RTEMS 6.1-rc5
Modules | Data Structures | Macros | Enumerator | Functions | Variables
Dcp_driver
 Dcp_driver_aes
 Dcp_driver_hash
 Dcp_nonblocking_driver_aes
struct  _dcp_work_packet
 DCP's work packet. More...
struct  _dcp_handle
 Specify DCP's key resource and DCP channel. More...
struct  _dcp_context
 DCP's context buffer, used by DCP for context switching between channels. More...
struct  _dcp_config
 DCP's configuration structure. More...
#define DCP_USE_DCACHE   1
void DCP_Init (DCP_Type *base, const dcp_config_t *config)
 Enables clock to and enables DCP.
void DCP_Deinit (DCP_Type *base)
 Disable DCP clock.
void DCP_GetDefaultConfig (dcp_config_t *config)
 Gets the default configuration structure.
status_t DCP_WaitForChannelComplete (DCP_Type *base, dcp_handle_t *handle)
 Poll and wait on DCP channel.
uint32_t _dcp_work_packet::nextCmdAddress
uint32_t _dcp_work_packet::control0
uint32_t _dcp_work_packet::control1
uint32_t _dcp_work_packet::sourceBufferAddress
uint32_t _dcp_work_packet::destinationBufferAddress
uint32_t _dcp_work_packet::bufferSize
uint32_t _dcp_work_packet::payloadPointer
uint32_t _dcp_work_packet::status
dcp_channel_t _dcp_handle::channel
dcp_key_slot_t _dcp_handle::keySlot
uint32_t _dcp_handle::swapConfig
uint32_t _dcp_handle::keyWord [4]
uint32_t _dcp_handle::iv [4]
uint32_t _dcp_context::x [208/sizeof(uint32_t)]
bool _dcp_config::gatherResidualWrites
bool _dcp_config::enableContextCaching
bool _dcp_config::enableContextSwitching
uint8_t _dcp_config::enableChannel
uint8_t _dcp_config::enableChannelInterrupt
uint32_t _dcp_hash_ctx_t::x [DCP_HASH_CTX_SIZE]
Driver version
enum  _dcp_status { kStatus_DCP_Again = MAKE_STATUS(kStatusGroup_DCP, 0) }
 DCP status return codes. More...
enum  _dcp_ch_enable {
  kDCP_chDisable = 0U , kDCP_ch0Enable = 1U , kDCP_ch1Enable = 2U , kDCP_ch2Enable = 4U ,
  kDCP_ch3Enable = 8U , kDCP_chEnableAll = 15U
 DCP channel enable. More...
enum  _dcp_ch_int_enable {
  kDCP_chIntDisable = 0U , kDCP_ch0IntEnable = 1U , kDCP_ch1IntEnable = 2U , kDCP_ch2IntEnable = 4U ,
  kDCP_ch3IntEnable = 8U
 DCP interrupt enable. More...
enum  _dcp_channel { kDCP_Channel0 = (1u << 16) , kDCP_Channel1 = (1u << 17) , kDCP_Channel2 = (1u << 18) , kDCP_Channel3 = (1u << 19) }
 DCP channel selection. More...
enum  _dcp_key_slot {
  kDCP_KeySlot0 = 0U , kDCP_KeySlot1 = 1U , kDCP_KeySlot2 = 2U , kDCP_KeySlot3 = 3U ,
  kDCP_OtpKey = 4U , kDCP_OtpUniqueKey = 5U , kDCP_PayloadKey = 6U
 DCP key slot selection. More...
enum  _dcp_swap {
  kDCP_NoSwap = 0x0U , kDCP_KeyByteSwap = 0x40000U , kDCP_KeyWordSwap = 0x80000U , kDCP_InputByteSwap = 0x100000U ,
  kDCP_InputWordSwap = 0x200000U , kDCP_OutputByteSwap = 0x400000U , kDCP_OutputWordSwap = 0x800000U
 DCP key, input & output swap options. More...
typedef enum _dcp_ch_enable _dcp_ch_enable_t
 DCP channel enable.
typedef enum _dcp_ch_int_enable _dcp_ch_int_enable_t
typedef enum _dcp_channel dcp_channel_t
typedef enum _dcp_key_slot dcp_key_slot_t
typedef enum _dcp_swap dcp_swap_t
typedef struct _dcp_work_packet dcp_work_packet_t
 DCP's work packet.
typedef struct _dcp_handle dcp_handle_t
typedef struct _dcp_context dcp_context_t
typedef struct _dcp_config dcp_config_t
#define FSL_DCP_DRIVER_VERSION   (MAKE_VERSION(2, 1, 6))
 DCP driver version. Version 2.1.6.
