RTEMS 6.1-rc5
Modules | Files | Data Structures | Typedefs
This group contains the GRPCI2 interfaces. More...
 AHB master to PCI memory address mapping register (AHBM2PCI)
 This group contains register bit definitions.
 AHB to PCI mapping for PCI IO (AHB2PCI)
 Control register (CTRL)
 DMA channel active register (DMACHAN)
 DMA control and status register (DMACTRL)
 DMA descriptor base address register (DMABASE)
 PCI BAR to AHB address mapping register (PCI2AHB)
 PCI master prefetch burst limit (BCIM)
 PCI trace AD mask register (TADM)
 PCI trace AD pattern register (TADP)
 PCI trace Control and Status register (TCTRC)
 PCI trace Ctrl signal mask register (TCM)
 PCI trace Ctrl signal pattern register (TCP)
 PCI trace PCI AD state register (TADS)
 PCI trace PCI Ctrl signal state register (TCS)
 PCI trace counter and mode register (TMODE)
 Status and Capability register (STATCAP)
file  grpci2-regs.h
 This header file defines the GRPCI2 register block interface.
struct  grpci2
 This structure defines the GRPCI2 register block memory map. More...
typedef struct grpci2 grpci2
