RTEMS 6.1-rc5
Data Structures | Enumerator | Variables
Enet
struct  _enet_rx_bd_struct
 Defines the receive buffer descriptor structure for the little endian system. More...
struct  _enet_tx_bd_struct
 Defines the enhanced transmit buffer descriptor structure for the little endian system. More...
struct  _enet_data_error_stats
 Defines the ENET data error statistics structure. More...
struct  _enet_rx_frame_error
 Defines the Rx frame error structure. More...
struct  _enet_transfer_stats
 Defines the ENET transfer statistics structure. More...
struct  enet_frame_info
 Defines the frame info structure. More...
struct  _enet_tx_dirty_ring
 Defines the ENET transmit dirty addresses ring/queue structure. More...
struct  _enet_buffer_config
 Defines the receive buffer descriptor configuration structure. More...
struct  _enet_config
 Defines the basic configuration structure for the ENET device. More...
struct  _enet_tx_bd_ring
 Defines the ENET transmit buffer descriptor ring/queue structure. More...
struct  _enet_rx_bd_ring
 Defines the ENET receive buffer descriptor ring/queue structure. More...
struct  _enet_handle
 Defines the ENET handler structure. More...
struct  _enet_buffer_struct
struct  _enet_rx_frame_attribute_struct
struct  _enet_rx_frame_struct
struct  _enet_tx_frame_struct
uint16_t _enet_rx_bd_struct::length
uint16_t _enet_rx_bd_struct::control
uint32_t _enet_rx_bd_struct::buffer
uint16_t _enet_tx_bd_struct::length
uint16_t _enet_tx_bd_struct::control
uint32_t _enet_tx_bd_struct::buffer
uint32_t _enet_data_error_stats::statsRxLenGreaterErr
uint32_t _enet_data_error_stats::statsRxAlignErr
uint32_t _enet_data_error_stats::statsRxFcsErr
uint32_t _enet_data_error_stats::statsRxOverRunErr
uint32_t _enet_data_error_stats::statsRxTruncateErr
bool _enet_rx_frame_error::statsRxTruncateErr: 1
bool _enet_rx_frame_error::statsRxOverRunErr: 1
bool _enet_rx_frame_error::statsRxFcsErr: 1
bool _enet_rx_frame_error::__pad0__: 1
bool _enet_rx_frame_error::statsRxAlignErr: 1
bool _enet_rx_frame_error::statsRxLenGreaterErr: 1
uint32_t _enet_rx_frame_error::__pad1__: 19
uint32_t _enet_transfer_stats::statsRxFrameCount
uint32_t _enet_transfer_stats::statsRxFrameOk
uint32_t _enet_transfer_stats::statsRxCrcErr
uint32_t _enet_transfer_stats::statsRxAlignErr
uint32_t _enet_transfer_stats::statsRxDropInvalidSFD
uint32_t _enet_transfer_stats::statsRxFifoOverflowErr
uint32_t _enet_transfer_stats::statsTxFrameCount
uint32_t _enet_transfer_stats::statsTxFrameOk
uint32_t _enet_transfer_stats::statsTxCrcAlignErr
uint32_t _enet_transfer_stats::statsTxFifoUnderRunErr
void * enet_frame_info::context
enet_frame_info_t_enet_tx_dirty_ring::txDirtyBase
uint16_t _enet_tx_dirty_ring::txGenIdx
uint16_t _enet_tx_dirty_ring::txConsumIdx
uint16_t _enet_tx_dirty_ring::txRingLen
bool _enet_tx_dirty_ring::isFull
uint16_t _enet_buffer_config::rxBdNumber
uint16_t _enet_buffer_config::txBdNumber
uint16_t _enet_buffer_config::rxBuffSizeAlign
uint16_t _enet_buffer_config::txBuffSizeAlign
volatile enet_rx_bd_struct_t_enet_buffer_config::rxBdStartAddrAlign
volatile enet_tx_bd_struct_t_enet_buffer_config::txBdStartAddrAlign
uint8_t * _enet_buffer_config::rxBufferAlign
uint8_t * _enet_buffer_config::txBufferAlign
bool _enet_buffer_config::rxMaintainEnable
bool _enet_buffer_config::txMaintainEnable
enet_frame_info_t_enet_buffer_config::txFrameInfo
uint32_t _enet_config::macSpecialConfig
uint32_t _enet_config::interrupt
uint16_t _enet_config::rxMaxFrameLen
enet_mii_mode_t _enet_config::miiMode
enet_mii_speed_t _enet_config::miiSpeed
enet_mii_duplex_t _enet_config::miiDuplex
uint8_t _enet_config::rxAccelerConfig
uint8_t _enet_config::txAccelerConfig
uint16_t _enet_config::pauseDuration
uint8_t _enet_config::rxFifoEmptyThreshold
uint8_t _enet_config::rxFifoFullThreshold
uint8_t _enet_config::txFifoWatermark
uint8_t _enet_config::ringNum
enet_rx_alloc_callback_t _enet_config::rxBuffAlloc
enet_rx_free_callback_t _enet_config::rxBuffFree
enet_callback_t _enet_config::callback
void * _enet_config::userData
volatile enet_tx_bd_struct_t_enet_tx_bd_ring::txBdBase
uint16_t _enet_tx_bd_ring::txGenIdx
uint16_t _enet_tx_bd_ring::txConsumIdx
volatile uint16_t _enet_tx_bd_ring::txDescUsed
uint16_t _enet_tx_bd_ring::txRingLen
volatile enet_rx_bd_struct_t_enet_rx_bd_ring::rxBdBase
uint16_t _enet_rx_bd_ring::rxGenIdx
uint16_t _enet_rx_bd_ring::rxRingLen
enet_rx_bd_ring_t _enet_handle::rxBdRing [FSL_FEATURE_ENET_QUEUE]
enet_tx_bd_ring_t _enet_handle::txBdRing [FSL_FEATURE_ENET_QUEUE]
uint16_t _enet_handle::rxBuffSizeAlign [FSL_FEATURE_ENET_QUEUE]
uint16_t _enet_handle::txBuffSizeAlign [FSL_FEATURE_ENET_QUEUE]
bool _enet_handle::rxMaintainEnable [FSL_FEATURE_ENET_QUEUE]
bool _enet_handle::txMaintainEnable [FSL_FEATURE_ENET_QUEUE]
uint8_t _enet_handle::ringNum
enet_callback_t _enet_handle::callback
void * _enet_handle::userData
enet_tx_dirty_ring_t _enet_handle::txDirtyRing [FSL_FEATURE_ENET_QUEUE]
bool _enet_handle::txReclaimEnable [FSL_FEATURE_ENET_QUEUE]
enet_rx_alloc_callback_t _enet_handle::rxBuffAlloc
enet_rx_free_callback_t _enet_handle::rxBuffFree
uint8_t _enet_handle::multicastCount [64]
void * _enet_buffer_struct::buffer
uint16_t _enet_buffer_struct::length
bool _enet_rx_frame_attribute_struct::promiscuous
enet_buffer_struct_t_enet_rx_frame_struct::rxBuffArray
uint16_t _enet_rx_frame_struct::totLen
enet_rx_frame_attribute_t _enet_rx_frame_struct::rxAttribute
enet_rx_frame_error_t _enet_rx_frame_struct::rxFrameError
enet_buffer_struct_t_enet_tx_frame_struct::txBuffArray
uint32_t _enet_tx_frame_struct::txBuffNum
void * _enet_tx_frame_struct::context
Defines some Ethernet parameters.
enum  {
  kStatus_ENET_InitMemoryFail , kStatus_ENET_RxFrameError = MAKE_STATUS(kStatusGroup_ENET, 1U) , kStatus_ENET_RxFrameFail = MAKE_STATUS(kStatusGroup_ENET, 2U) , kStatus_ENET_RxFrameEmpty = MAKE_STATUS(kStatusGroup_ENET, 3U) ,
  kStatus_ENET_RxFrameDrop = MAKE_STATUS(kStatusGroup_ENET, 4U) , kStatus_ENET_TxFrameOverLen = MAKE_STATUS(kStatusGroup_ENET, 5U) , kStatus_ENET_TxFrameBusy = MAKE_STATUS(kStatusGroup_ENET, 6U) , kStatus_ENET_TxFrameFail = MAKE_STATUS(kStatusGroup_ENET, 7U)
 Defines the status return codes for transaction. More...
enum  _enet_mii_mode { kENET_MiiMode = 0U , kENET_RmiiMode = 1U }
 Defines the MII/RMII/RGMII mode for data interface between the MAC and the PHY. More...
enum  _enet_mii_speed { kENET_MiiSpeed10M = 0U , kENET_MiiSpeed100M = 1U }
 Defines the 10/100/1000 Mbps speed for the MII data interface. More...
enum  _enet_mii_duplex { kENET_MiiHalfDuplex = 0U , kENET_MiiFullDuplex }
 Defines the half or full duplex for the MII data interface. More...
