Define FlexIO I2C master transfer structure. More...
struct  _flexio_i2c_master_handle
 Define FlexIO I2C master handle structure. More...
FLEXIO_Type_flexio_i2c_type::flexioBase
uint8_t _flexio_i2c_type::SDAPinIndex
uint8_t _flexio_i2c_type::SCLPinIndex
uint8_t _flexio_i2c_type::shifterIndex [2]
uint8_t _flexio_i2c_type::timerIndex [3]
uint32_t _flexio_i2c_type::baudrate
bool _flexio_i2c_master_config::enableMaster
bool _flexio_i2c_master_config::enableInDoze
bool _flexio_i2c_master_config::enableInDebug
bool _flexio_i2c_master_config::enableFastAccess
uint32_t _flexio_i2c_master_config::baudRate_Bps
uint32_t _flexio_i2c_master_transfer::flags
uint8_t _flexio_i2c_master_transfer::slaveAddress
flexio_i2c_direction_t _flexio_i2c_master_transfer::direction
uint32_t _flexio_i2c_master_transfer::subaddress
uint8_t _flexio_i2c_master_transfer::subaddressSize
uint8_t volatile * _flexio_i2c_master_transfer::data
volatile size_t _flexio_i2c_master_transfer::dataSize
flexio_i2c_master_transfer_t _flexio_i2c_master_handle::transfer
size_t _flexio_i2c_master_handle::transferSize
uint8_t _flexio_i2c_master_handle::state
flexio_i2c_master_transfer_callback_t _flexio_i2c_master_handle::completionCallback
void * _flexio_i2c_master_handle::userData
bool _flexio_i2c_master_handle::needRestart
Driver version
enum  { kStatus_FLEXIO_I2C_Busy = MAKE_STATUS(kStatusGroup_FLEXIO_I2C, 0) , kStatus_FLEXIO_I2C_Idle = MAKE_STATUS(kStatusGroup_FLEXIO_I2C, 1) , kStatus_FLEXIO_I2C_Nak = MAKE_STATUS(kStatusGroup_FLEXIO_I2C, 2) , kStatus_FLEXIO_I2C_Timeout = MAKE_STATUS(kStatusGroup_FLEXIO_I2C, 3) }
 FlexIO I2C transfer status. More...
enum  _flexio_i2c_master_interrupt { kFLEXIO_I2C_TxEmptyInterruptEnable = 0x1U , kFLEXIO_I2C_RxFullInterruptEnable = 0x2U }
 Define FlexIO I2C master interrupt mask. More...
enum  _flexio_i2c_master_status_flags { kFLEXIO_I2C_TxEmptyFlag = 0x1U , kFLEXIO_I2C_RxFullFlag = 0x2U , kFLEXIO_I2C_ReceiveNakFlag = 0x4U }
 Define FlexIO I2C master status mask. More...
enum  _flexio_i2c_direction { kFLEXIO_I2C_Write = 0x0U , kFLEXIO_I2C_Read = 0x1U }
 Direction of master transfer. More...
typedef enum _flexio_i2c_direction flexio_i2c_direction_t
typedef struct _flexio_i2c_type FLEXIO_I2C_Type
typedef struct _flexio_i2c_master_config flexio_i2c_master_config_t
typedef struct _flexio_i2c_master_transfer flexio_i2c_master_transfer_t
typedef struct _flexio_i2c_master_handle flexio_i2c_master_handle_t
 FlexIO I2C master handle typedef.
typedef void(* flexio_i2c_master_transfer_callback_t) (FLEXIO_I2C_Type *base, flexio_i2c_master_handle_t *handle, status_t status, void *userData)
 FlexIO I2C master transfer callback typedef.
#define FSL_FLEXIO_I2C_MASTER_DRIVER_VERSION   (MAKE_VERSION(2, 5, 0))
#define I2C_RETRY_TIMES   0U /* Define to zero means keep waiting until the flag is assert/deassert. */
 Retry times for waiting flag.
Initialization and deinitialization
status_t FLEXIO_I2C_MasterInit (FLEXIO_I2C_Type *base, flexio_i2c_master_config_t *masterConfig, uint32_t srcClock_Hz)
 Ungates the FlexIO clock, resets the FlexIO module, and configures the FlexIO I2C hardware configuration.
void FLEXIO_I2C_MasterDeinit (FLEXIO_I2C_Type *base)
 De-initializes the FlexIO I2C master peripheral. Calling this API Resets the FlexIO I2C master shifer and timer config, module can't work unless the FLEXIO_I2C_MasterInit is called.
void FLEXIO_I2C_MasterGetDefaultConfig (flexio_i2c_master_config_t *masterConfig)
 Gets the default configuration to configure the FlexIO module. The configuration can be used directly for calling the FLEXIO_I2C_MasterInit().
