RTEMS 6.1-rc5
#define __HAL_USART_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_USART_STATE_RESET)
 Reset USART handle state.
#define __HAL_USART_GET_FLAG(__HANDLE__, __FLAG__)   (((__HANDLE__)->Instance->ISR & (__FLAG__)) == (__FLAG__))
 Check whether the specified USART flag is set or not.
#define __HAL_USART_CLEAR_FLAG(__HANDLE__, __FLAG__)   ((__HANDLE__)->Instance->ICR = (__FLAG__))
 Clear the specified USART pending flag.
#define __HAL_USART_CLEAR_PEFLAG(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_PEF)
 Clear the USART PE pending flag.
#define __HAL_USART_CLEAR_FEFLAG(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_FEF)
 Clear the USART FE pending flag.
#define __HAL_USART_CLEAR_NEFLAG(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_NEF)
 Clear the USART NE pending flag.
#define __HAL_USART_CLEAR_OREFLAG(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_OREF)
 Clear the USART ORE pending flag.
#define __HAL_USART_CLEAR_IDLEFLAG(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_IDLEF)
 Clear the USART IDLE pending flag.
#define __HAL_USART_CLEAR_TXFECF(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_TXFECF)
 Clear the USART TX FIFO empty clear flag.
#define __HAL_USART_CLEAR_UDRFLAG(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_UDRF)
 Clear SPI slave underrun error flag.
#define __HAL_USART_ENABLE_IT(__HANDLE__, __INTERRUPT__)
 Enable the specified USART interrupt.
#define __HAL_USART_DISABLE_IT(__HANDLE__, __INTERRUPT__)
 Disable the specified USART interrupt.
#define __HAL_USART_GET_IT(__HANDLE__, __INTERRUPT__)
 Check whether the specified USART interrupt has occurred or not.
#define __HAL_USART_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Check whether the specified USART interrupt source is enabled or not.
#define __HAL_USART_CLEAR_IT(__HANDLE__, __IT_CLEAR__)   ((__HANDLE__)->Instance->ICR = (uint32_t)(__IT_CLEAR__))
 Clear the specified USART ISR flag, in setting the proper ICR register flag.
#define __HAL_USART_SEND_REQ(__HANDLE__, __REQ__)   ((__HANDLE__)->Instance->RQR |= (uint16_t)(__REQ__))
 Set a specific USART request flag.
#define __HAL_USART_ONE_BIT_SAMPLE_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR3|= USART_CR3_ONEBIT)
 Enable the USART one bit sample method.
#define __HAL_USART_ONE_BIT_SAMPLE_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR3 &= ~USART_CR3_ONEBIT)
 Disable the USART one bit sample method.
#define __HAL_USART_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR1 |= USART_CR1_UE)
 Enable USART.
#define __HAL_USART_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR1 &= ~USART_CR1_UE)
 Disable USART.
◆ __HAL_USART_CLEAR_FEFLAG
#define __HAL_USART_CLEAR_FEFLAG (   __HANDLE__)    __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_FEF)
Parameters
__HANDLE__specifies the USART Handle.
Return values
None
◆ __HAL_USART_CLEAR_FLAG
#define __HAL_USART_CLEAR_FLAG (   __HANDLE__,
  __FLAG__
Parameters
__FLAG__specifies the flag to check. This parameter can be any combination of the following values:
Return values
None
◆ __HAL_USART_CLEAR_IDLEFLAG
#define __HAL_USART_CLEAR_IDLEFLAG (   __HANDLE__)    __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_IDLEF)
Parameters
Return values
None
◆ __HAL_USART_CLEAR_IT
#define __HAL_USART_CLEAR_IT (   __HANDLE__,
  __IT_CLEAR__
Parameters
__IT_CLEAR__specifies the interrupt clear register flag that needs to be set to clear the corresponding interrupt. This parameter can be one of the following values:
Return values
None
◆ __HAL_USART_CLEAR_NEFLAG
#define __HAL_USART_CLEAR_NEFLAG (   __HANDLE__)    __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_NEF)
Parameters
Return values
None
◆ __HAL_USART_CLEAR_OREFLAG
#define __HAL_USART_CLEAR_OREFLAG (   __HANDLE__)    __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_OREF)
Parameters
Return values
None
◆ __HAL_USART_CLEAR_PEFLAG
#define __HAL_USART_CLEAR_PEFLAG (   __HANDLE__)    __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_PEF)
Parameters
Return values
None
◆ __HAL_USART_CLEAR_TXFECF
#define __HAL_USART_CLEAR_TXFECF (   __HANDLE__)    __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_TXFECF)
Parameters
Return values
None
◆ __HAL_USART_CLEAR_UDRFLAG
#define __HAL_USART_CLEAR_UDRFLAG (   __HANDLE__)    __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_UDRF)
Parameters
Return values
None
◆ __HAL_USART_DISABLE
#define __HAL_USART_DISABLE (   __HANDLE__)    ((__HANDLE__)->Instance->CR1 &= ~USART_CR1_UE)
Disable USART.
