RTEMS 6.1-rc5
Data Structures | Enumerator | Variables
Flexio_camera
struct  _flexio_camera_type
 Define structure of configuring the FlexIO Camera device. More...
struct  _flexio_camera_config
 Define FlexIO Camera user configuration structure. More...
struct  _flexio_camera_transfer
 Define FlexIO Camera transfer structure. More...
FLEXIO_Type_flexio_camera_type::flexioBase
uint32_t _flexio_camera_type::datPinStartIdx
uint32_t _flexio_camera_type::pclkPinIdx
uint32_t _flexio_camera_type::hrefPinIdx
uint32_t _flexio_camera_type::shifterStartIdx
uint32_t _flexio_camera_type::shifterCount
uint32_t _flexio_camera_type::timerIdx
bool _flexio_camera_config::enablecamera
bool _flexio_camera_config::enableInDoze
bool _flexio_camera_config::enableInDebug
bool _flexio_camera_config::enableFastAccess
uint32_t _flexio_camera_transfer::dataAddress
uint32_t _flexio_camera_transfer::dataNum
Driver version
enum  { kStatus_FLEXIO_CAMERA_RxBusy = MAKE_STATUS(kStatusGroup_FLEXIO_CAMERA, 0) , kStatus_FLEXIO_CAMERA_RxIdle = MAKE_STATUS(kStatusGroup_FLEXIO_CAMERA, 1) }
 Error codes for the Camera driver. More...
enum  _flexio_camera_status_flags { kFLEXIO_CAMERA_RxDataRegFullFlag = 0x1U , kFLEXIO_CAMERA_RxErrorFlag = 0x2U }
 Define FlexIO Camera status mask. More...
typedef struct _flexio_camera_type FLEXIO_CAMERA_Type
typedef struct _flexio_camera_config flexio_camera_config_t
typedef struct _flexio_camera_transfer flexio_camera_transfer_t
#define FSL_FLEXIO_CAMERA_DRIVER_VERSION   (MAKE_VERSION(2, 1, 3))
 FlexIO Camera driver version 2.1.3.
#define FLEXIO_CAMERA_PARALLEL_DATA_WIDTH   (8U)
 Define the Camera CPI interface is constantly 8-bit width.
Initialization and configuration
void FLEXIO_CAMERA_Init (FLEXIO_CAMERA_Type *base, const flexio_camera_config_t *config)
 Ungates the FlexIO clock, resets the FlexIO module, and configures the FlexIO Camera.
void FLEXIO_CAMERA_Deinit (FLEXIO_CAMERA_Type *base)
 Resets the FLEXIO_CAMERA shifer and timer config.
void FLEXIO_CAMERA_GetDefaultConfig (flexio_camera_config_t *config)
 Gets the default configuration to configure the FlexIO Camera. The configuration can be used directly for calling the FLEXIO_CAMERA_Init(). Example:
Status
uint32_t FLEXIO_CAMERA_GetStatusFlags (FLEXIO_CAMERA_Type *base)
 Gets the FlexIO Camera status flags.
void FLEXIO_CAMERA_ClearStatusFlags (FLEXIO_CAMERA_Type *base, uint32_t mask)
 Clears the receive buffer full flag manually.
Interrupts
void FLEXIO_CAMERA_EnableInterrupt (FLEXIO_CAMERA_Type *base)
 Switches on the interrupt for receive buffer full event.
void FLEXIO_CAMERA_DisableInterrupt (FLEXIO_CAMERA_Type *base)
 Switches off the interrupt for receive buffer full event.
◆ anonymous enum
anonymous enum
Receiver is busy.
Camera receiver is idle.
◆ _flexio_camera_status_flags
Receive buffer full flag.
Receive buffer error flag.
◆ FLEXIO_CAMERA_ClearStatusFlags()
void FLEXIO_CAMERA_ClearStatusFlags ( FLEXIO_CAMERA_Type base,
uint32_t  mask
Parameters
basePointer to the device.
maskstatus flag The parameter can be any combination of the following values:
  • kFLEXIO_CAMERA_RxDataRegFullFlag
  • kFLEXIO_CAMERA_RxErrorFlag
◆ FLEXIO_CAMERA_Deinit()
void FLEXIO_CAMERA_Deinit ( FLEXIO_CAMERA_Type base)
Note
After calling this API, call FLEXO_CAMERA_Init to use the FlexIO Camera module.
Parameters
basePointer to FLEXIO_CAMERA_Type structure
◆ FLEXIO_CAMERA_DisableInterrupt()
void FLEXIO_CAMERA_DisableInterrupt ( FLEXIO_CAMERA_Type base)
Parameters
◆ FLEXIO_CAMERA_EnableInterrupt()
void FLEXIO_CAMERA_EnableInterrupt ( FLEXIO_CAMERA_Type base)
Parameters
◆ FLEXIO_CAMERA_GetDefaultConfig()
void FLEXIO_CAMERA_GetDefaultConfig ( flexio_camera_config_t config)
void FLEXIO_CAMERA_GetDefaultConfig(flexio_camera_config_t *config)
Gets the default configuration to configure the FlexIO Camera. The configuration can be used directly...
Definition: fsl_flexio_camera.h:65
Definition: deflate.c:114
Parameters
configPointer to the flexio_camera_config_t structure
◆ FLEXIO_CAMERA_GetStatusFlags()
uint32_t FLEXIO_CAMERA_GetStatusFlags ( FLEXIO_CAMERA_Type base)
Parameters
Returns
FlexIO shifter status flags
  • FLEXIO_SHIFTSTAT_SSF_MASK
  • 0
◆ FLEXIO_CAMERA_Init()
void FLEXIO_CAMERA_Init ( FLEXIO_CAMERA_Type base,
const flexio_camera_config_t config
Parameters
configPointer to flexio_camera_config_t structure
Variable Documentation
◆ dataAddress
Transfer buffer
◆ dataNum
Transfer num
◆ datPinStartIdx
First data pin (D0) index for flexio_camera. Then the successive following FLEXIO_CAMERA_DATA_WIDTH-1 pins are used as D1-D7.
◆ enablecamera
Enable/disable FlexIO Camera TX & RX.
◆ enableFastAccess
Enable/disable fast access to FlexIO registers, fast access requires the FlexIO clock to be at least twice the frequency of the bus clock.
◆ enableInDebug
Enable/disable FlexIO operation in debug mode
◆ enableInDoze
Enable/disable FlexIO operation in doze mode
◆ flexioBase
FLEXIO_Type* _flexio_camera_type::flexioBase
FlexIO module base address.
◆ hrefPinIdx
Horizontal sync pin (HREF) index for flexio_camera.
◆ pclkPinIdx
Pixel clock pin (PCLK) index for flexio_camera.
◆ shifterCount
The count of shifters that are used as flexio_camera data FIFO.
◆ shifterStartIdx
First shifter index used for flexio_camera data FIFO.
◆ timerIdx
Timer index used for flexio_camera in FlexIO.