enum  _enet_mii_write { kENET_MiiWriteNoCompliant = 0U , kENET_MiiWriteValidFrame }
 Define the MII opcode for normal MDIO_CLAUSES_22 Frame. More...
enum  _enet_mii_read { kENET_MiiReadValidFrame = 2U , kENET_MiiReadNoCompliant = 3U }
 Defines the read operation for the MII management frame. More...
enum  _enet_special_control_flag {
  kENET_ControlFlowControlEnable = 0x0001U , kENET_ControlRxPayloadCheckEnable = 0x0002U , kENET_ControlRxPadRemoveEnable = 0x0004U , kENET_ControlRxBroadCastRejectEnable = 0x0008U ,
  kENET_ControlMacAddrInsert = 0x0010U , kENET_ControlStoreAndFwdDisable = 0x0020U , kENET_ControlSMIPreambleDisable = 0x0040U , kENET_ControlPromiscuousEnable = 0x0080U ,
  kENET_ControlMIILoopEnable = 0x0100U , kENET_ControlVLANTagEnable = 0x0200U
 Defines a special configuration for ENET MAC controller. More...
enum  _enet_interrupt_enable {
  kENET_BabrInterrupt = ENET_EIR_BABR_MASK , kENET_BabtInterrupt = ENET_EIR_BABT_MASK , kENET_GraceStopInterrupt = ENET_EIR_GRA_MASK , kENET_TxFrameInterrupt = ENET_EIR_TXF_MASK ,
  kENET_TxBufferInterrupt = ENET_EIR_TXB_MASK , kENET_RxFrameInterrupt = ENET_EIR_RXF_MASK , kENET_RxBufferInterrupt = ENET_EIR_RXB_MASK , kENET_MiiInterrupt = ENET_EIR_MII_MASK ,
  kENET_EBusERInterrupt = ENET_EIR_EBERR_MASK , kENET_LateCollisionInterrupt = ENET_EIR_LC_MASK , kENET_RetryLimitInterrupt = ENET_EIR_RL_MASK , kENET_UnderrunInterrupt = ENET_EIR_UN_MASK ,
  kENET_PayloadRxInterrupt = ENET_EIR_PLR_MASK , kENET_WakeupInterrupt = ENET_EIR_WAKEUP_MASK , kENET_TsAvailInterrupt = ENET_EIR_TS_AVAIL_MASK , kENET_TsTimerInterrupt = ENET_EIR_TS_TIMER_MASK
 List of interrupts supported by the peripheral. This enumeration uses one-bit encoding to allow a logical OR of multiple members. Members usually map to interrupt enable bits in one or more peripheral registers. More...
enum  _enet_event {
  kENET_RxEvent , kENET_TxEvent , kENET_ErrEvent , kENET_WakeUpEvent ,
  kENET_TimeStampEvent , kENET_TimeStampAvailEvent
 Defines the common interrupt event for callback use. More...
enum  _enet_tx_accelerator { kENET_TxAccelIsShift16Enabled = ENET_TACC_SHIFT16_MASK , kENET_TxAccelIpCheckEnabled = ENET_TACC_IPCHK_MASK , kENET_TxAccelProtoCheckEnabled = ENET_TACC_PROCHK_MASK }
 Defines the transmit accelerator configuration. More...
enum  _enet_rx_accelerator {
  kENET_RxAccelPadRemoveEnabled = ENET_RACC_PADREM_MASK , kENET_RxAccelIpCheckEnabled = ENET_RACC_IPDIS_MASK , kENET_RxAccelProtoCheckEnabled = ENET_RACC_PRODIS_MASK , kENET_RxAccelMacCheckEnabled = ENET_RACC_LINEDIS_MASK ,
  kENET_RxAccelisShift16Enabled = ENET_RACC_SHIFT16_MASK
 Defines the receive accelerator configuration. More...
typedef enum _enet_mii_mode enet_mii_mode_t
typedef enum _enet_mii_speed enet_mii_speed_t
typedef enum _enet_mii_duplex enet_mii_duplex_t
typedef enum _enet_mii_write enet_mii_write_t
typedef enum _enet_mii_read enet_mii_read_t
typedef enum _enet_special_control_flag enet_special_control_flag_t
typedef enum _enet_interrupt_enable enet_interrupt_enable_t
typedef enum _enet_event enet_event_t
typedef enum _enet_tx_accelerator enet_tx_accelerator_t
typedef enum _enet_rx_accelerator enet_rx_accelerator_t
typedef struct _enet_rx_bd_struct enet_rx_bd_struct_t
typedef struct _enet_tx_bd_struct enet_tx_bd_struct_t
typedef struct _enet_data_error_stats enet_data_error_stats_t
typedef struct _enet_rx_frame_error enet_rx_frame_error_t
typedef struct _enet_transfer_stats enet_transfer_stats_t
typedef struct enet_frame_info enet_frame_info_t
typedef struct _enet_tx_dirty_ring enet_tx_dirty_ring_t
typedef void *(* enet_rx_alloc_callback_t) (ENET_Type *base, void *userData, uint8_t ringId)
 Defines the ENET Rx memory buffer alloc function pointer.
typedef void(* enet_rx_free_callback_t) (ENET_Type *base, void *buffer, void *userData, uint8_t ringId)
 Defines the ENET Rx memory buffer free function pointer.
typedef struct _enet_buffer_config enet_buffer_config_t
typedef struct _enet_handle enet_handle_t
typedef void(* enet_callback_t) (ENET_Type *base, enet_handle_t *handle, enet_event_t event, enet_frame_info_t *frameInfo, void *userData)
 ENET callback function.
typedef struct _enet_config enet_config_t
typedef struct _enet_tx_bd_ring enet_tx_bd_ring_t
typedef struct _enet_rx_bd_ring enet_rx_bd_ring_t
typedef struct _enet_buffer_struct enet_buffer_struct_t
typedef struct _enet_rx_frame_attribute_struct enet_rx_frame_attribute_t
typedef struct _enet_rx_frame_struct enet_rx_frame_struct_t
typedef struct _enet_tx_frame_struct enet_tx_frame_struct_t
typedef void(* enet_isr_t) (ENET_Type *base, enet_handle_t *handle)
 Define interrupt IRQ handler.
const clock_ip_name_t s_enetClock []
 Pointers to enet clocks for each instance.
uint32_t ENET_GetInstance (ENET_Type *base)
 Get the ENET instance from peripheral base address.
#define ENET_FRAME_MAX_FRAMELEN   1518U
#define ENET_FRAME_VLAN_TAGLEN   4U
#define ENET_FRAME_CRC_LEN   4U
#define ENET_FRAME_TX_LEN_LIMITATION(x)    ((((x)->RCR & ENET_RCR_MAX_FL_MASK) >> ENET_RCR_MAX_FL_SHIFT) - ENET_FRAME_CRC_LEN)
#define ENET_FIFO_MIN_RX_FULL   5U
#define ENET_RX_MIN_BUFFERSIZE   256U
#define ENET_PHY_MAXADDRESS   (ENET_MMFR_PA_MASK >> ENET_MMFR_PA_SHIFT)
#define ENET_TX_INTERRUPT    ((uint32_t)kENET_TxFrameInterrupt | (uint32_t)kENET_TxBufferInterrupt)
#define ENET_RX_INTERRUPT    ((uint32_t)kENET_RxFrameInterrupt | (uint32_t)kENET_RxBufferInterrupt)
#define ENET_TS_INTERRUPT    ((uint32_t)kENET_TsTimerInterrupt | (uint32_t)kENET_TsAvailInterrupt)
#define ENET_ERR_INTERRUPT
Initialization and De-initialization
void ENET_GetDefaultConfig (enet_config_t *config)
 Gets the ENET default configuration structure.
status_t ENET_Up (ENET_Type *base, enet_handle_t *handle, const enet_config_t *config, const enet_buffer_config_t *bufferConfig, uint8_t *macAddr, uint32_t srcClock_Hz)
 Initializes the ENET module.
status_t ENET_Init (ENET_Type *base, enet_handle_t *handle, const enet_config_t *config, const enet_buffer_config_t *bufferConfig, uint8_t *macAddr, uint32_t srcClock_Hz)
void ENET_Down (ENET_Type *base)
 Stops the ENET module.
void ENET_Deinit (ENET_Type *base)
 Deinitializes the ENET module.
MII interface operation
void ENET_SetMII (ENET_Type *base, enet_mii_speed_t speed, enet_mii_duplex_t duplex)
 Sets the ENET MII speed and duplex.
void ENET_SetSMI (ENET_Type *base, uint32_t srcClock_Hz, bool isPreambleDisabled)
 Sets the ENET SMI(serial management interface)- MII management interface.
status_t ENET_MDIOWrite (ENET_Type *base, uint8_t phyAddr, uint8_t regAddr, uint16_t data)
 MDIO write with IEEE802.3 Clause 22 format.
status_t ENET_MDIORead (ENET_Type *base, uint8_t phyAddr, uint8_t regAddr, uint16_t *pData)
 MDIO read with IEEE802.3 Clause 22 format.
