RTEMS 6.1-rc5
Files | Data Structures | Functions
spec:/score/interr/val/terminate
Tests system termination procedure. More...
file  tc-terminate.c
file  tc-userext.h
 This header file provides functions used by corresponding test suite.
struct  FatalInfo
void * __real__CPU_Thread_Idle_body (void *arg)
void * __wrap__CPU_Thread_Idle_body (void *arg)
void FatalExtension0 (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code)
void FatalExtension1 (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code)
 T_TEST_CASE (ScoreInterrValTerminate)
This test case performs the following actions:
