RTEMS 6.1-rc5
This group contains the Rate Monotonic Manager implementation. More...
Files | |
file | ratemon.h |
This header file defines the Rate-Monotonic Manager API. | |
file | ratemondata.h |
This header file provides data structures used by the implementation and the Application Configuration to define _Rate_monotonic_Information. | |
file | ratemonimpl.h |
This header file provides the implementation interfaces of the Rate Monotonic Manager. | |
file | ratemon.c |
This source file contains a definition of the _Rate_monotonic_Information with zero objects. | |
file | ratemoncancel.c |
This source file contains the implementation of rtems_rate_monotonic_cancel(). | |
file | ratemoncreate.c |
This source file contains the implementation of rtems_rate_monotonic_create(). | |
file | ratemondelete.c |
This source file contains the implementation of rtems_rate_monotonic_delete(). | |
file | ratemongetstatistics.c |
This source file contains the implementation of rtems_rate_monotonic_get_statistics(). | |
file | ratemongetstatus.c |
This source file contains the implementation of rtems_rate_monotonic_get_status(). | |
file | ratemonident.c |
This source file contains the implementation of rtems_rate_monotonic_ident(). | |
file | ratemonperiod.c |
This source file contains the implementation of rtems_rate_monotonic_period_states(). | |
file | ratemonreportstatistics.c |
This source file contains the implementation of rtems_rate_monotonic_report_statistics_with_plugin(). | |
file | ratemonresetall.c |
This source file contains the implementation of rtems_rate_monotonic_reset_all_statistics(). | |
file | ratemonresetstatistics.c |
This source file contains the implementation of rtems_rate_monotonic_reset_statistics(). | |
file | ratemontimeout.c |
This source file contains the implementation of _Rate_monotonic_Timeout(). | |
struct | Rate_monotonic_Statistics |
struct | Rate_monotonic_Control |
The following structure defines the control block used to manage each period. More... | |
#define | RATE_MONOTONIC_INFORMATION_DEFINE(max) |
Macro to define the objects information for the Classic Rate Monotonic objects. | |
#define | RATE_MONOTONIC_INTEND_TO_BLOCK ( THREAD_WAIT_CLASS_PERIOD | THREAD_WAIT_STATE_INTEND_TO_BLOCK ) |
#define | RATE_MONOTONIC_BLOCKED ( THREAD_WAIT_CLASS_PERIOD | THREAD_WAIT_STATE_BLOCKED ) |
void | _Rate_monotonic_Timeout (Watchdog_Control *watchdog) |
void | _Rate_monotonic_Get_status (const Rate_monotonic_Control *the_period, Timestamp_Control *wall_since_last_period, Timestamp_Control *cpu_since_last_period) |
Gets the rate monotonic CPU usage status. | |
void | _Rate_monotonic_Restart (Rate_monotonic_Control *the_period, Thread_Control *owner, ISR_lock_Context *lock_context) |
void | _Rate_monotonic_Cancel (Rate_monotonic_Control *the_period, Thread_Control *owner, ISR_lock_Context *lock_context) |
Objects_Information | _Rate_monotonic_Information |
The Classic Rate Monotonic objects information. | |
#define RATE_MONOTONIC_INFORMATION_DEFINE | ( | max | ) |
This macro should only be used by <rtems/confdefs.h>.
max | The configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set). |
void _Rate_monotonic_Get_status | ( | const Rate_monotonic_Control * | the_period, |
Timestamp_Control * | wall_since_last_period, | ||
Timestamp_Control * | cpu_since_last_period | ||
This routine is invoked to compute the elapsed wall time and cpu time for a period.
[in] | the_period | points to the period being operated upon. |
[out] | wall_since_last_period | is set to the wall time elapsed since the period was initiated. |
[out] | cpu_since_last_period | is set to the cpu time used by the owning thread since the period was initiated. |
