RTEMS 6.1-rc5
WCR - Watchdog Control Register
#define WDOG_WCR_WDZST_MASK   (0x1U)
#define WDOG_WCR_WDZST_SHIFT   (0U)
#define WDOG_WCR_WDZST(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WDZST_SHIFT)) & WDOG_WCR_WDZST_MASK)
#define WDOG_WCR_WDBG_MASK   (0x2U)
#define WDOG_WCR_WDBG_SHIFT   (1U)
#define WDOG_WCR_WDBG(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WDBG_SHIFT)) & WDOG_WCR_WDBG_MASK)
#define WDOG_WCR_WDE_MASK   (0x4U)
#define WDOG_WCR_WDE_SHIFT   (2U)
#define WDOG_WCR_WDE(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WDE_SHIFT)) & WDOG_WCR_WDE_MASK)
#define WDOG_WCR_WDT_MASK   (0x8U)
#define WDOG_WCR_WDT_SHIFT   (3U)
#define WDOG_WCR_WDT(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WDT_SHIFT)) & WDOG_WCR_WDT_MASK)
#define WDOG_WCR_SRS_MASK   (0x10U)
#define WDOG_WCR_SRS_SHIFT   (4U)
#define WDOG_WCR_SRS(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_SRS_SHIFT)) & WDOG_WCR_SRS_MASK)
#define WDOG_WCR_WDA_MASK   (0x20U)
#define WDOG_WCR_WDA_SHIFT   (5U)
#define WDOG_WCR_WDA(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WDA_SHIFT)) & WDOG_WCR_WDA_MASK)
#define WDOG_WCR_SRE_MASK   (0x40U)
#define WDOG_WCR_SRE_SHIFT   (6U)
#define WDOG_WCR_SRE(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_SRE_SHIFT)) & WDOG_WCR_SRE_MASK)
#define WDOG_WCR_WDW_MASK   (0x80U)
#define WDOG_WCR_WDW_SHIFT   (7U)
#define WDOG_WCR_WDW(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WDW_SHIFT)) & WDOG_WCR_WDW_MASK)
#define WDOG_WCR_WT_MASK   (0xFF00U)
#define WDOG_WCR_WT_SHIFT   (8U)
#define WDOG_WCR_WT(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WT_SHIFT)) & WDOG_WCR_WT_MASK)
WSR - Watchdog Service Register
#define WDOG_WSR_WSR_MASK   (0xFFFFU)
#define WDOG_WSR_WSR_SHIFT   (0U)
#define WDOG_WSR_WSR(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WSR_WSR_SHIFT)) & WDOG_WSR_WSR_MASK)
WRSR - Watchdog Reset Status Register
#define WDOG_WRSR_SFTW_MASK   (0x1U)
#define WDOG_WRSR_SFTW_SHIFT   (0U)
#define WDOG_WRSR_SFTW(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WRSR_SFTW_SHIFT)) & WDOG_WRSR_SFTW_MASK)
#define WDOG_WRSR_TOUT_MASK   (0x2U)
#define WDOG_WRSR_TOUT_SHIFT   (1U)
#define WDOG_WRSR_TOUT(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WRSR_TOUT_SHIFT)) & WDOG_WRSR_TOUT_MASK)
#define WDOG_WRSR_POR_MASK   (0x10U)
#define WDOG_WRSR_POR_SHIFT   (4U)
#define WDOG_WRSR_POR(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WRSR_POR_SHIFT)) & WDOG_WRSR_POR_MASK)
WICR - Watchdog Interrupt Control Register
#define WDOG_WICR_WICT_MASK   (0xFFU)
#define WDOG_WICR_WICT_SHIFT   (0U)
#define WDOG_WICR_WICT(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WICR_WICT_SHIFT)) & WDOG_WICR_WICT_MASK)
#define WDOG_WICR_WTIS_MASK   (0x4000U)
#define WDOG_WICR_WTIS_SHIFT   (14U)
#define WDOG_WICR_WTIS(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WICR_WTIS_SHIFT)) & WDOG_WICR_WTIS_MASK)
#define WDOG_WICR_WIE_MASK   (0x8000U)
#define WDOG_WICR_WIE_SHIFT   (15U)
#define WDOG_WICR_WIE(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WICR_WIE_SHIFT)) & WDOG_WICR_WIE_MASK)
WMCR - Watchdog Miscellaneous Control Register
#define WDOG_WMCR_PDE_MASK   (0x1U)
#define WDOG_WMCR_PDE_SHIFT   (0U)
#define WDOG_WMCR_PDE(x)   (((uint16_t)(((uint16_t)(x)) << WDOG_WMCR_PDE_SHIFT)) & WDOG_WMCR_PDE_MASK)
◆ WDOG_WCR_SRE [1/3]
#define WDOG_WCR_SRE (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_SRE_SHIFT)) & WDOG_WCR_SRE_MASK)
SRE - software reset extension, an option way to generate software reset 0b0..using original way to generate software reset (default) 0b1..using new way to generate software reset.