MAC Address Filter
void ENET_SetMacAddr (ENET_Type *base, uint8_t *macAddr)
 Sets the ENET module Mac address.
void ENET_GetMacAddr (ENET_Type *base, uint8_t *macAddr)
 Gets the ENET module Mac address.
void ENET_AddMulticastGroup (ENET_Type *base, uint8_t *address)
 Adds the ENET device to a multicast group.
void ENET_LeaveMulticastGroup (ENET_Type *base, uint8_t *address)
 Moves the ENET device from a multicast group.
Interrupts.
void ENET_SetRxISRHandler (ENET_Type *base, enet_isr_t ISRHandler)
 Set the second level Rx IRQ handler.
void ENET_SetTxISRHandler (ENET_Type *base, enet_isr_t ISRHandler)
 Set the second level Tx IRQ handler.
void ENET_SetErrISRHandler (ENET_Type *base, enet_isr_t ISRHandler)
 Set the second level Err IRQ handler.
Transactional operation
void ENET_SetCallback (enet_handle_t *handle, enet_callback_t callback, void *userData)
 Sets the callback function.
void ENET_GetRxErrBeforeReadFrame (enet_handle_t *handle, enet_data_error_stats_t *eErrorStatic, uint8_t ringId)
 Gets the error statistics of a received frame for ENET specified ring.
void ENET_GetStatistics (ENET_Type *base, enet_transfer_stats_t *statistics)
 Gets statistical data in transfer.
status_t ENET_GetRxFrameSize (enet_handle_t *handle, uint32_t *length, uint8_t ringId)
 Gets the size of the read frame for specified ring.
status_t ENET_ReadFrame (ENET_Type *base, enet_handle_t *handle, uint8_t *data, uint32_t length, uint8_t ringId, uint32_t *ts)
 Reads a frame from the ENET device. This function reads a frame (both the data and the length) from the ENET buffer descriptors. User can get timestamp through ts pointer if the ts is not NULL.
status_t ENET_SendFrame (ENET_Type *base, enet_handle_t *handle, const uint8_t *data, uint32_t length, uint8_t ringId, bool tsFlag, void *context)
 Transmits an ENET frame for specified ring.
status_t ENET_SetTxReclaim (enet_handle_t *handle, bool isEnable, uint8_t ringId)
 Enable or disable tx descriptors reclaim mechanism.
void ENET_ReclaimTxDescriptor (ENET_Type *base, enet_handle_t *handle, uint8_t ringId)
 Reclaim tx descriptors. This function is used to update the tx descriptor status and store the tx timestamp when the 1588 feature is enabled. This is called by the transmit interupt IRQ handler after the complete of a frame transmission.
status_t ENET_GetRxBuffer (ENET_Type *base, enet_handle_t *handle, void **buffer, uint32_t *length, uint8_t ringId, bool *isLastBuff, uint32_t *ts)
 Get a receive buffer pointer of the ENET device for specified ring.
void ENET_ReleaseRxBuffer (ENET_Type *base, enet_handle_t *handle, void *buffer, uint8_t ringId)
 Release receive buffer descriptor to DMA.
status_t ENET_GetRxFrame (ENET_Type *base, enet_handle_t *handle, enet_rx_frame_struct_t *rxFrame, uint8_t ringId)
 Receives one frame in specified BD ring with zero copy.
status_t ENET_StartTxFrame (ENET_Type *base, enet_handle_t *handle, enet_tx_frame_struct_t *txFrame, uint8_t ringId)
 Sends one frame in specified BD ring with zero copy.
status_t ENET_SendFrameZeroCopy (ENET_Type *base, enet_handle_t *handle, const uint8_t *data, uint32_t length, uint8_t ringId, bool tsFlag, void *context)
 Transmits an ENET frame for specified ring with zero-copy.
void ENET_TransmitIRQHandler (ENET_Type *base, enet_handle_t *handle)
 The transmit IRQ handler.
void ENET_ReceiveIRQHandler (ENET_Type *base, enet_handle_t *handle)
 The receive IRQ handler.
void ENET_ErrorIRQHandler (ENET_Type *base, enet_handle_t *handle)
 Some special IRQ handler including the error, mii, wakeup irq handler.
void ENET_Ptp1588IRQHandler (ENET_Type *base)
 the common IRQ handler for the 1588 irq handler.
void ENET_CommonFrame0IRQHandler (ENET_Type *base)
 the common IRQ handler for the tx/rx/error etc irq handler.
Driver version
#define FSL_ENET_DRIVER_VERSION   (MAKE_VERSION(2, 6, 3))
 Defines the driver version.
ENET DESCRIPTOR QUEUE
#define FSL_FEATURE_ENET_QUEUE   1 /* Singal queue for previous IP. */
 Defines the queue number.
Control and status region bit masks of the receive buffer descriptor.
#define ENET_BUFFDESCRIPTOR_RX_EMPTY_MASK   0x8000U
#define ENET_BUFFDESCRIPTOR_RX_SOFTOWNER1_MASK   0x4000U
#define ENET_BUFFDESCRIPTOR_RX_WRAP_MASK   0x2000U
#define ENET_BUFFDESCRIPTOR_RX_SOFTOWNER2_Mask   0x1000U
#define ENET_BUFFDESCRIPTOR_RX_LAST_MASK   0x0800U
#define ENET_BUFFDESCRIPTOR_RX_MISS_MASK   0x0100U
#define ENET_BUFFDESCRIPTOR_RX_BROADCAST_MASK   0x0080U
#define ENET_BUFFDESCRIPTOR_RX_MULTICAST_MASK   0x0040U
#define ENET_BUFFDESCRIPTOR_RX_LENVLIOLATE_MASK   0x0020U
#define ENET_BUFFDESCRIPTOR_RX_NOOCTET_MASK   0x0010U
#define ENET_BUFFDESCRIPTOR_RX_CRC_MASK   0x0004U
#define ENET_BUFFDESCRIPTOR_RX_OVERRUN_MASK   0x0002U
#define ENET_BUFFDESCRIPTOR_RX_TRUNC_MASK   0x0001U
Control and status bit masks of the transmit buffer descriptor.
#define ENET_BUFFDESCRIPTOR_TX_READY_MASK   0x8000U
#define ENET_BUFFDESCRIPTOR_TX_SOFTOWENER1_MASK   0x4000U
#define ENET_BUFFDESCRIPTOR_TX_WRAP_MASK   0x2000U
#define ENET_BUFFDESCRIPTOR_TX_SOFTOWENER2_MASK   0x1000U
#define ENET_BUFFDESCRIPTOR_TX_LAST_MASK   0x0800U
#define ENET_BUFFDESCRIPTOR_TX_TRANMITCRC_MASK   0x0400U
#define ENET_BUFFDESCRIPTOR_RX_ERR_MASK
 Defines the receive error status flag mask.
◆ ENET_BUFFDESCRIPTOR_RX_BROADCAST_MASK
Broadcast packet mask.
◆ ENET_BUFFDESCRIPTOR_RX_CRC_MASK
CRC error mask.
◆ ENET_BUFFDESCRIPTOR_RX_EMPTY_MASK
Empty bit mask.
◆ ENET_BUFFDESCRIPTOR_RX_ERR_MASK
Value:
Definition: fsl_enet.h:51
Definition: fsl_enet.h:50
Definition: fsl_enet.h:49
Definition: fsl_enet.h:48
Definition: fsl_enet.h:52
◆ ENET_BUFFDESCRIPTOR_RX_LAST_MASK
Last BD of the frame mask.
◆ ENET_BUFFDESCRIPTOR_RX_LENVLIOLATE_MASK
Length violation mask.
◆ ENET_BUFFDESCRIPTOR_RX_MISS_MASK
Received because of the promiscuous mode.
◆ ENET_BUFFDESCRIPTOR_RX_MULTICAST_MASK
Multicast packet mask.
◆ ENET_BUFFDESCRIPTOR_RX_NOOCTET_MASK
Non-octet aligned frame mask.
◆ ENET_BUFFDESCRIPTOR_RX_OVERRUN_MASK
FIFO overrun mask.
◆ ENET_BUFFDESCRIPTOR_RX_SOFTOWNER1_MASK
Software owner one mask.
◆ ENET_BUFFDESCRIPTOR_RX_SOFTOWNER2_Mask
Software owner two mask.
◆ ENET_BUFFDESCRIPTOR_RX_TRUNC_MASK
Frame is truncated mask.
◆ ENET_BUFFDESCRIPTOR_RX_WRAP_MASK
Next buffer descriptor is the start address.
◆ ENET_BUFFDESCRIPTOR_TX_LAST_MASK
◆ ENET_BUFFDESCRIPTOR_TX_READY_MASK
Ready bit mask.