Status
uint32_t FLEXIO_I2C_MasterGetStatusFlags (FLEXIO_I2C_Type *base)
 Gets the FlexIO I2C master status flags.
void FLEXIO_I2C_MasterClearStatusFlags (FLEXIO_I2C_Type *base, uint32_t mask)
 Clears the FlexIO I2C master status flags.
Interrupts
void FLEXIO_I2C_MasterEnableInterrupts (FLEXIO_I2C_Type *base, uint32_t mask)
 Enables the FlexIO i2c master interrupt requests.
void FLEXIO_I2C_MasterDisableInterrupts (FLEXIO_I2C_Type *base, uint32_t mask)
 Disables the FlexIO I2C master interrupt requests.
Bus Operations
void FLEXIO_I2C_MasterSetBaudRate (FLEXIO_I2C_Type *base, uint32_t baudRate_Bps, uint32_t srcClock_Hz)
 Sets the FlexIO I2C master transfer baudrate.
void FLEXIO_I2C_MasterStart (FLEXIO_I2C_Type *base, uint8_t address, flexio_i2c_direction_t direction)
 Sends START + 7-bit address to the bus.
void FLEXIO_I2C_MasterStop (FLEXIO_I2C_Type *base)
 Sends the stop signal on the bus.
void FLEXIO_I2C_MasterRepeatedStart (FLEXIO_I2C_Type *base)
 Sends the repeated start signal on the bus.
void FLEXIO_I2C_MasterAbortStop (FLEXIO_I2C_Type *base)
 Sends the stop signal when transfer is still on-going.
void FLEXIO_I2C_MasterEnableAck (FLEXIO_I2C_Type *base, bool enable)
 Configures the sent ACK/NAK for the following byte.
status_t FLEXIO_I2C_MasterSetTransferCount (FLEXIO_I2C_Type *base, uint16_t count)
 Sets the number of bytes to be transferred from a start signal to a stop signal.
status_t FLEXIO_I2C_MasterWriteBlocking (FLEXIO_I2C_Type *base, const uint8_t *txBuff, uint8_t txSize)
 Sends a buffer of data in bytes.
status_t FLEXIO_I2C_MasterReadBlocking (FLEXIO_I2C_Type *base, uint8_t *rxBuff, uint8_t rxSize)
 Receives a buffer of bytes.
status_t FLEXIO_I2C_MasterTransferBlocking (FLEXIO_I2C_Type *base, flexio_i2c_master_transfer_t *xfer)
 Performs a master polling transfer on the I2C bus.
Transactional
status_t FLEXIO_I2C_MasterTransferCreateHandle (FLEXIO_I2C_Type *base, flexio_i2c_master_handle_t *handle, flexio_i2c_master_transfer_callback_t callback, void *userData)
 Initializes the I2C handle which is used in transactional functions.
status_t FLEXIO_I2C_MasterTransferNonBlocking (FLEXIO_I2C_Type *base, flexio_i2c_master_handle_t *handle, flexio_i2c_master_transfer_t *xfer)
 Performs a master interrupt non-blocking transfer on the I2C bus.
status_t FLEXIO_I2C_MasterTransferGetCount (FLEXIO_I2C_Type *base, flexio_i2c_master_handle_t *handle, size_t *count)
 Gets the master transfer status during a interrupt non-blocking transfer.
void FLEXIO_I2C_MasterTransferAbort (FLEXIO_I2C_Type *base, flexio_i2c_master_handle_t *handle)
 Aborts an interrupt non-blocking transfer early.
void FLEXIO_I2C_MasterTransferHandleIRQ (void *i2cType, void *i2cHandle)
 Master interrupt handler.
◆ anonymous enum
anonymous enum
I2C is busy doing transfer.
NAK received during transfer.
Timeout polling status flags.
◆ _flexio_i2c_direction
kFLEXIO_I2C_Write
Master send to slave.
kFLEXIO_I2C_Read
Master receive from slave.
◆ _flexio_i2c_master_interrupt
Tx buffer empty interrupt enable.
Rx buffer full interrupt enable.
◆ _flexio_i2c_master_status_flags
Tx shifter empty flag.
Rx shifter full/Transfer complete flag.
Receive NAK flag.
