This group contains the Xilinx Triple Timer Counter (TTC) Clock Driver implementation.
More...
file | xttcps_hw.h |
file | xil-ttc.c |
| This source file contains a Clock Driver implementation using the Xilinx Triple Timer Counter (TTC).
#define | XTTCPS_HW_H /* by using protection macros */ |
#define | ARMA9 |
#define | Clock_driver_support_at_tick(arg) xil_ttc_clock_driver_support_at_tick(arg) |
#define | Clock_driver_support_initialize_hardware xil_ttc_clock_driver_support_initialize_hardware |
#define | Clock_driver_support_install_isr(isr) xil_ttc_clock_driver_support_install_isr(isr) |
uint32_t | _CPU_Counter_frequency (void) |
| Gets the current CPU counter frequency in Hz.
CPU_Counter_ticks | _CPU_Counter_read (void) |
| Gets the current CPU counter value.
| RTEMS_SYSINIT_ITEM (xil_ttc_initialize, RTEMS_SYSINIT_CPU_COUNTER, RTEMS_SYSINIT_ORDER_MIDDLE) |
Interval Value Register is the maximum value the counter will count up or down to.
#define | XTTCPS_INTERVAL_VAL_MASK 0x0000FFFFU |
◆ XTTCPS_CLK_CNTRL_EXT_EDGE_MASK
#define XTTCPS_CLK_CNTRL_EXT_EDGE_MASK 0x00000040U |
◆ XTTCPS_CLK_CNTRL_OFFSET
#define XTTCPS_CLK_CNTRL_OFFSET 0x00000000U |
◆ XTTCPS_CLK_CNTRL_PS_DISABLE
#define XTTCPS_CLK_CNTRL_PS_DISABLE 16U |
◆ XTTCPS_CLK_CNTRL_PS_EN_MASK
#define XTTCPS_CLK_CNTRL_PS_EN_MASK 0x00000001U |
◆ XTTCPS_CLK_CNTRL_PS_VAL_MASK
#define XTTCPS_CLK_CNTRL_PS_VAL_MASK 0x0000001EU |
◆ XTTCPS_CLK_CNTRL_PS_VAL_SHIFT
#define XTTCPS_CLK_CNTRL_PS_VAL_SHIFT 1U |
◆ XTTCPS_CLK_CNTRL_SRC_MASK
#define XTTCPS_CLK_CNTRL_SRC_MASK 0x00000020U |
◆ XTTCPS_CNT_CNTRL_DECR_MASK
#define XTTCPS_CNT_CNTRL_DECR_MASK 0x00000004U |
◆ XTTCPS_CNT_CNTRL_DIS_MASK
#define XTTCPS_CNT_CNTRL_DIS_MASK 0x00000001U |
◆ XTTCPS_CNT_CNTRL_EN_WAVE_MASK
#define XTTCPS_CNT_CNTRL_EN_WAVE_MASK 0x00000020U |
◆ XTTCPS_CNT_CNTRL_INT_MASK
#define XTTCPS_CNT_CNTRL_INT_MASK 0x00000002U |
◆ XTTCPS_CNT_CNTRL_MATCH_MASK
#define XTTCPS_CNT_CNTRL_MATCH_MASK 0x00000008U |
◆ XTTCPS_CNT_CNTRL_OFFSET
#define XTTCPS_CNT_CNTRL_OFFSET 0x0000000CU |
◆ XTTCPS_CNT_CNTRL_POL_WAVE_MASK
#define XTTCPS_CNT_CNTRL_POL_WAVE_MASK 0x00000040U |
◆ XTTCPS_CNT_CNTRL_RESET_VALUE
#define XTTCPS_CNT_CNTRL_RESET_VALUE 0x00000021U |
◆ XTTCPS_CNT_CNTRL_RST_MASK
#define XTTCPS_CNT_CNTRL_RST_MASK 0x00000010U |
◆ XTTCPS_COUNT_VALUE_MASK
#define XTTCPS_COUNT_VALUE_MASK 0x0000FFFFU |
◆ XTTCPS_COUNT_VALUE_OFFSET
#define XTTCPS_COUNT_VALUE_OFFSET 0x00000018U |
◆ XTTCPS_IER_OFFSET
#define XTTCPS_IER_OFFSET 0x00000060U |
Interrupt Enable Register
◆ XTTCPS_INTERVAL_VAL_MASK
#define XTTCPS_INTERVAL_VAL_MASK 0x0000FFFFU |
◆ XTTCPS_INTERVAL_VAL_OFFSET
#define XTTCPS_INTERVAL_VAL_OFFSET 0x00000024U |
◆ XTTCPS_ISR_OFFSET
#define XTTCPS_ISR_OFFSET 0x00000054U |