◆ ENET_BUFFDESCRIPTOR_TX_SOFTOWENER1_MASK
◆ ENET_BUFFDESCRIPTOR_TX_SOFTOWENER2_MASK
◆ ENET_BUFFDESCRIPTOR_TX_TRANMITCRC_MASK
Transmit CRC mask.
◆ ENET_BUFFDESCRIPTOR_TX_WRAP_MASK
Wrap buffer descriptor mask.
◆ ENET_ERR_INTERRUPT
Value:
((uint32_t)kENET_BabrInterrupt | (uint32_t)kENET_BabtInterrupt | (uint32_t)kENET_EBusERInterrupt | \
@ kENET_BabtInterrupt
Definition: fsl_enet.h:262
@ kENET_LateCollisionInterrupt
Definition: fsl_enet.h:270
@ kENET_UnderrunInterrupt
Definition: fsl_enet.h:272
@ kENET_BabrInterrupt
Definition: fsl_enet.h:261
@ kENET_RetryLimitInterrupt
Definition: fsl_enet.h:271
@ kENET_EBusERInterrupt
Definition: fsl_enet.h:269
@ kENET_PayloadRxInterrupt
Definition: fsl_enet.h:273
Enet error interrupt flag.
◆ ENET_FIFO_MIN_RX_FULL
ENET minimum receive FIFO full.
◆ ENET_FRAME_CRC_LEN
CRC size in a frame.
◆ ENET_FRAME_MAX_FRAMELEN
Default maximum Ethernet frame size without VLAN tag.
◆ ENET_FRAME_VLAN_TAGLEN
Ethernet single VLAN tag size.
◆ ENET_PHY_MAXADDRESS
Maximum PHY address.
◆ ENET_RX_INTERRUPT
Enet Rx interrupt flag.
◆ ENET_RX_MIN_BUFFERSIZE
ENET minimum buffer size.
◆ ENET_TS_INTERRUPT
Enet timestamp interrupt flag.
◆ ENET_TX_INTERRUPT
Enet Tx interrupt flag.
Typedef Documentation
◆ enet_buffer_config_t
Note that for the internal DMA requirements, the buffers have a corresponding alignment requirements.
  1. The aligned receive and transmit buffer size must be evenly divisible by ENET_BUFF_ALIGNMENT. when the data buffers are in cacheable region when cache is enabled, all those size should be aligned to the maximum value of "ENET_BUFF_ALIGNMENT" and the cache line size.
  2. The aligned transmit and receive buffer descriptor start address must be at least 64 bit aligned. However, it's recommended to be evenly divisible by ENET_BUFF_ALIGNMENT. buffer descriptors should be put in non-cacheable region when cache is enabled.
  3. The aligned transmit and receive data buffer start address must be evenly divisible by ENET_BUFF_ALIGNMENT. Receive buffers should be continuous with the total size equal to "rxBdNumber * rxBuffSizeAlign". Transmit buffers should be continuous with the total size equal to "txBdNumber * txBuffSizeAlign". when the data buffers are in cacheable region when cache is enabled, all those size should be aligned to the maximum value of "ENET_BUFF_ALIGNMENT" and the cache line size.
◆ enet_config_t
Note:
  1. macSpecialConfig is used for a special control configuration, A logical OR of "enet_special_control_flag_t". For a special configuration for MAC, set this parameter to 0.
  2. txWatermark is used for a cut-through operation. It is in steps of 64 bytes: 0/1 - 64 bytes written to TX FIFO before transmission of a frame begins. 2 - 128 bytes written to TX FIFO .... 3 - 192 bytes written to TX FIFO .... The maximum of txWatermark is 0x2F - 4032 bytes written to TX FIFO .... txWatermark allows minimizing the transmit latency to set the txWatermark to 0 or 1 or for larger bus access latency 3 or larger due to contention for the system bus.
  3. rxFifoFullThreshold is similar to the txWatermark for cut-through operation in RX. It is in 64-bit words. The minimum is ENET_FIFO_MIN_RX_FULL and the maximum is 0xFF. If the end of the frame is stored in FIFO and the frame size if smaller than the txWatermark, the frame is still transmitted. The rule is the same for rxFifoFullThreshold in the receive direction.
  4. When "kENET_ControlFlowControlEnable" is set in the macSpecialConfig, ensure that the pauseDuration, rxFifoEmptyThreshold, and rxFifoStatEmptyThreshold are set for flow control enabled case.
  5. When "kENET_ControlStoreAndFwdDisabled" is set in the macSpecialConfig, ensure that the rxFifoFullThreshold and txFifoWatermark are set for store and forward disable.
  6. The rxAccelerConfig and txAccelerConfig default setting with 0 - accelerator are disabled. The "enet_tx_accelerator_t" and "enet_rx_accelerator_t" are recommended to be used to enable the transmit and receive accelerator. After the accelerators are enabled, the store and forward feature should be enabled. As a result, kENET_ControlStoreAndFwdDisabled should not be set.
  7. The intCoalesceCfg can be used in the rx or tx enabled cases to decrese the CPU loading.
◆ enet_mii_speed_t
Notice: "kENET_MiiSpeed1000M" only supported when mii mode is "kENET_RgmiiMode".
◆ enet_special_control_flag_t
These control flags are provided for special user requirements. Normally, these control flags are unused for ENET initialization. For special requirements, set the flags to macSpecialConfig in the enet_config_t. The kENET_ControlStoreAndFwdDisable is used to disable the FIFO store and forward. FIFO store and forward means that the FIFO read/send is started when a complete frame is stored in TX/RX FIFO. If this flag is set, configure rxFifoFullThreshold and txFifoWatermark in the enet_config_t.
◆ anonymous enum
anonymous enum
Init fails since buffer memory is not enough.
A frame received but data error happen.
Failed to receive a frame.
No frame arrive.
Rx frame is dropped since no buffer memory.
Tx frame over length.
Tx buffer descriptors are under process.
Transmit frame fail.
◆ _enet_event
kENET_RxEvent
Receive event.
kENET_TxEvent
Transmit event.
kENET_ErrEvent
Error event: BABR/BABT/EBERR/LC/RL/UN/PLR .
kENET_WakeUpEvent
Wake up from sleep mode event.
Time stamp event.
Time stamp available event.
◆ _enet_interrupt_enable
kENET_BabrInterrupt
Babbling receive error interrupt source
kENET_BabtInterrupt
Babbling transmit error interrupt source
Graceful stop complete interrupt source
TX FRAME interrupt source
TX BUFFER interrupt source
RX FRAME interrupt source
RX BUFFER interrupt source
kENET_MiiInterrupt
MII interrupt source
Ethernet bus error interrupt source
Late collision interrupt source
Collision Retry Limit interrupt source
Transmit FIFO underrun interrupt source
Payload Receive error interrupt source
WAKEUP interrupt source
TS AVAIL interrupt source for PTP
TS WRAP interrupt source for PTP
◆ _enet_mii_duplex
kENET_MiiHalfDuplex
Half duplex mode.
kENET_MiiFullDuplex
Full duplex mode.
◆ _enet_mii_mode
kENET_MiiMode
MII mode for data interface.
kENET_RmiiMode
RMII mode for data interface.
◆ _enet_mii_read
Read frame operation for a valid MII management frame.
Read frame operation, but not MII-compliant.
◆ _enet_mii_speed
kENET_MiiSpeed10M
Speed 10 Mbps.
kENET_MiiSpeed100M
Speed 100 Mbps.
◆ _enet_mii_write
Write frame operation, but not MII-compliant.
Write frame operation for a valid MII management frame.
◆ _enet_rx_accelerator
Padding removal for short IP frames.
Discard with wrong IP header checksum.
Discard with wrong protocol checksum.
Discard with Mac layer errors.
Receive FIFO shift-16.
◆ _enet_special_control_flag
Enable ENET flow control: pause frame.
Enable ENET receive payload length check.
Padding is removed from received frames.
Enable broadcast frame reject.
Enable MAC address insert.
Enable FIFO store and forward.
Enable SMI preamble.
Enable promiscuous mode.
Enable ENET MII loop back.
Enable normal VLAN (single vlan tag).
◆ _enet_tx_accelerator
Transmit FIFO shift-16.
Insert IP header checksum.
Insert protocol checksum.
◆ ENET_AddMulticastGroup()
void ENET_AddMulticastGroup ( ENET_Type base,
uint8_t *  address
Parameters
baseENET peripheral base address.
addressThe six-byte multicast group address which is provided by application.
brief Adds the ENET device to a multicast group.
param base ENET peripheral base address. param address The six-byte multicast group address which is provided by application.
◆ ENET_CommonFrame0IRQHandler()
void ENET_CommonFrame0IRQHandler ( ENET_Type base)
This is used for the combined tx/rx/error interrupt for single/mutli-ring (frame 0).