◆ FLEXIO_I2C_MasterAbortStop()
void FLEXIO_I2C_MasterAbortStop ( FLEXIO_I2C_Type base)
Parameters
basePointer to FLEXIO_I2C_Type structure.
brief Sends the stop signal when transfer is still on-going.
param base Pointer to FLEXIO_I2C_Type structure.
◆ FLEXIO_I2C_MasterClearStatusFlags()
void FLEXIO_I2C_MasterClearStatusFlags ( FLEXIO_I2C_Type base,
uint32_t  mask
Parameters
maskStatus flag. The parameter can be any combination of the following values:
  • kFLEXIO_I2C_RxFullFlag
  • kFLEXIO_I2C_ReceiveNakFlag
brief Clears the FlexIO I2C master status flags.
param base Pointer to FLEXIO_I2C_Type structure. param mask Status flag. The parameter can be any combination of the following values: arg kFLEXIO_I2C_RxFullFlag arg kFLEXIO_I2C_ReceiveNakFlag
◆ FLEXIO_I2C_MasterDeinit()
void FLEXIO_I2C_MasterDeinit ( FLEXIO_I2C_Type base)
Parameters
basepointer to FLEXIO_I2C_Type structure.
brief De-initializes the FlexIO I2C master peripheral. Calling this API Resets the FlexIO I2C master shifer and timer config, module can't work unless the FLEXIO_I2C_MasterInit is called.
param base pointer to FLEXIO_I2C_Type structure.
◆ FLEXIO_I2C_MasterDisableInterrupts()
void FLEXIO_I2C_MasterDisableInterrupts ( FLEXIO_I2C_Type base,
uint32_t  mask
Parameters
maskInterrupt source.
brief Disables the FlexIO I2C master interrupt requests.
param base Pointer to FLEXIO_I2C_Type structure. param mask Interrupt source.
◆ FLEXIO_I2C_MasterEnableAck()
void FLEXIO_I2C_MasterEnableAck ( FLEXIO_I2C_Type base,
bool  enable
Parameters
enableTrue to configure send ACK, false configure to send NAK.
brief Configures the sent ACK/NAK for the following byte.
param base Pointer to FLEXIO_I2C_Type structure. param enable True to configure send ACK, false configure to send NAK.
◆ FLEXIO_I2C_MasterEnableInterrupts()
void FLEXIO_I2C_MasterEnableInterrupts ( FLEXIO_I2C_Type base,
uint32_t  mask
Parameters
maskInterrupt source. Currently only one interrupt request source:
  • kFLEXIO_I2C_TransferCompleteInterruptEnable
brief Enables the FlexIO i2c master interrupt requests.
param base Pointer to FLEXIO_I2C_Type structure. param mask Interrupt source. Currently only one interrupt request source: arg kFLEXIO_I2C_TransferCompleteInterruptEnable
◆ FLEXIO_I2C_MasterGetDefaultConfig()
void FLEXIO_I2C_MasterGetDefaultConfig ( flexio_i2c_master_config_t masterConfig)
Example:
void FLEXIO_I2C_MasterGetDefaultConfig(flexio_i2c_master_config_t *masterConfig)
Gets the default configuration to configure the FlexIO module. The configuration can be used directly...
Definition: fsl_flexio_i2c_master.c:800
Definition: fsl_flexio_i2c_master.h:77
Definition: deflate.c:114
Parameters
masterConfigPointer to flexio_i2c_master_config_t structure.
brief Gets the default configuration to configure the FlexIO module. The configuration can be used directly for calling the FLEXIO_I2C_MasterInit().
Example: code flexio_i2c_master_config_t config; FLEXIO_I2C_MasterGetDefaultConfig(&config); endcode param masterConfig Pointer to flexio_i2c_master_config_t structure.
◆ FLEXIO_I2C_MasterGetStatusFlags()
uint32_t FLEXIO_I2C_MasterGetStatusFlags ( FLEXIO_I2C_Type base)
Parameters
Returns
Status flag, use status flag to AND _flexio_i2c_master_status_flags can get the related status.
brief Gets the FlexIO I2C master status flags.
param base Pointer to FLEXIO_I2C_Type structure return Status flag, use status flag to AND _flexio_i2c_master_status_flags can get the related status.