◆ FSL_DCP_DRIVER_VERSION
Current version: 2.1.6
Change log:
  • Version 2.1.6
    • Bug Fix
      • MISRA C-2012 issue fix.
  • Version 2.1.5
    • Improvements
      • Add support for DCACHE.
  • Version 2.1.4
    • Bug Fix
      • Fix CRC-32 computation issue on the code's block boundary size.
  • Version 2.1.3
    • Bug Fix
      • MISRA C-2012 issue fixed: rule 10.1, 10.3, 10.4, 11.9, 14.4, 16.4 and 17.7.
  • Version 2.1.2
    • Fix sign-compare warning in dcp_reverse_and_copy.
  • Version 2.1.1
    • Add DCP status clearing when channel operation is complete
  • 2.1.0
    • Add byte/word swap feature for key, input and output data
  • Version 2.0.0
    • Initial version
Typedef Documentation
◆ _dcp_ch_enable_t
DCP channel enable.
◆ _dcp_ch_int_enable_t
◆ dcp_channel_t
◆ dcp_key_slot_t
◆ dcp_swap_t
◆ _dcp_ch_enable
DCP channel enable.
kDCP_chDisable
DCP channel disable
kDCP_ch0Enable
DCP channel 0 enable
kDCP_ch1Enable
DCP channel 1 enable
kDCP_ch2Enable
DCP channel 2 enable
kDCP_ch3Enable
DCP channel 3 enable
kDCP_chEnableAll
DCP channel enable all
kDCP_chIntDisable
DCP interrupts disable
kDCP_ch0IntEnable
DCP channel 0 interrupt enable
kDCP_ch1IntEnable
DCP channel 1 interrupt enable
kDCP_ch2IntEnable
DCP channel 2 interrupt enable
kDCP_ch3IntEnable
DCP channel 3 interrupt enable
◆ _dcp_channel
kDCP_Channel0
DCP channel 0.
kDCP_Channel1
DCP channel 1.
kDCP_Channel2
DCP channel 2.
kDCP_Channel3
DCP channel 3.
◆ _dcp_key_slot
kDCP_KeySlot0
DCP key slot 0.
kDCP_KeySlot1
DCP key slot 1.
kDCP_KeySlot2
DCP key slot 2.
kDCP_KeySlot3
DCP key slot 3.
kDCP_OtpKey
DCP OTP key.
kDCP_OtpUniqueKey
DCP unique OTP key.
kDCP_PayloadKey
DCP payload key.
◆ _dcp_status
kStatus_DCP_Again
Non-blocking function shall be called again.
◆ _dcp_swap
enum _dcp_swap
◆ DCP_Deinit()
void DCP_Deinit ( DCP_Type base)
Disable DCP clock.
Reset DCP and Disable DCP clock.
Parameters
baseDCP base address
brief Disable DCP clock
param base DCP base address
◆ DCP_GetDefaultConfig()
void DCP_GetDefaultConfig ( dcp_config_t config)
This function initializes the DCP configuration structure to a default value. The default values are as follows. dcpConfig->gatherResidualWrites = true; dcpConfig->enableContextCaching = true; dcpConfig->enableContextSwitching = true; dcpConfig->enableChannnel = kDCP_chEnableAll; dcpConfig->enableChannelInterrupt = kDCP_chIntDisable;
Parameters
[out]configPointer to configuration structure.
brief Gets the default configuration structure.
param[out] config Pointer to configuration structure.
◆ DCP_Init()
void DCP_Init ( DCP_Type base,
const dcp_config_t config
Enable DCP clock and configure DCP.
Parameters
brief Enables clock to and enables DCP
param base DCP base address param config Pointer to configuration structure.
◆ DCP_WaitForChannelComplete()
status_t DCP_WaitForChannelComplete ( DCP_Type base,
dcp_handle_t handle
Polls the specified DCP channel until current it completes activity.
Parameters
baseDCP peripheral base address.
handleSpecifies DCP channel.
Returns
kStatus_Success When data processing completes without error.
kStatus_Fail When error occurs.
brief Poll and wait on DCP channel.
param base DCP peripheral base address. param handle Specifies DCP channel. return kStatus_Success When data processing completes without error. return kStatus_Fail When error occurs.
Variable Documentation
◆ channel
Specify DCP channel.
◆ enableChannel
DCP channel enable.
◆ enableChannelInterrupt
Per-channel interrupt enable.
◆ enableContextCaching
Enable the caching of contexts between the operations.
◆ enableContextSwitching
Enable automatic context switching for the channels.
◆ gatherResidualWrites
Enable the ragged writes to the unaligned buffers.
◆ keySlot
For operations with key (such as AES encryption/decryption), specify DCP key slot.
◆ swapConfig
For configuration of key, input, output byte/word swap options
