RTEMS 6.1-rc5
MIF_AUTHEN_CTRL - MIF Authentication Control | |
#define | PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_MASK (0x100000U) |
#define | PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_SHIFT (20U) |
#define | PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG(x) (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_SHIFT)) & PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_MASK) |
MIF_MLPL_SLEEP - MIF MLPL control of SLEEP | |
#define | PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_MASK (0xFFFFU) |
#define | PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_SHIFT (0U) |
#define | PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL(x) (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_MASK) |
MIF_MLPL_IG - MIF MLPL control of IG | |
#define | PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_MASK (0xFFFFU) |
#define | PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_SHIFT (0U) |
#define | PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL(x) (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_MASK) |
MIF_MLPL_LS - MIF MLPL control of LS | |
#define | PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_MASK (0xFFFFU) |
#define | PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_SHIFT (0U) |
#define | PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL(x) (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_MASK) |
MIF_MLPL_HS - MIF MLPL control of HS | |
#define | PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_MASK (0xFFFFU) |
#define | PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_SHIFT (0U) |
#define | PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL(x) (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_MASK) |
MIF_MLPL_STDBY - MIF MLPL control of STDBY | |
#define | PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_MASK (0xFFFFU) |
#define | PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_SHIFT (0U) |
#define | PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL(x) (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_MASK) |
MIF_MLPL_ARR_PDN - MIF MLPL control of array power down | |
#define | PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_MASK (0xFFFFU) |
#define | PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_SHIFT (0U) |
#define | PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL(x) (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_MASK) |
MIF_MLPL_PER_PDN - MIF MLPL control of peripheral power down | |
#define | PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_MASK (0xFFFFU) |
#define | PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_SHIFT (0U) |
#define | PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL(x) (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_MASK) |
MIF_MLPL_INITN - MIF MLPL control of INITN | |
#define | PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_MASK (0xFFFFU) |
#define | PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_SHIFT (0U) |
#define | PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL(x) (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_MASK) |
#define | PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_MASK (0x80000000U) |
#define | PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_SHIFT (31U) |
#define | PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK(x) (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_SHIFT)) & PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_MASK) |
MIF_MLPL_ISO - MIF MLPL control of isolation enable | |
#define | PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_MASK (0xFFFFU) |
#define | PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_SHIFT (0U) |
#define | PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL(x) (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_MASK) |
#define PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_SHIFT)) & PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_MASK) |
LOCK_CFG - Configuration lock
#define PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_MASK) |
MLPL_CTRL - Signal behavior at each MLPL
#define PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_MASK) |
#define PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_MASK) |
#define PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_SHIFT)) & PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_MASK) |
BYPASS_VDD_OK - Bypass vdd_ok. This field is locked by AUTHEN_CTRL[LOCK_CFG] field.
#define PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_MASK) |
#define PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_MASK) |
#define PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_MASK) |
#define PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_MASK) |
#define PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_MASK) |
#define PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_MASK) |