◆ WDOG_WCR_SRE [2/3]
SRE - Software Reset Extension, an optional way to generate software reset 0b0..using original way to generate software reset (default) 0b1..using new way to generate software reset.
◆ WDOG_WCR_SRE [3/3]
◆ WDOG_WCR_SRS [1/3]
#define WDOG_WCR_SRS (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_SRS_SHIFT)) & WDOG_WCR_SRS_MASK)
SRS - SRS 0b0..Assert system reset signal. 0b1..No effect on the system (Default).
◆ WDOG_WCR_SRS [2/3]
◆ WDOG_WCR_SRS [3/3]
◆ WDOG_WCR_WDA [1/3]
#define WDOG_WCR_WDA (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WDA_SHIFT)) & WDOG_WCR_WDA_MASK)
WDA - WDA 0b0..Assert WDOG_B output. 0b1..No effect on system (Default).
◆ WDOG_WCR_WDA [2/3]
◆ WDOG_WCR_WDA [3/3]
◆ WDOG_WCR_WDBG [1/3]
#define WDOG_WCR_WDBG (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WDBG_SHIFT)) & WDOG_WCR_WDBG_MASK)
WDBG - WDBG 0b0..Continue WDOG timer operation (Default). 0b1..Suspend the watchdog timer.
◆ WDOG_WCR_WDBG [2/3]
◆ WDOG_WCR_WDBG [3/3]
◆ WDOG_WCR_WDE [1/3]
#define WDOG_WCR_WDE (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WDE_SHIFT)) & WDOG_WCR_WDE_MASK)
WDE - WDE 0b0..Disable the Watchdog (Default). 0b1..Enable the Watchdog.
◆ WDOG_WCR_WDE [2/3]
◆ WDOG_WCR_WDE [3/3]
◆ WDOG_WCR_WDT [1/3]
#define WDOG_WCR_WDT (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WDT_SHIFT)) & WDOG_WCR_WDT_MASK)
WDT - WDT 0b0..No effect on WDOG_B (Default). 0b1..Assert WDOG_B upon a Watchdog Time-out event.
◆ WDOG_WCR_WDT [2/3]
◆ WDOG_WCR_WDT [3/3]
◆ WDOG_WCR_WDW [1/3]
#define WDOG_WCR_WDW (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WDW_SHIFT)) & WDOG_WCR_WDW_MASK)
WDW - WDW 0b0..Continue WDOG timer operation (Default). 0b1..Suspend WDOG timer operation.
◆ WDOG_WCR_WDW [2/3]
◆ WDOG_WCR_WDW [3/3]
◆ WDOG_WCR_WDZST [1/3]
#define WDOG_WCR_WDZST (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WDZST_SHIFT)) & WDOG_WCR_WDZST_MASK)
WDZST - WDZST 0b0..Continue timer operation (Default). 0b1..Suspend the watchdog timer.
◆ WDOG_WCR_WDZST [2/3]
◆ WDOG_WCR_WDZST [3/3]
◆ WDOG_WCR_WT [1/3]
#define WDOG_WCR_WT (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WCR_WT_SHIFT)) & WDOG_WCR_WT_MASK)
WT - WT 0b00000000..- 0.5 Seconds (Default). 0b00000001..- 1.0 Seconds. 0b00000010..- 1.5 Seconds. 0b00000011..- 2.0 Seconds. 0b11111111..- 128 Seconds.