Parameters
brief the common IRQ handler for the tx/rx/error etc irq handler.
◆ ENET_Deinit()
void ENET_Deinit ( ENET_Type base)
This function gates the module clock, clears ENET interrupts, and disables the ENET module.
Parameters
brief Deinitializes the ENET module.
◆ ENET_Down()
void ENET_Down ( ENET_Type base)
This function disables the ENET module.
Parameters
brief Stops the ENET module.
◆ ENET_ErrorIRQHandler()
void ENET_ErrorIRQHandler ( ENET_Type base,
enet_handle_t handle
Parameters
handleThe ENET handler pointer.
brief Some special IRQ handler including the error, mii, wakeup irq handler.
param base ENET peripheral base address. param handle The ENET handler pointer.
◆ ENET_GetDefaultConfig()
void ENET_GetDefaultConfig ( enet_config_t config)
The purpose of this API is to get the default ENET MAC controller configure structure for ENET_Init(). User may use the initialized structure unchanged in ENET_Init(), or modify some fields of the structure before calling ENET_Init(). Example:
void ENET_GetDefaultConfig(enet_config_t *config)
Definition: fsl_enet.c:206
Definition: fsl_enet.h:646
Definition: deflate.c:114
Parameters
configThe ENET mac controller configuration structure pointer.
brief Gets the ENET default configuration structure.
The purpose of this API is to get the default ENET MAC controller configure structure for ENET_Init(). User may use the initialized structure unchanged in ENET_Init(), or modify some fields of the structure before calling ENET_Init(). Example: code enet_config_t config; ENET_GetDefaultConfig(&config); endcode param config The ENET mac controller configuration structure pointer.
◆ ENET_GetInstance()
uint32_t ENET_GetInstance ( ENET_Type base)
Parameters
Returns
ENET instance.
Parameters
Returns
ENET instance.
◆ ENET_GetMacAddr()
void ENET_GetMacAddr ( ENET_Type base,
uint8_t *  macAddr
Parameters
macAddrThe six-byte Mac address pointer. The pointer is allocated by application and input into the API.
brief Gets the ENET module Mac address.
param base ENET peripheral base address. param macAddr The six-byte Mac address pointer. The pointer is allocated by application and input into the API.
◆ ENET_GetRxBuffer()
status_t ENET_GetRxBuffer ( ENET_Type base,
enet_handle_t handle,
void **  buffer,
uint32_t *  length,
uint8_t  ringId,
bool *  isLastBuff,
uint32_t *  ts
Deprecated:
Do not use this function. It has been superseded by ENET_GetRxFrame.
This function can get the data address which stores frame. Then can analyze these data directly without doing any memory copy. When the frame locates in multiple BD buffer, need to repeat calling this function until isLastBuff=true (need to store the temp buf pointer everytime call this function). After finishing the analysis of this frame, call ENET_ReleaseRxBuffer to release rxbuff memory to DMA. This is an example:
uint32_t length;
uint8_t *buf = NULL;
uint32_t data_len = 0;
bool isLastBuff = false;
enet_handle_t g_handle;
status_t status;
status = ENET_GetRxFrameSize(&g_handle, &length, 0);
if (length != 0)
ENET_GetRxBuffer(EXAMPLE_ENET, &g_handle, &buf, &data_len, 0, &isLastBuff, NULL);
ENET_ReleaseRxBuffer(EXAMPLE_ENET, &g_handle, buf, 0);
void ENET_ReleaseRxBuffer(ENET_Type *base, enet_handle_t *handle, void *buffer, uint8_t ringId)
Definition: fsl_enet.c:2252
status_t ENET_GetRxBuffer(ENET_Type *base, enet_handle_t *handle, void **buffer, uint32_t *length, uint8_t ringId, bool *isLastBuff, uint32_t *ts)
Definition: fsl_enet.c:2181
status_t ENET_GetRxFrameSize(enet_handle_t *handle, uint32_t *length, uint8_t ringId)
Definition: fsl_enet.c:1599
int32_t status_t
Type used for all status and error return values.
Definition: fsl_common.h:225
Definition: fsl_enet.h:698
Parameters
handleThe ENET handler structure. This is the same handler pointer used in the ENET_Init.
bufferThe data buffer pointer to store the frame.
lengthThe size of the data buffer. If isLastBuff=false, it represents data length of this buffer. If isLastBuff=true, it represents data length of total frame.
ringIdThe ring index, range from 0 ~ (FSL_FEATURE_ENET_INSTANCE_QUEUEn(x) - 1).
isLastBuffThe flag represents whether this buffer is the last buffer to store frame.
tsThe 1588 timestamp value, vaild in last buffer.
Return values
kStatus_SuccessGet receive buffer succeed.
kStatus_ENET_RxFrameFailGet receive buffer fails, it's owned by application, should wait app to release this buffer.
deprecated Do not use this function. It has been superseded by ENET_GetRxFrame.
◆ ENET_GetRxErrBeforeReadFrame()
void ENET_GetRxErrBeforeReadFrame ( enet_handle_t handle,
enet_data_error_stats_t eErrorStatic,
uint8_t  ringId
This API must be called after the ENET_GetRxFrameSize and before the ENET_ReadFrame(). If the ENET_GetRxFrameSize returns kStatus_ENET_RxFrameError, the ENET_GetRxErrBeforeReadFrame can be used to get the exact error statistics. This is an example.
Comments: Get the error information of the received frame.
ENET_GetRxErrBeforeReadFrame(&g_handle, &eErrStatic, 0);
Comments: update the receive buffer.
ENET_ReadFrame(EXAMPLE_ENET, &g_handle, NULL, 0);
status_t ENET_ReadFrame(ENET_Type *base, enet_handle_t *handle, uint8_t *data, uint32_t length, uint8_t ringId, uint32_t *ts)
Reads a frame from the ENET device. This function reads a frame (both the data and the length) from t...
Definition: fsl_enet.c:1716
void ENET_GetRxErrBeforeReadFrame(enet_handle_t *handle, enet_data_error_stats_t *eErrorStatic, uint8_t ringId)
Definition: fsl_enet.c:1482
@ kStatus_ENET_RxFrameError
Definition: fsl_enet.h:161
Parameters
handleThe ENET handler structure pointer. This is the same handler pointer used in the ENET_Init.
eErrorStaticThe error statistics structure pointer.
brief Gets the error statistics of a received frame for ENET specified ring.
This API must be called after the ENET_GetRxFrameSize and before the ENET_ReadFrame(). If the ENET_GetRxFrameSize returns kStatus_ENET_RxFrameError, the ENET_GetRxErrBeforeReadFrame can be used to get the exact error statistics. This is an example. code status = ENET_GetRxFrameSize(&g_handle, &length, 0); if (status == kStatus_ENET_RxFrameError) { ENET_GetRxErrBeforeReadFrame(&g_handle, &eErrStatic, 0); ENET_ReadFrame(EXAMPLE_ENET, &g_handle, NULL, 0); } endcode param handle The ENET handler structure pointer. This is the same handler pointer used in the ENET_Init. param eErrorStatic The error statistics structure pointer. param ringId The ring index, range from 0 ~ (FSL_FEATURE_ENET_INSTANCE_QUEUEn(x) - 1).
◆ ENET_GetRxFrame()
status_t ENET_GetRxFrame ( ENET_Type base,
enet_rx_frame_struct_t rxFrame,
uint8_t  ringId
This function will use the user-defined allocate and free callback. Every time application gets one frame through this function, driver will allocate new buffers for the BDs whose buffers have been taken by application.
Note
This function will drop current frame and update related BDs as available for DMA if new buffers allocating fails. Application must provide a memory pool including at least BD number + 1 buffers to make this function work normally. If user calls this function in Rx interrupt handler, be careful that this function makes Rx BD ready with allocating new buffer(normal) or updating current BD(out of memory). If there's always new Rx frame input, Rx interrupt will be triggered forever. Application need to disable Rx interrupt according to specific design in this case.
Parameters
handleThe ENET handler pointer. This is the same handler pointer used in the ENET_Init.
rxFrameThe received frame information structure provided by user.
ringIdThe ring index or ring number.
Return values
kStatus_SuccessSucceed to get one frame and allocate new memory for Rx buffer.
kStatus_ENET_RxFrameEmptyThere's no Rx frame in the BD.
kStatus_ENET_RxFrameErrorThere's issue in this receiving.
kStatus_ENET_RxFrameDropThere's no new buffer memory for BD, drop this frame.
brief Receives one frame in specified BD ring with zero copy.