◆ FLEXIO_I2C_MasterInit()
status_t FLEXIO_I2C_MasterInit ( FLEXIO_I2C_Type base,
flexio_i2c_master_config_t masterConfig,
Example
.flexioBase = FLEXIO,
.SDAPinIndex = 0,
.SCLPinIndex = 1,
.shifterIndex = {0,1},
.timerIndex = {0,1}
.enableInDoze = false,
.enableInDebug = true,
.enableFastAccess = false,
.baudRate_Bps = 100000
FLEXIO_I2C_MasterInit(base, &config, srcClock_Hz);
status_t FLEXIO_I2C_MasterInit(FLEXIO_I2C_Type *base, flexio_i2c_master_config_t *masterConfig, uint32_t srcClock_Hz)
Ungates the FlexIO clock, resets the FlexIO module, and configures the FlexIO I2C hardware configurat...
Definition: fsl_flexio_i2c_master.c:630
Definition: fsl_flexio_i2c_master.h:66
Parameters
srcClock_HzFlexIO source clock in Hz.
Return values
kStatus_SuccessInitialization successful
kStatus_InvalidArgumentThe source clock exceed upper range limitation
brief Ungates the FlexIO clock, resets the FlexIO module, and configures the FlexIO I2C hardware configuration.
Example code FLEXIO_I2C_Type base = { .flexioBase = FLEXIO, .SDAPinIndex = 0, .SCLPinIndex = 1, .shifterIndex = {0,1}, .timerIndex = {0,1} }; flexio_i2c_master_config_t config = { .enableInDoze = false, .enableInDebug = true, .enableFastAccess = false, .baudRate_Bps = 100000 }; FLEXIO_I2C_MasterInit(base, &config, srcClock_Hz); endcode
param base Pointer to FLEXIO_I2C_Type structure. param masterConfig Pointer to flexio_i2c_master_config_t structure. param srcClock_Hz FlexIO source clock in Hz. retval kStatus_Success Initialization successful retval kStatus_InvalidArgument The source clock exceed upper range limitation
◆ FLEXIO_I2C_MasterReadBlocking()
status_t FLEXIO_I2C_MasterReadBlocking ( FLEXIO_I2C_Type base,
uint8_t *  rxBuff,
uint8_t  rxSize
Note
This function blocks via polling until all bytes have been received.
Parameters
rxBuffThe buffer to store the received bytes.
rxSizeThe number of data bytes to be received.
Return values
kStatus_SuccessSuccessfully read data.
kStatus_FLEXIO_I2C_TimeoutTimeout polling status flags.
brief Receives a buffer of bytes.
note This function blocks via polling until all bytes have been received.
param base Pointer to FLEXIO_I2C_Type structure. param rxBuff The buffer to store the received bytes. param rxSize The number of data bytes to be received. retval kStatus_Success Successfully read data. retval kStatus_FLEXIO_I2C_Timeout Timeout polling status flags.
◆ FLEXIO_I2C_MasterRepeatedStart()
void FLEXIO_I2C_MasterRepeatedStart ( FLEXIO_I2C_Type base)
Parameters
brief Sends the repeated start signal on the bus.
◆ FLEXIO_I2C_MasterSetBaudRate()
void FLEXIO_I2C_MasterSetBaudRate ( FLEXIO_I2C_Type base,
Parameters
baudRate_Bpsthe baud rate value in HZ
srcClock_Hzsource clock in HZ
brief Sets the FlexIO I2C master transfer baudrate.
param base Pointer to FLEXIO_I2C_Type structure param baudRate_Bps the baud rate value in HZ param srcClock_Hz source clock in HZ
◆ FLEXIO_I2C_MasterSetTransferCount()
status_t FLEXIO_I2C_MasterSetTransferCount ( FLEXIO_I2C_Type base,
uint16_t  count
Note
Call this API before a transfer begins because the timer generates a number of clocks according to the number of bytes that need to be transferred.
Parameters
countNumber of bytes need to be transferred from a start signal to a re-start/stop signal
Return values
kStatus_SuccessSuccessfully configured the count.
kStatus_InvalidArgumentInput argument is invalid.
brief Sets the number of bytes to be transferred from a start signal to a stop signal.
note Call this API before a transfer begins because the timer generates a number of clocks according to the number of bytes that need to be transferred.
param base Pointer to FLEXIO_I2C_Type structure. param count Number of bytes need to be transferred from a start signal to a re-start/stop signal retval kStatus_Success Successfully configured the count. retval kStatus_InvalidArgument Input argument is invalid.
◆ FLEXIO_I2C_MasterStart()
void FLEXIO_I2C_MasterStart ( FLEXIO_I2C_Type base,
uint8_t  address,
Note
This API should be called when the transfer configuration is ready to send a START signal and 7-bit address to the bus. This is a non-blocking API, which returns directly after the address is put into the data register but the address transfer is not finished on the bus. Ensure that the kFLEXIO_I2C_RxFullFlag status is asserted before calling this API.
Parameters
address7-bit address.
directiontransfer direction. This parameter is one of the values in flexio_i2c_direction_t:
  • kFLEXIO_I2C_Write: Transmit
  • kFLEXIO_I2C_Read: Receive
brief Sends START + 7-bit address to the bus.
note This API should be called when the transfer configuration is ready to send a START signal and 7-bit address to the bus. This is a non-blocking API, which returns directly after the address is put into the data register but the address transfer is not finished on the bus. Ensure that the kFLEXIO_I2C_RxFullFlag status is asserted before calling this API. param base Pointer to FLEXIO_I2C_Type structure. param address 7-bit address. param direction transfer direction. This parameter is one of the values in flexio_i2c_direction_t: arg kFLEXIO_I2C_Write: Transmit arg kFLEXIO_I2C_Read: Receive
◆ FLEXIO_I2C_MasterStop()
void FLEXIO_I2C_MasterStop ( FLEXIO_I2C_Type base)
Parameters
brief Sends the stop signal on the bus.
◆ FLEXIO_I2C_MasterTransferAbort()
void FLEXIO_I2C_MasterTransferAbort ( FLEXIO_I2C_Type base,
flexio_i2c_master_handle_t handle
Note
This API can be called at any time when an interrupt non-blocking transfer initiates to abort the transfer early.
Parameters
handlePointer to flexio_i2c_master_handle_t structure which stores the transfer state
brief Aborts an interrupt non-blocking transfer early.
note This API can be called at any time when an interrupt non-blocking transfer initiates to abort the transfer early.
param base Pointer to FLEXIO_I2C_Type structure param handle Pointer to flexio_i2c_master_handle_t structure which stores the transfer state
◆ FLEXIO_I2C_MasterTransferBlocking()
status_t FLEXIO_I2C_MasterTransferBlocking ( FLEXIO_I2C_Type base,
flexio_i2c_master_transfer_t xfer
Note
The API does not return until the transfer succeeds or fails due to receiving NAK.
Parameters
xferpointer to flexio_i2c_master_transfer_t structure.
Returns
status of status_t.
brief Performs a master polling transfer on the I2C bus.
note The API does not return until the transfer succeeds or fails due to receiving NAK.
param base pointer to FLEXIO_I2C_Type structure. param xfer pointer to flexio_i2c_master_transfer_t structure. return status of status_t.
◆ FLEXIO_I2C_MasterTransferCreateHandle()
status_t FLEXIO_I2C_MasterTransferCreateHandle ( FLEXIO_I2C_Type base,
flexio_i2c_master_handle_t handle,
void *  userData
Parameters
handlePointer to flexio_i2c_master_handle_t structure to store the transfer state.
callbackPointer to user callback function.
userDataUser param passed to the callback function.
Return values
kStatus_SuccessSuccessfully create the handle.
kStatus_OutOfRangeThe FlexIO type/handle/isr table out of range.
brief Initializes the I2C handle which is used in transactional functions.
param base Pointer to FLEXIO_I2C_Type structure. param handle Pointer to flexio_i2c_master_handle_t structure to store the transfer state. param callback Pointer to user callback function. param userData User param passed to the callback function. retval kStatus_Success Successfully create the handle. retval kStatus_OutOfRange The FlexIO type/handle/isr table out of range.
◆ FLEXIO_I2C_MasterTransferGetCount()
status_t FLEXIO_I2C_MasterTransferGetCount ( FLEXIO_I2C_Type base,
size_t *  count
Parameters
handlePointer to flexio_i2c_master_handle_t structure which stores the transfer state.
countNumber of bytes transferred so far by the non-blocking transaction.
Return values
kStatus_InvalidArgumentcount is Invalid.
kStatus_NoTransferInProgressThere is not a non-blocking transaction currently in progress.
kStatus_SuccessSuccessfully return the count.
brief Gets the master transfer status during a interrupt non-blocking transfer.
param base Pointer to FLEXIO_I2C_Type structure. param handle Pointer to flexio_i2c_master_handle_t structure which stores the transfer state. param count Number of bytes transferred so far by the non-blocking transaction. retval kStatus_InvalidArgument count is Invalid. retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress. retval kStatus_Success Successfully return the count.