◆ WDOG_WCR_WT [2/3]
◆ WDOG_WCR_WT [3/3]
◆ WDOG_WICR_WICT [1/3]
#define WDOG_WICR_WICT (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WICR_WICT_SHIFT)) & WDOG_WICR_WICT_MASK)
WICT - WICT 0b00000000..WICT[7:0] = Time duration between interrupt and time-out is 0 seconds. 0b00000001..WICT[7:0] = Time duration between interrupt and time-out is 0.5 seconds. 0b00000100..WICT[7:0] = Time duration between interrupt and time-out is 2 seconds (Default). 0b11111111..WICT[7:0] = Time duration between interrupt and time-out is 127.5 seconds.
◆ WDOG_WICR_WICT [2/3]
◆ WDOG_WICR_WICT [3/3]
◆ WDOG_WICR_WIE [1/3]
#define WDOG_WICR_WIE (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WICR_WIE_SHIFT)) & WDOG_WICR_WIE_MASK)
WIE - WIE 0b0..Disable Interrupt (Default). 0b1..Enable Interrupt.
◆ WDOG_WICR_WIE [2/3]
◆ WDOG_WICR_WIE [3/3]
◆ WDOG_WICR_WTIS [1/3]
#define WDOG_WICR_WTIS (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WICR_WTIS_SHIFT)) & WDOG_WICR_WTIS_MASK)
WTIS - WTIS 0b0..No interrupt has occurred (Default). 0b1..Interrupt has occurred
◆ WDOG_WICR_WTIS [2/3]
◆ WDOG_WICR_WTIS [3/3]
◆ WDOG_WMCR_PDE [1/3]
#define WDOG_WMCR_PDE (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WMCR_PDE_SHIFT)) & WDOG_WMCR_PDE_MASK)
PDE - PDE 0b0..Power Down Counter of WDOG is disabled. 0b1..Power Down Counter of WDOG is enabled (Default).
◆ WDOG_WMCR_PDE [2/3]
◆ WDOG_WMCR_PDE [3/3]
◆ WDOG_WRSR_POR [1/3]
#define WDOG_WRSR_POR (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WRSR_POR_SHIFT)) & WDOG_WRSR_POR_MASK)
POR - POR 0b0..Reset is not the result of a power on reset. 0b1..Reset is the result of a power on reset.
◆ WDOG_WRSR_POR [2/3]
◆ WDOG_WRSR_POR [3/3]
◆ WDOG_WRSR_SFTW [1/3]
#define WDOG_WRSR_SFTW (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WRSR_SFTW_SHIFT)) & WDOG_WRSR_SFTW_MASK)
SFTW - SFTW 0b0..Reset is not the result of a software reset. 0b1..Reset is the result of a software reset.
◆ WDOG_WRSR_SFTW [2/3]
◆ WDOG_WRSR_SFTW [3/3]
◆ WDOG_WRSR_TOUT [1/3]
#define WDOG_WRSR_TOUT (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WRSR_TOUT_SHIFT)) & WDOG_WRSR_TOUT_MASK)
TOUT - TOUT 0b0..Reset is not the result of a WDOG timeout. 0b1..Reset is the result of a WDOG timeout.
◆ WDOG_WRSR_TOUT [2/3]
◆ WDOG_WRSR_TOUT [3/3]
◆ WDOG_WSR_WSR [1/3]
#define WDOG_WSR_WSR (   x)    (((uint16_t)(((uint16_t)(x)) << WDOG_WSR_WSR_SHIFT)) & WDOG_WSR_WSR_MASK)
WSR - WSR 0b0101010101010101..Write to the Watchdog Service Register (WDOG_WSR). 0b1010101010101010..Write to the Watchdog Service Register (WDOG_WSR).
◆ WDOG_WSR_WSR [2/3]
◆ WDOG_WSR_WSR [3/3]