This function will use the user-defined allocate and free callback. Every time application gets one frame through this function, driver will allocate new buffers for the BDs whose buffers have been taken by application. note This function will drop current frame and update related BDs as available for DMA if new buffers allocating fails. Application must provide a memory pool including at least BD number + 1 buffers to make this function work normally. If user calls this function in Rx interrupt handler, be careful that this function makes Rx BD ready with allocating new buffer(normal) or updating current BD(out of memory). If there's always new Rx frame input, Rx interrupt will be triggered forever. Application need to disable Rx interrupt according to specific design in this case.
param base ENET peripheral base address. param handle The ENET handler pointer. This is the same handler pointer used in the ENET_Init. param rxFrame The received frame information structure provided by user. param ringId The ring index or ring number. retval kStatus_Success Succeed to get one frame and allocate new memory for Rx buffer. retval kStatus_ENET_RxFrameEmpty There's no Rx frame in the BD. retval kStatus_ENET_RxFrameError There's issue in this receiving. retval kStatus_ENET_RxFrameDrop There's no new buffer memory for BD, drop this frame.
◆ ENET_GetRxFrameSize()
status_t ENET_GetRxFrameSize ( enet_handle_t handle,
uint32_t *  length,
uint8_t  ringId
This function gets a received frame size from the ENET buffer descriptors.
Note
The FCS of the frame is automatically removed by MAC and the size is the length without the FCS. After calling ENET_GetRxFrameSize, ENET_ReadFrame() should be called to receive frame and update the BD if the result is not "kStatus_ENET_RxFrameEmpty".
Parameters
lengthThe length of the valid frame received.
Return values
kStatus_ENET_RxFrameEmptyNo frame received. Should not call ENET_ReadFrame to read frame.
kStatus_ENET_RxFrameErrorData error happens. ENET_ReadFrame should be called with NULL data and NULL length to update the receive buffers.
kStatus_SuccessReceive a frame Successfully then the ENET_ReadFrame should be called with the right data buffer and the captured data length input.
brief Gets the size of the read frame for specified ring.
This function gets a received frame size from the ENET buffer descriptors. note The FCS of the frame is automatically removed by MAC and the size is the length without the FCS. After calling ENET_GetRxFrameSize, ENET_ReadFrame() should be called to receive frame and update the BD if the result is not "kStatus_ENET_RxFrameEmpty".
param handle The ENET handler structure. This is the same handler pointer used in the ENET_Init. param length The length of the valid frame received. param ringId The ring index or ring number. retval kStatus_ENET_RxFrameEmpty No frame received. Should not call ENET_ReadFrame to read frame. retval kStatus_ENET_RxFrameError Data error happens. ENET_ReadFrame should be called with NULL data and NULL length to update the receive buffers. retval kStatus_Success Receive a frame Successfully then the ENET_ReadFrame should be called with the right data buffer and the captured data length input.
◆ ENET_GetStatistics()
void ENET_GetStatistics ( ENET_Type base,
enet_transfer_stats_t statistics
Parameters
statisticsThe statistics structure pointer.
brief Gets statistical data in transfer.
param base ENET peripheral base address. param statistics The statistics structure pointer.
◆ ENET_Init()
status_t ENET_Init ( ENET_Type base,
const enet_config_t config,
const enet_buffer_config_t bufferConfig,
uint8_t *  macAddr,
This function ungates the module clock and initializes it with the ENET configuration.
Note
ENET has two buffer descriptors legacy buffer descriptors and enhanced IEEE 1588 buffer descriptors. The legacy descriptor is used by default. To use the IEEE 1588 feature, use the enhanced IEEE 1588 buffer descriptor by defining "ENET_ENHANCEDBUFFERDESCRIPTOR_MODE" and calling ENET_Ptp1588Configure() to configure the 1588 feature and related buffers after calling ENET_Init().
Parameters
handleENET handler pointer.
configENET mac configuration structure pointer. The "enet_config_t" type mac configuration return from ENET_GetDefaultConfig can be used directly. It is also possible to verify the Mac configuration using other methods.
bufferConfigENET buffer configuration structure pointer. The buffer configuration should be prepared for ENET Initialization. It is the start address of "ringNum" enet_buffer_config structures. To support added multi-ring features in some soc and compatible with the previous enet driver version. For single ring supported, this bufferConfig is a buffer configure structure pointer, for multi-ring supported and used case, this bufferConfig pointer should be a buffer configure structure array pointer.
macAddrENET mac address of Ethernet device. This MAC address should be provided.
srcClock_HzThe internal module clock source for MII clock.
Return values
kStatus_SuccessSucceed to initialize the ethernet driver.
kStatus_ENET_InitMemoryFailInit fails since buffer memory is not enough.
brief Initializes the ENET module.
This function ungates the module clock and initializes it with the ENET configuration. note ENET has two buffer descriptors legacy buffer descriptors and enhanced IEEE 1588 buffer descriptors. The legacy descriptor is used by default. To use the IEEE 1588 feature, use the enhanced IEEE 1588 buffer descriptor by defining "ENET_ENHANCEDBUFFERDESCRIPTOR_MODE" and calling ENET_Ptp1588Configure() to configure the 1588 feature and related buffers after calling ENET_Init().
param base ENET peripheral base address. param handle ENET handler pointer. param config ENET mac configuration structure pointer. The "enet_config_t" type mac configuration return from ENET_GetDefaultConfig can be used directly. It is also possible to verify the Mac configuration using other methods. param bufferConfig ENET buffer configuration structure pointer. The buffer configuration should be prepared for ENET Initialization. It is the start address of "ringNum" enet_buffer_config structures. To support added multi-ring features in some soc and compatible with the previous enet driver version. For single ring supported, this bufferConfig is a buffer configure structure pointer, for multi-ring supported and used case, this bufferConfig pointer should be a buffer configure structure array pointer. param macAddr ENET mac address of Ethernet device. This MAC address should be provided. param srcClock_Hz The internal module clock source for MII clock. retval kStatus_Success Succeed to initialize the ethernet driver. retval kStatus_ENET_InitMemoryFail Init fails since buffer memory is not enough.
◆ ENET_LeaveMulticastGroup()
void ENET_LeaveMulticastGroup ( ENET_Type base,
uint8_t *  address
Parameters
brief Moves the ENET device from a multicast group.
◆ ENET_MDIORead()
status_t ENET_MDIORead ( ENET_Type base,
uint8_t  phyAddr,
uint8_t  regAddr,
uint16_t *  pData
Parameters
phyAddrThe PHY address. Range from 0 ~ 31.
regAddrThe PHY register. Range from 0 ~ 31.
pDataThe data read from PHY.
Returns
kStatus_Success MDIO access succeeds.
kStatus_Timeout MDIO access timeout.
Parameters
Returns
◆ ENET_MDIOWrite()
status_t ENET_MDIOWrite ( ENET_Type base,
uint8_t  phyAddr,
uint8_t  regAddr,
uint16_t  data
Parameters
dataThe data written to PHY.
Returns
Parameters
Returns
◆ ENET_Ptp1588IRQHandler()
void ENET_Ptp1588IRQHandler ( ENET_Type base)
This is used for the 1588 timer interrupt.
Parameters
◆ ENET_ReadFrame()
status_t ENET_ReadFrame ( ENET_Type base,
uint8_t *  data,
uint32_t  length,
uint8_t  ringId,
uint32_t *  ts
Note
It doesn't store the timestamp in the receive timestamp queue. The ENET_GetRxFrameSize should be used to get the size of the prepared data buffer. This API uses memcpy to copy data from DMA buffer to application buffer, 4 bytes aligned data buffer in 32 bits platforms provided by user may let compiler use optimization instruction to reduce time consumption. This is an example:
uint32_t length;
Comments: Get the received frame size firstly.
if (length != 0)
Comments: Allocate memory here with the size of "length"
uint8_t *data = memory allocate interface;
if (!data)
ENET_ReadFrame(ENET, &g_handle, NULL, 0, 0, NULL);
Comments: Add the console warning log.
else
status = ENET_ReadFrame(ENET, &g_handle, data, length, 0, NULL);
Comments: Call stack input API to deliver the data to stack
else if (status == kStatus_ENET_RxFrameError)
Comments: Update the received buffer when a error frame is received.
#define ENET
Definition: MIMXRT1052.h:20352
Parameters
dataThe data buffer provided by user to store the frame which memory size should be at least "length".
lengthThe size of the data buffer which is still the length of the received frame.
tsThe timestamp address to store received timestamp.