◆ FLEXIO_I2C_MasterTransferHandleIRQ()
void FLEXIO_I2C_MasterTransferHandleIRQ ( void *  i2cType,
void *  i2cHandle
Parameters
i2cTypePointer to FLEXIO_I2C_Type structure
i2cHandlePointer to flexio_i2c_master_transfer_t structure
brief Master interrupt handler.
param i2cType Pointer to FLEXIO_I2C_Type structure param i2cHandle Pointer to flexio_i2c_master_transfer_t structure
◆ FLEXIO_I2C_MasterTransferNonBlocking()
status_t FLEXIO_I2C_MasterTransferNonBlocking ( FLEXIO_I2C_Type base,
Note
The API returns immediately after the transfer initiates. Call FLEXIO_I2C_MasterTransferGetCount to poll the transfer status to check whether the transfer is finished. If the return status is not kStatus_FLEXIO_I2C_Busy, the transfer is finished.
Parameters
Return values
kStatus_SuccessSuccessfully start a transfer.
kStatus_FLEXIO_I2C_BusyFlexIO I2C is not idle, is running another transfer.
brief Performs a master interrupt non-blocking transfer on the I2C bus.
note The API returns immediately after the transfer initiates. Call FLEXIO_I2C_MasterTransferGetCount to poll the transfer status to check whether the transfer is finished. If the return status is not kStatus_FLEXIO_I2C_Busy, the transfer is finished.
param base Pointer to FLEXIO_I2C_Type structure param handle Pointer to flexio_i2c_master_handle_t structure which stores the transfer state param xfer pointer to flexio_i2c_master_transfer_t structure retval kStatus_Success Successfully start a transfer. retval kStatus_FLEXIO_I2C_Busy FlexIO I2C is not idle, is running another transfer.
◆ FLEXIO_I2C_MasterWriteBlocking()
status_t FLEXIO_I2C_MasterWriteBlocking ( FLEXIO_I2C_Type base,
const uint8_t *  txBuff,
uint8_t  txSize
Note
This function blocks via polling until all bytes have been sent.
Parameters
txBuffThe data bytes to send.
txSizeThe number of data bytes to send.
Return values
kStatus_SuccessSuccessfully write data.
kStatus_FLEXIO_I2C_NakReceive NAK during writing data.
brief Sends a buffer of data in bytes.
note This function blocks via polling until all bytes have been sent.
param base Pointer to FLEXIO_I2C_Type structure. param txBuff The data bytes to send. param txSize The number of data bytes to send. retval kStatus_Success Successfully write data. retval kStatus_FLEXIO_I2C_Nak Receive NAK during writing data. retval kStatus_FLEXIO_I2C_Timeout Timeout polling status flags.
Variable Documentation
◆ baudrate
Master transfer baudrate, used to calculate delay time.
◆ baudRate_Bps
Baud rate in Bps.
◆ completionCallback
Callback function called at transfer event. Callback function called at transfer event.
◆ data
uint8_t volatile* _flexio_i2c_master_transfer::data
Transfer buffer.
◆ dataSize
Transfer size.
◆ direction
Transfer direction, read or write.
◆ enableFastAccess
Enable/disable fast access to FlexIO registers, fast access requires the FlexIO clock to be at least twice the frequency of the bus clock.
◆ enableInDebug
Enable/disable FlexIO operation in debug mode.
◆ enableInDoze
Enable/disable FlexIO operation in doze mode.
◆ enableMaster
Enables the FlexIO I2C peripheral at initialization time.
◆ flags
Transfer flag which controls the transfer, reserved for FlexIO I2C.
◆ flexioBase
FLEXIO_Type* _flexio_i2c_type::flexioBase
FlexIO base pointer.
◆ needRestart
Whether master needs to send re-start signal.
◆ SCLPinIndex
Pin select for I2C SCL.
◆ SDAPinIndex
Pin select for I2C SDA.
◆ shifterIndex
uint8_t _flexio_i2c_type::shifterIndex[2]
Shifter index used in FlexIO I2C.
◆ slaveAddress
7-bit slave address.
◆ state
Transfer state maintained during transfer.
◆ subaddress
Sub address. Transferred MSB first.
◆ subaddressSize
Size of command buffer.
◆ timerIndex
uint8_t _flexio_i2c_type::timerIndex[3]
Timer index used in FlexIO I2C.
◆ transfer
FlexIO I2C master transfer copy.
◆ transferSize
Total bytes to be transferred.
◆ userData
void* _flexio_i2c_master_handle::userData
Callback parameter passed to callback function.
