RTEMS 6.1-rc5
struct | _flexio_spi_master_dma_handle |
FlexIO SPI DMA transfer handle, users should not touch the content of the handle. More... | |
Driver version | |
typedef struct _flexio_spi_master_dma_handle | flexio_spi_master_dma_handle_t |
typedef for flexio_spi_master_dma_handle_t in advance. | |
typedef flexio_spi_master_dma_handle_t | flexio_spi_slave_dma_handle_t |
Slave handle is the same with master handle. | |
typedef void(* | flexio_spi_master_dma_transfer_callback_t) (FLEXIO_SPI_Type *base, flexio_spi_master_dma_handle_t *handle, status_t status, void *userData) |
FlexIO SPI master callback for finished transmit. | |
typedef void(* | flexio_spi_slave_dma_transfer_callback_t) (FLEXIO_SPI_Type *base, flexio_spi_slave_dma_handle_t *handle, status_t status, void *userData) |
FlexIO SPI slave callback for finished transmit. | |
#define | FSL_FLEXIO_SPI_DMA_DRIVER_VERSION (MAKE_VERSION(2, 3, 0)) |
FlexIO SPI DMA driver version 2.3.0. | |
DMA Transactional | |
status_t | FLEXIO_SPI_MasterTransferCreateHandleDMA (FLEXIO_SPI_Type *base, flexio_spi_master_dma_handle_t *handle, flexio_spi_master_dma_transfer_callback_t callback, void *userData, dma_handle_t *txHandle, dma_handle_t *rxHandle) |
Initializes the FLEXO SPI master DMA handle. | |
status_t | FLEXIO_SPI_MasterTransferDMA (FLEXIO_SPI_Type *base, flexio_spi_master_dma_handle_t *handle, flexio_spi_transfer_t *xfer) |
Performs a non-blocking FlexIO SPI transfer using DMA. | |
void | FLEXIO_SPI_MasterTransferAbortDMA (FLEXIO_SPI_Type *base, flexio_spi_master_dma_handle_t *handle) |
Aborts a FlexIO SPI transfer using DMA. | |
status_t | FLEXIO_SPI_MasterTransferGetCountDMA (FLEXIO_SPI_Type *base, flexio_spi_master_dma_handle_t *handle, size_t *count) |
Gets the remaining bytes for FlexIO SPI DMA transfer. | |
status_t | FLEXIO_SPI_SlaveTransferDMA (FLEXIO_SPI_Type *base, flexio_spi_slave_dma_handle_t *handle, flexio_spi_transfer_t *xfer) |
void FLEXIO_SPI_MasterTransferAbortDMA | ( | FLEXIO_SPI_Type * | base, |
flexio_spi_master_dma_handle_t * | handle | ||
base | Pointer to FLEXIO_SPI_Type structure. |
handle | FlexIO SPI DMA handle pointer. |
status_t FLEXIO_SPI_MasterTransferCreateHandleDMA | ( | FLEXIO_SPI_Type * | base, |
flexio_spi_master_dma_handle_t * | handle, | ||
flexio_spi_master_dma_transfer_callback_t | callback, | ||
void * | userData, | ||
dma_handle_t * | txHandle, | ||
dma_handle_t * | rxHandle | ||
This function initializes the FLEXO SPI master DMA handle which can be used for other FLEXO SPI master transactional APIs. Usually, for a specified FLEXO SPI instance, call this API once to get the initialized handle.
handle | Pointer to flexio_spi_master_dma_handle_t structure to store the transfer state. |
callback | SPI callback, NULL means no callback. |
userData | callback function parameter. |
txHandle | User requested DMA handle for FlexIO SPI RX DMA transfer. |
rxHandle | User requested DMA handle for FlexIO SPI TX DMA transfer. |
kStatus_Success | Successfully create the handle. |
kStatus_OutOfRange | The FlexIO SPI DMA type/handle table out of range. |
status_t FLEXIO_SPI_MasterTransferDMA | ( | FLEXIO_SPI_Type * | base, |
flexio_spi_transfer_t * | xfer | ||
xfer | Pointer to FlexIO SPI transfer structure. |
kStatus_Success | Successfully start a transfer. |
kStatus_InvalidArgument | Input argument is invalid. |
kStatus_FLEXIO_SPI_Busy | FlexIO SPI is not idle, is running another transfer. |
status_t FLEXIO_SPI_MasterTransferGetCountDMA | ( | FLEXIO_SPI_Type * | base, |
size_t * | count | ||
count | Number of bytes transferred so far by the non-blocking transaction. |
status_t FLEXIO_SPI_SlaveTransferDMA | ( | FLEXIO_SPI_Type * | base, |
flexio_spi_slave_dma_handle_t * | handle, | ||
handle | Pointer to flexio_spi_slave_dma_handle_t structure to store the transfer state. |
