RTEMS 6.1-rc5
Files | Data Structures | Macros | Functions | Variables
Region Manager
This group contains the Region Manager implementation. More...
file  region.h
 This header file defines the Region Manager API.
file  regiondata.h
 This header file provides data structures used by the implementation and the Application Configuration to define _Region_Information.
file  regionimpl.h
 This header file provides the implementation interfaces of the Region Manager.
file  region.c
 This source file contains a definition of the _Region_Information with zero objects.
file  regioncreate.c
 This source file contains the implementation of rtems_region_create() and the Region Manager system initialization.
file  regiondelete.c
 This source file contains the implementation of rtems_region_delete().
file  regionextend.c
 This source file contains the implementation of rtems_region_extend().
file  regiongetfreeinfo.c
 This source file contains the implementation of rtems_region_get_free_information().
file  regiongetinfo.c
 This source file contains the implementation of rtems_region_get_information().
file  regiongetsegment.c
 This source file contains the implementation of rtems_region_get_segment().
file  regiongetsegmentsize.c
 This source file contains the implementation of rtems_region_get_segment_size().
file  regionident.c
 This source file contains the implementation of rtems_region_ident().
file  regionprocessqueue.c
 This source file contains the implementation of _Region_Process_queue().
file  regionresizesegment.c
 This source file contains the implementation of rtems_region_resize_segment().
file  regionreturnsegment.c
 This source file contains the implementation of rtems_region_return_segment().
struct  Region_Control
#define REGION_INFORMATION_DEFINE(max)
 Macro to define the objects information for the Classic Region objects.
#define REGION_OF_THREAD_QUEUE_QUEUE(queue)    RTEMS_CONTAINER_OF( queue, Region_Control, Wait_queue.Queue )
void _Region_Process_queue (Region_Control *the_region)
 Process Region Queue.
Objects_Information _Region_Information
 The Classic Region objects information.
◆ REGION_INFORMATION_DEFINE
#define REGION_INFORMATION_DEFINE (   max)
Value:
_Region, \
OBJECTS_CLASSIC_API, \
OBJECTS_RTEMS_REGIONS, \
max, \
NULL \
#define OBJECTS_NO_STRING_NAME
Constant for the object information string name length to indicate that this object class has no stri...
Definition: objectdata.h:123
#define OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex)
Statically initializes an objects information.
Definition: objectdata.h:449
Definition: regiondata.h:60
This macro should only be used by <rtems/confdefs.h>.
Parameters
maxThe configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set).
◆ _Region_Process_queue()
void _Region_Process_queue ( Region_Control the_region)
This is a helper routine which is invoked any time memory is freed. It looks at the set of waiting tasks and attempts to satisfy all outstanding requests.
Parameters
[in]the_regionis the the region