Parameters
Return values
None
◆ __HAL_USART_DISABLE_IT
#define __HAL_USART_DISABLE_IT (   __HANDLE__,
  __INTERRUPT__
Value:
(((((__INTERRUPT__) & USART_CR_MASK) >> USART_CR_POS) == 1U)?\
((__HANDLE__)->Instance->CR1 &= ~ (1U << ((__INTERRUPT__) & USART_IT_MASK))): \
((((__INTERRUPT__) & USART_CR_MASK) >> USART_CR_POS) == 2U)?\
((__HANDLE__)->Instance->CR2 &= ~ (1U << ((__INTERRUPT__) & USART_IT_MASK))): \
((__HANDLE__)->Instance->CR3 &= ~ (1U << ((__INTERRUPT__) & USART_IT_MASK))))
#define USART_IT_MASK
Definition: stm32h7xx_hal_usart.h:429
#define USART_CR_MASK
Definition: stm32h7xx_hal_usart.h:430
#define USART_CR_POS
Definition: stm32h7xx_hal_usart.h:431
Parameters
__INTERRUPT__specifies the USART interrupt source to disable. This parameter can be one of the following values:
Return values
None
◆ __HAL_USART_ENABLE
#define __HAL_USART_ENABLE (   __HANDLE__)    ((__HANDLE__)->Instance->CR1 |= USART_CR1_UE)
Enable USART.
Parameters
Return values
None
◆ __HAL_USART_ENABLE_IT
#define __HAL_USART_ENABLE_IT (   __HANDLE__,
  __INTERRUPT__
Value:
((__HANDLE__)->Instance->CR1 |= (1U << ((__INTERRUPT__) & USART_IT_MASK))): \
((__HANDLE__)->Instance->CR2 |= (1U << ((__INTERRUPT__) & USART_IT_MASK))): \
((__HANDLE__)->Instance->CR3 |= (1U << ((__INTERRUPT__) & USART_IT_MASK))))
Parameters
__INTERRUPT__specifies the USART interrupt source to enable. This parameter can be one of the following values:
Return values
None
◆ __HAL_USART_GET_FLAG
#define __HAL_USART_GET_FLAG (   __HANDLE__,
  __FLAG__
Parameters
__FLAG__specifies the flag to check. This parameter can be one of the following values:
Return values
Thenew state of FLAG (TRUE or FALSE).
◆ __HAL_USART_GET_IT
#define __HAL_USART_GET_IT (   __HANDLE__,
  __INTERRUPT__
Value:
((((__HANDLE__)->Instance->ISR\
& (0x01U << (((__INTERRUPT__) & USART_ISR_MASK)>>\
USART_ISR_POS))) != 0U) ? SET : RESET)
#define USART_ISR_POS
Definition: stm32h7xx_hal_usart.h:433
#define USART_ISR_MASK
Definition: stm32h7xx_hal_usart.h:432
Parameters
__INTERRUPT__specifies the USART interrupt source to check. This parameter can be one of the following values:
Return values
Thenew state of INTERRUPT (SET or RESET).
◆ __HAL_USART_GET_IT_SOURCE
#define __HAL_USART_GET_IT_SOURCE (   __HANDLE__,
  __INTERRUPT__
Value:
((((((((uint8_t)(__INTERRUPT__)) >> 0x05U) == 0x01U) ?\
(__HANDLE__)->Instance->CR1 : \
(((((uint8_t)(__INTERRUPT__)) >> 0x05U) == 0x02U) ?\
(__HANDLE__)->Instance->CR2 : \
(__HANDLE__)->Instance->CR3)) & (0x01U <<\
(((uint16_t)(__INTERRUPT__)) &\
USART_IT_MASK))) != 0U) ? SET : RESET)
Parameters
Return values
◆ __HAL_USART_ONE_BIT_SAMPLE_DISABLE
#define __HAL_USART_ONE_BIT_SAMPLE_DISABLE (   __HANDLE__)    ((__HANDLE__)->Instance->CR3 &= ~USART_CR3_ONEBIT)
Parameters
Return values
None
◆ __HAL_USART_ONE_BIT_SAMPLE_ENABLE
#define __HAL_USART_ONE_BIT_SAMPLE_ENABLE (   __HANDLE__)    ((__HANDLE__)->Instance->CR3|= USART_CR3_ONEBIT)
Parameters
Return values
None
◆ __HAL_USART_RESET_HANDLE_STATE
#define __HAL_USART_RESET_HANDLE_STATE (   __HANDLE__)    ((__HANDLE__)->State = HAL_USART_STATE_RESET)
Parameters
__HANDLE__USART handle.
Return values
None
◆ __HAL_USART_SEND_REQ
#define __HAL_USART_SEND_REQ (   __HANDLE__,
  __REQ__
Parameters
__REQ__specifies the request flag to set. This parameter can be one of the following values:
Return values
None