Returns
The execute status, successful or failure.
brief Reads a frame from the ENET device. This function reads a frame (both the data and the length) from the ENET buffer descriptors. User can get timestamp through ts pointer if the ts is not NULL. note It doesn't store the timestamp in the receive timestamp queue. The ENET_GetRxFrameSize should be used to get the size of the prepared data buffer. This API uses memcpy to copy data from DMA buffer to application buffer, 4 bytes aligned data buffer in 32 bits platforms provided by user may let compiler use optimization instruction to reduce time consumption. This is an example: code uint32_t length; enet_handle_t g_handle; Comments: Get the received frame size firstly. status = ENET_GetRxFrameSize(&g_handle, &length, 0); if (length != 0) { Comments: Allocate memory here with the size of "length" uint8_t *data = memory allocate interface; if (!data) { ENET_ReadFrame(ENET, &g_handle, NULL, 0, 0, NULL); Comments: Add the console warning log. } else { status = ENET_ReadFrame(ENET, &g_handle, data, length, 0, NULL); Comments: Call stack input API to deliver the data to stack } } else if (status == kStatus_ENET_RxFrameError) { Comments: Update the received buffer when a error frame is received. ENET_ReadFrame(ENET, &g_handle, NULL, 0, 0, NULL); } endcode param base ENET peripheral base address. param handle The ENET handler structure. This is the same handler pointer used in the ENET_Init. param data The data buffer provided by user to store the frame which memory size should be at least "length". param length The size of the data buffer which is still the length of the received frame. param ringId The ring index or ring number. param ts The timestamp address to store received timestamp. return The execute status, successful or failure.
◆ ENET_ReceiveIRQHandler()
void ENET_ReceiveIRQHandler ( ENET_Type base,
Parameters
brief The receive IRQ handler.
◆ ENET_ReclaimTxDescriptor()
void ENET_ReclaimTxDescriptor ( ENET_Type base,
uint8_t  ringId
Parameters
brief Reclaim tx descriptors. This function is used to update the tx descriptor status and store the tx timestamp when the 1588 feature is enabled. This is called by the transmit interupt IRQ handler after the complete of a frame transmission.
param base ENET peripheral base address. param handle The ENET handler pointer. This is the same handler pointer used in the ENET_Init. param ringId The ring index or ring number.
◆ ENET_ReleaseRxBuffer()
void ENET_ReleaseRxBuffer ( ENET_Type base,
void *  buffer,
uint8_t  ringId
Deprecated:
This function can release specified BD owned by application, meanwhile it may rearrange the BD to let the no-owned BDs always in back of the index of DMA transfer. So for the situation that releasing order is not same as the getting order, the rearrangement makes all ready BDs can be used by DMA.
Note
This function can't be interrupted by ENET_GetRxBuffer, so in application must make sure ENET_GetRxBuffer is called before or after this function. And this function itself isn't thread safe due to BD content exchanging.
Parameters
bufferThe buffer address to store frame, using it to find the correspond BD and release it.
◆ ENET_SendFrame()
status_t ENET_SendFrame ( ENET_Type base,
const uint8_t *  data,
uint32_t  length,
uint8_t  ringId,
bool  tsFlag,
void *  context
Note
The CRC is automatically appended to the data. Input the data to send without the CRC. This API uses memcpy to copy data from DMA buffer to application buffer, 4 bytes aligned data buffer in 32 bits platforms provided by user may let compiler use optimization instruction to reduce time consumption.
Parameters
dataThe data buffer provided by user to send.
lengthThe length of the data to send.
tsFlagTimestamp enable flag.
contextUsed by user to handle some events after transmit over.
Return values
kStatus_SuccessSend frame succeed.
kStatus_ENET_TxFrameBusyTransmit buffer descriptor is busy under transmission. The transmit busy happens when the data send rate is over the MAC capacity. The waiting mechanism is recommended to be added after each call return with kStatus_ENET_TxFrameBusy.
brief Transmits an ENET frame for specified ring. note The CRC is automatically appended to the data. Input the data to send without the CRC. This API uses memcpy to copy data from DMA buffer to application buffer, 4 bytes aligned data buffer in 32 bits platforms provided by user may let compiler use optimization instruction to reduce time consumption.
param base ENET peripheral base address. param handle The ENET handler pointer. This is the same handler pointer used in the ENET_Init. param data The data buffer provided by user to send. param length The length of the data to send. param ringId The ring index or ring number. param tsFlag Timestamp enable flag. param context Used by user to handle some events after transmit over. retval kStatus_Success Send frame succeed. retval kStatus_ENET_TxFrameBusy Transmit buffer descriptor is busy under transmission. The transmit busy happens when the data send rate is over the MAC capacity. The waiting mechanism is recommended to be added after each call return with kStatus_ENET_TxFrameBusy.
◆ ENET_SendFrameZeroCopy()
status_t ENET_SendFrameZeroCopy ( ENET_Type base,
uint32_t  length,
uint8_t  ringId,
bool  tsFlag,
void *  context
Deprecated:
Do not use this function. It has been superseded by ENET_StartTxFrame.
Note
The CRC is automatically appended to the data. Input the data to send without the CRC. The frame must store in continuous memory and need to check the buffer start address alignment based on your device, otherwise it has issue or can't get highest DMA transmit speed.
Parameters
Return values
deprecated Do not use this function. It has been superseded by ENET_StartTxFrame.
◆ ENET_SetCallback()
void ENET_SetCallback ( enet_handle_t handle,
void *  userData
Deprecated:
Do not use this function. It has been superceded by the config param in ENET_Init. This API is provided for the application callback required case when ENET interrupt is enabled. This API should be called after calling ENET_Init.
Parameters
handleENET handler pointer. Should be provided by application.
callbackThe ENET callback function.
userDataThe callback function parameter.
deprecated Do not use this function. It has been superceded by the config param in ENET_Init.
◆ ENET_SetErrISRHandler()
void ENET_SetErrISRHandler ( ENET_Type base,
Parameters
ISRHandlerThe handler to install.
◆ ENET_SetMacAddr()
void ENET_SetMacAddr ( ENET_Type base,
uint8_t *  macAddr
Parameters
brief Sets the ENET module Mac address.
◆ ENET_SetMII()
void ENET_SetMII ( ENET_Type base,
This API is provided to dynamically change the speed and dulpex for MAC.
Parameters
speedThe speed of the RMII mode.
duplexThe duplex of the RMII mode.
brief Sets the ENET MII speed and duplex.
param base ENET peripheral base address. param speed The speed of the RMII mode. param duplex The duplex of the RMII mode.
◆ ENET_SetRxISRHandler()
void ENET_SetRxISRHandler ( ENET_Type base,
Parameters
◆ ENET_SetSMI()
void ENET_SetSMI ( ENET_Type base,
Parameters
srcClock_HzThis is the ENET module clock frequency. See clock distribution.
isPreambleDisabledThe preamble disable flag.
  • true Enables the preamble.
  • false Disables the preamble.
brief Sets the ENET SMI(serial management interface)- MII management interface.
param base ENET peripheral base address. param srcClock_Hz This is the ENET module clock frequency. See clock distribution. param isPreambleDisabled The preamble disable flag.
◆ ENET_SetTxISRHandler()
void ENET_SetTxISRHandler ( ENET_Type base,
Parameters
◆ ENET_SetTxReclaim()
status_t ENET_SetTxReclaim ( enet_handle_t handle,
bool  isEnable,
uint8_t  ringId
Note
This function must be called when no pending send frame action. Set enable if you want to reclaim context or timestamp in interrupt.
Parameters
isEnableEnable or disable flag.
Return values
kStatus_SuccessSucceed to enable/disable Tx reclaim.
kStatus_FailFail to enable/disable Tx reclaim.
brief Enable or disable tx descriptors reclaim mechanism. note This function must be called when no pending send frame action. Set enable if you want to reclaim context or timestamp in interrupt.
param handle The ENET handler pointer. This is the same handler pointer used in the ENET_Init. param isEnable Enable or disable flag. param ringId The ring index or ring number. retval kStatus_Success Succeed to enable/disable Tx reclaim. retval kStatus_Fail Fail to enable/disable Tx reclaim.
◆ ENET_StartTxFrame()
status_t ENET_StartTxFrame ( ENET_Type base,
enet_tx_frame_struct_t txFrame,
uint8_t  ringId
This function supports scattered buffer transmit, user needs to provide the buffer array.
Note
Tx reclaim should be enabled to ensure the Tx buffer ownership can be given back to application after Tx is over.
Parameters
txFrameThe Tx frame structure.
Return values
kStatus_SuccessSucceed to send one frame.
kStatus_ENET_TxFrameBusyThe BD is not ready for Tx or the reclaim operation still not finishs.
kStatus_ENET_TxFrameOverLenThe Tx frame length is over max ethernet frame length.
brief Sends one frame in specified BD ring with zero copy.
This function supports scattered buffer transmit, user needs to provide the buffer array. note Tx reclaim should be enabled to ensure the Tx buffer ownership can be given back to application after Tx is over.
param base ENET peripheral base address. param handle The ENET handler pointer. This is the same handler pointer used in the ENET_Init. param txFrame The Tx frame structure. param ringId The ring index or ring number. retval kStatus_Success Succeed to send one frame. retval kStatus_ENET_TxFrameBusy The BD is not ready for Tx or the reclaim operation still not finishs. retval kStatus_ENET_TxFrameOverLen The Tx frame length is over max ethernet frame length.
◆ ENET_TransmitIRQHandler()
void ENET_TransmitIRQHandler ( ENET_Type base,
Parameters
brief The transmit IRQ handler.
