RTEMS 6.1-rc5
Files | Macros | Typedefs | Functions
MCF5329 Board Support Package. More...
file  bsp.h
 Global BSP definitions.
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "fec0"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_fec_driver_attach
#define CONSOLE_PORT   0
#define FEC_IRQ_LEVEL   4
#define PIT3_IRQ_LEVEL   4
#define UART0_IRQ_LEVEL   3
#define UART1_IRQ_LEVEL   3
#define UART2_IRQ_LEVEL   3
typedef volatile unsigned char vuint8
typedef volatile unsigned short vuint16
typedef volatile unsigned long vuint32
int rtems_fec_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching)
uint32_t bsp_get_CPU_clock_speed (void)
uint32_t bsp_get_BUS_clock_speed (void)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
void Init5329 (void)
◆ CONSOLE_PORT
User Definable configuration
Typedef Documentation
◆ vuint8
Hardware data structure headers
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