Interrupt Status Register
◆ XTTCPS_IXR_ALL_MASK
#define XTTCPS_IXR_ALL_MASK 0x0000001FU |
◆ XTTCPS_IXR_CNT_OVR_MASK
#define XTTCPS_IXR_CNT_OVR_MASK 0x00000010U |
◆ XTTCPS_IXR_INTERVAL_MASK
#define XTTCPS_IXR_INTERVAL_MASK 0x00000001U |
◆ XTTCPS_IXR_MATCH_0_MASK
#define XTTCPS_IXR_MATCH_0_MASK 0x00000002U |
◆ XTTCPS_IXR_MATCH_1_MASK
#define XTTCPS_IXR_MATCH_1_MASK 0x00000004U |
◆ XTTCPS_IXR_MATCH_2_MASK
#define XTTCPS_IXR_MATCH_2_MASK 0x00000008U |
◆ XTTCPS_MATCH_0_OFFSET
#define XTTCPS_MATCH_0_OFFSET 0x00000030U |
◆ XTTCPS_MATCH_1_OFFSET
#define XTTCPS_MATCH_1_OFFSET 0x0000003CU |
◆ XTTCPS_MATCH_2_OFFSET
#define XTTCPS_MATCH_2_OFFSET 0x00000048U |
◆ XTTCPS_MATCH_MASK
#define XTTCPS_MATCH_MASK 0x0000FFFFU |
◆ XTtcPs_Match_N_Offset
#define XTtcPs_Match_N_Offset |
MatchIndex | ) |
((u32)XTTCPS_MATCH_0_OFFSET + ((u32)(12U) * (u32)(MatchIndex))) |
Calculate a match register offset using the Match Register index.
- Parameters
MatchIndex | is the 0-2 value of the match register |
- Returns
- MATCH_N_OFFSET.
- Note
- C-style signature: u32 XTtcPs_Match_N_Offset(u8 MatchIndex)
◆ XTTCPS_NUM_MATCH_REG
#define XTTCPS_NUM_MATCH_REG 3U |
◆ XTtcPs_ReadReg
#define XTtcPs_ReadReg |
BaseAddress, |
RegOffset |
| (Xil_In32((BaseAddress) + (u32)(RegOffset))) |
Read the given Timer Counter register.
- Parameters
BaseAddress | is the base address of the timer counter device. |
RegOffset | is the register offset to be read |
- Returns
- The 32-bit value of the register
- Note
- C-style signature: u32 XTtcPs_ReadReg(u32 BaseAddress, u32 RegOffset)
◆ XTtcPs_WriteReg
#define XTtcPs_WriteReg |
BaseAddress, |
RegOffset, |
Data |
| (Xil_Out32((BaseAddress) + (u32)(RegOffset), (u32)(Data))) |
Write the given Timer Counter register.
- Parameters
RegOffset | is the register offset to be written |
Data | is the 32-bit value to write to the register |
- Returns
- None.
- Note
- C-style signature: void XTtcPs_WriteReg(XTtcPs BaseAddress, u32 RegOffset,
u32 Data)
◆ _CPU_Counter_frequency()
uint32_t _CPU_Counter_frequency |
void |
- Returns
- Returns the current CPU counter frequency in Hz.
◆ _CPU_Counter_read()
CPU_Counter_ticks _CPU_Counter_read |
void |
A CPU counter should be some monotonically increasing free-running counter. It ticks usually with a frequency close to the CPU or system bus clock. The counter should not be affected by power saving states so that it can be used for timestamps. The CPU counter should be initialized at the RTEMS_SYSINIT_CPU_COUNTER initialization step if necessary. If RTEMS_PROFILING is enabled, the CPU counter may have to work very early in the system initialization to avoid invalid profiling statistics.
- Returns
- Returns the current CPU counter value.