◆ ENET_Up()
status_t ENET_Up ( ENET_Type base,
uint8_t *  macAddr,
This function initializes the module with the ENET configuration.
Note
ENET has two buffer descriptors legacy buffer descriptors and enhanced IEEE 1588 buffer descriptors. The legacy descriptor is used by default. To use the IEEE 1588 feature, use the enhanced IEEE 1588 buffer descriptor by defining "ENET_ENHANCEDBUFFERDESCRIPTOR_MODE" and calling ENET_Ptp1588Configure() to configure the 1588 feature and related buffers after calling ENET_Up().
Parameters
Return values
This function initializes the module with the ENET configuration. note ENET has two buffer descriptors legacy buffer descriptors and enhanced IEEE 1588 buffer descriptors. The legacy descriptor is used by default. To use the IEEE 1588 feature, use the enhanced IEEE 1588 buffer descriptor by defining "ENET_ENHANCEDBUFFERDESCRIPTOR_MODE" and calling ENET_Ptp1588Configure() to configure the 1588 feature and related buffers after calling ENET_Up().
Variable Documentation
◆ buffer [1/3]
Data buffer pointer.
◆ buffer [2/3]
◆ buffer [3/3]
void* _enet_buffer_struct::buffer
The buffer store the whole or partial frame.
◆ callback [1/2]
General callback function.
◆ callback [2/2]
Callback function.
◆ context [1/2]
void* enet_frame_info::context
User specified data
◆ context [2/2]
void* _enet_tx_frame_struct::context
Driver reclaims and gives it in Tx over callback, usually store network packet header.
◆ control [1/2]
Buffer descriptor control and status.
◆ control [2/2]
◆ interrupt
Mac interrupt source. A logical OR of "enet_interrupt_enable_t".
◆ isFull
tx ring is full flag.
◆ length [1/3]
Buffer descriptor data length.
◆ length [2/3]
◆ length [3/3]
The byte length of this buffer.
◆ macSpecialConfig
Mac special configuration. A logical OR of "enet_special_control_flag_t".
◆ miiDuplex
MII duplex.
◆ miiMode
MII mode.
◆ miiSpeed
MII Speed.
◆ multicastCount
uint8_t _enet_handle::multicastCount[64]
Multicast collisions counter
◆ pauseDuration
For flow control enabled case: Pause duration.
◆ promiscuous
This frame is received because of promiscuous mode.
◆ ringNum [1/2]
Number of used rings. default with 1 – single ring.
◆ ringNum [2/2]
◆ rxAccelerConfig
Receive accelerator, A logical OR of "enet_rx_accelerator_t".
◆ rxAttribute
Rx frame attribute structure.
◆ rxBdBase
volatile enet_rx_bd_struct_t* _enet_rx_bd_ring::rxBdBase
Buffer descriptor base address pointer.
◆ rxBdNumber
Receive buffer descriptor number.
◆ rxBdRing
enet_rx_bd_ring_t _enet_handle::rxBdRing[FSL_FEATURE_ENET_QUEUE]
Receive buffer descriptor.
◆ rxBdStartAddrAlign
volatile enet_rx_bd_struct_t* _enet_buffer_config::rxBdStartAddrAlign
Aligned receive buffer descriptor start address: should be non-cacheable.
◆ rxBuffAlloc [1/2]
Callback function to alloc memory, must be provided for zero-copy Rx.
◆ rxBuffAlloc [2/2]
Callback function to alloc memory for zero copy Rx.
◆ rxBuffArray
enet_buffer_struct_t* _enet_rx_frame_struct::rxBuffArray
Rx frame buffer structure.
◆ rxBufferAlign
uint8_t* _enet_buffer_config::rxBufferAlign
Receive data buffer start address.
◆ rxBuffFree [1/2]
Callback function to free memory, must be provided for zero-copy Rx.
◆ rxBuffFree [2/2]
Callback function to free memory for zero copy Rx.
◆ rxBuffSizeAlign [1/2]
Aligned receive data buffer size.
◆ rxBuffSizeAlign [2/2]
uint16_t _enet_handle::rxBuffSizeAlign[FSL_FEATURE_ENET_QUEUE]
Receive buffer size alignment.
◆ rxFifoEmptyThreshold
For flow control enabled case: when RX FIFO level reaches this value, it makes MAC generate XOFF pause frame.
◆ rxFifoFullThreshold
For store and forward disable case, the data required in RX FIFO to notify the MAC receive ready status.
◆ rxFrameError
Rx frame error.
◆ rxGenIdx
The current available receive buffer descriptor pointer.
◆ rxMaintainEnable [1/2]
Receive buffer cache maintain.
◆ rxMaintainEnable [2/2]
bool _enet_handle::rxMaintainEnable[FSL_FEATURE_ENET_QUEUE]
◆ rxMaxFrameLen
Receive maximum frame length.
◆ rxRingLen
Receive ring length.
◆ statsRxAlignErr [1/3]
Receive non-octet alignment/
◆ statsRxAlignErr [2/3]
Receive non-octet alignment.
◆ statsRxAlignErr [3/3]
Rx frame number with alignment error.
◆ statsRxCrcErr
Rx frame number with CRC error.
◆ statsRxDropInvalidSFD
Dropped frame number due to invalid SFD.
◆ statsRxFcsErr [1/2]
Receive CRC error.
◆ statsRxFcsErr [2/2]
Receive CRC error.
◆ statsRxFifoOverflowErr
Rx FIFO overflow count.
◆ statsRxFrameCount
Rx frame number.
◆ statsRxFrameOk
Good Rx frame number.
◆ statsRxLenGreaterErr [1/2]
Receive length greater than RCR[MAX_FL].
◆ statsRxLenGreaterErr [2/2]
◆ statsRxOverRunErr [1/2]
Receive over run.
◆ statsRxOverRunErr [2/2]
Receive over run.
◆ statsRxTruncateErr [1/2]
Receive truncate.
◆ statsRxTruncateErr [2/2]
Receive truncate.
◆ statsTxCrcAlignErr
The transmit frame is error.
◆ statsTxFifoUnderRunErr
Tx FIFO underrun count.
◆ statsTxFrameCount
Tx frame number.
◆ statsTxFrameOk
Good Tx frame number.
◆ totLen
Rx frame total length.
◆ txAccelerConfig
Transmit accelerator, A logical OR of "enet_rx_accelerator_t".
◆ txBdBase
volatile enet_tx_bd_struct_t* _enet_tx_bd_ring::txBdBase
◆ txBdNumber
Transmit buffer descriptor number.
◆ txBdRing
enet_tx_bd_ring_t _enet_handle::txBdRing[FSL_FEATURE_ENET_QUEUE]
Transmit buffer descriptor.
◆ txBdStartAddrAlign
volatile enet_tx_bd_struct_t* _enet_buffer_config::txBdStartAddrAlign
Aligned transmit buffer descriptor start address: should be non-cacheable.
◆ txBuffArray
enet_buffer_struct_t* _enet_tx_frame_struct::txBuffArray
Tx frame buffer structure.
◆ txBufferAlign
uint8_t* _enet_buffer_config::txBufferAlign
Transmit data buffer start address.
◆ txBuffNum
Buffer number of this Tx frame.
◆ txBuffSizeAlign [1/2]
Aligned transmit data buffer size.
◆ txBuffSizeAlign [2/2]
uint16_t _enet_handle::txBuffSizeAlign[FSL_FEATURE_ENET_QUEUE]
Transmit buffer size alignment.
◆ txConsumIdx [1/2]
tx consume index.
◆ txConsumIdx [2/2]
Transmit consume index.
◆ txDescUsed
Transmit descriptor used number.
◆ txDirtyBase
enet_frame_info_t* _enet_tx_dirty_ring::txDirtyBase
Dirty buffer descriptor base address pointer.
◆ txDirtyRing
enet_tx_dirty_ring_t _enet_handle::txDirtyRing[FSL_FEATURE_ENET_QUEUE]
Ring to store tx frame information.
◆ txFifoWatermark
For store and forward disable case, the data required in TX FIFO before a frame transmit start.
◆ txFrameInfo
enet_frame_info_t* _enet_buffer_config::txFrameInfo
Transmit frame information start address.
◆ txGenIdx [1/2]
tx generate index.
◆ txGenIdx [2/2]
The current available transmit buffer descriptor pointer.
◆ txMaintainEnable [1/2]
Transmit buffer cache maintain.
◆ txMaintainEnable [2/2]
bool _enet_handle::txMaintainEnable[FSL_FEATURE_ENET_QUEUE]
◆ txReclaimEnable
bool _enet_handle::txReclaimEnable[FSL_FEATURE_ENET_QUEUE]
Tx reclaim enable flag.
◆ txRingLen [1/2]
tx ring length.
◆ txRingLen [2/2]
Transmit ring length.
◆ userData [1/2]
void* _enet_config::userData
Callback function parameter.
◆ userData [2/2]
void* _enet_handle::userData
