RTEMS 6.1-rc5
Xilinx Zynq Board Support Package. More...
Modules | |
Interrupt Support | |
Interrupt Support. | |
TM27 Test Support | |
Interrupt Mechanisms for tm27 test. | |
Files | |
file | bsp.h |
Global BSP definitions. | |
file | bspreset.c |
This source file contains the implementation of bsp_reset(). | |
file | bspsmp.c |
This source file contains the implementation of _CPU_SMP_Start_processor() for Xilinx Zynq 7000 devices. | |
file | bspstart.c |
This source file contains the implementation of zynq_clock_cpu_1x() and bsp_start(). | |
file | bspstarthooks.c |
This source file contains the implementation of bsp_start_hook_0() and bsp_start_hook_1(). | |
file | bspstartmmu.c |
This source file contains the implementation of zynq_setup_mmu_and_cache(). | |
BSP_START_TEXT_SECTION void | zynq_setup_mmu_and_cache (void) |
Zynq specific set up of the MMU. | |
uint32_t | zynq_clock_cpu_1x (void) |
BSP_START_TEXT_SECTION void zynq_setup_mmu_and_cache | ( | void | ) |
Provide in the application to override the defaults in the BSP. Note the defaults do not map in the GP0 and GP1 AXI ports. You should add the specific regions that map into your PL rather than just open the whole of the GP[01] address space up.
