RTEMS 6.1-rc5
#define MU_TR_COUNT   (4U)
#define MU_RR_COUNT   (4U)
TR - Processor B Transmit Register 0..Processor B Transmit Register 3
#define MU_TR_DATA_MASK   (0xFFFFFFFFU)
#define MU_TR_DATA_SHIFT   (0U)
#define MU_TR_DATA(x)   (((uint32_t)(((uint32_t)(x)) << MU_TR_DATA_SHIFT)) & MU_TR_DATA_MASK)
RR - Processor B Receive Register 0..Processor B Receive Register 3
#define MU_RR_DATA_MASK   (0xFFFFFFFFU)
#define MU_RR_DATA_SHIFT   (0U)
#define MU_RR_DATA(x)   (((uint32_t)(((uint32_t)(x)) << MU_RR_DATA_SHIFT)) & MU_RR_DATA_MASK)
SR - Processor B Status Register
#define MU_SR_Fn_MASK   (0x7U)
#define MU_SR_Fn_SHIFT   (0U)
#define MU_SR_Fn(x)   (((uint32_t)(((uint32_t)(x)) << MU_SR_Fn_SHIFT)) & MU_SR_Fn_MASK)
#define MU_SR_EP_MASK   (0x10U)
#define MU_SR_EP_SHIFT   (4U)
#define MU_SR_EP(x)   (((uint32_t)(((uint32_t)(x)) << MU_SR_EP_SHIFT)) & MU_SR_EP_MASK)
#define MU_SR_RS_MASK   (0x80U)
#define MU_SR_RS_SHIFT   (7U)
#define MU_SR_RS(x)   (((uint32_t)(((uint32_t)(x)) << MU_SR_RS_SHIFT)) & MU_SR_RS_MASK)
#define MU_SR_FUP_MASK   (0x100U)
#define MU_SR_FUP_SHIFT   (8U)
#define MU_SR_FUP(x)   (((uint32_t)(((uint32_t)(x)) << MU_SR_FUP_SHIFT)) & MU_SR_FUP_MASK)
#define MU_SR_TEn_MASK   (0xF00000U)
#define MU_SR_TEn_SHIFT   (20U)
#define MU_SR_TEn(x)   (((uint32_t)(((uint32_t)(x)) << MU_SR_TEn_SHIFT)) & MU_SR_TEn_MASK)
#define MU_SR_RFn_MASK   (0xF000000U)
#define MU_SR_RFn_SHIFT   (24U)
#define MU_SR_RFn(x)   (((uint32_t)(((uint32_t)(x)) << MU_SR_RFn_SHIFT)) & MU_SR_RFn_MASK)
#define MU_SR_GIPn_MASK   (0xF0000000U)
#define MU_SR_GIPn_SHIFT   (28U)
#define MU_SR_GIPn(x)   (((uint32_t)(((uint32_t)(x)) << MU_SR_GIPn_SHIFT)) & MU_SR_GIPn_MASK)
CR - Processor B Control Register
#define MU_CR_Fn_MASK   (0x7U)
#define MU_CR_Fn_SHIFT   (0U)
#define MU_CR_Fn(x)   (((uint32_t)(((uint32_t)(x)) << MU_CR_Fn_SHIFT)) & MU_CR_Fn_MASK)
#define MU_CR_GIRn_MASK   (0xF0000U)
#define MU_CR_GIRn_SHIFT   (16U)
#define MU_CR_GIRn(x)   (((uint32_t)(((uint32_t)(x)) << MU_CR_GIRn_SHIFT)) & MU_CR_GIRn_MASK)
#define MU_CR_TIEn_MASK   (0xF00000U)
#define MU_CR_TIEn_SHIFT   (20U)
#define MU_CR_TIEn(x)   (((uint32_t)(((uint32_t)(x)) << MU_CR_TIEn_SHIFT)) & MU_CR_TIEn_MASK)
#define MU_CR_RIEn_MASK   (0xF000000U)
#define MU_CR_RIEn_SHIFT   (24U)
#define MU_CR_RIEn(x)   (((uint32_t)(((uint32_t)(x)) << MU_CR_RIEn_SHIFT)) & MU_CR_RIEn_MASK)
#define MU_CR_GIEn_MASK   (0xF0000000U)
#define MU_CR_GIEn_SHIFT   (28U)
#define MU_CR_GIEn(x)   (((uint32_t)(((uint32_t)(x)) << MU_CR_GIEn_SHIFT)) & MU_CR_GIEn_MASK)
TR - Processor A Transmit Register 0..Processor A Transmit Register 3
RR - Processor A Receive Register 0..Processor A Receive Register 3
SR - Processor A Status Register
CR - Processor A Control Register
#define MU_CR_MUR_MASK   (0x20U)
#define MU_CR_MUR_SHIFT   (5U)
#define MU_CR_MUR(x)   (((uint32_t)(((uint32_t)(x)) << MU_CR_MUR_SHIFT)) & MU_CR_MUR_MASK)
◆ MU_CR_Fn [1/2]
#define MU_CR_Fn (   x)    (((uint32_t)(((uint32_t)(x)) << MU_CR_Fn_SHIFT)) & MU_CR_Fn_MASK)
Fn - Fn 0b000..Clears the Fn bit in the MUA.SR register. 0b001..Sets the Fn bit in the MUA.SR register.
◆ MU_CR_Fn [2/2]
Fn - Fn 0b000..N/A. Self clearing bit (default). 0b001..Asserts the Processor A MU reset.
◆ MU_CR_GIEn [1/2]
#define MU_CR_GIEn (   x)    (((uint32_t)(((uint32_t)(x)) << MU_CR_GIEn_SHIFT)) & MU_CR_GIEn_MASK)
GIEn - GIEn 0b0000..Disables Processor B General Interrupt n. (default) 0b0001..Enables Processor B General Interrupt n.
◆ MU_CR_GIEn [2/2]
GIEn - GIEn 0b0000..Disables Processor A General Interrupt n. (default) 0b0001..Enables Processor A General Interrupt n.
◆ MU_CR_GIRn [1/2]
#define MU_CR_GIRn (   x)    (((uint32_t)(((uint32_t)(x)) << MU_CR_GIRn_SHIFT)) & MU_CR_GIRn_MASK)
GIRn - GIRn 0b0000..Processor B General Interrupt n is not requested to the Processor A (default). 0b0001..Processor B General Interrupt n is requested to the Processor A.
◆ MU_CR_GIRn [2/2]
GIRn - GIRn 0b0000..Processor A General Interrupt n is not requested to the Processor B (default). 0b0001..Processor A General Interrupt n is requested to the Processor B.
◆ MU_CR_MUR
#define MU_CR_MUR (   x)    (((uint32_t)(((uint32_t)(x)) << MU_CR_MUR_SHIFT)) & MU_CR_MUR_MASK)
MUR - MUR 0b0..N/A. Self clearing bit (default). 0b1..Asserts the Processor A MU reset.
◆ MU_CR_RIEn [1/2]
#define MU_CR_RIEn (   x)    (((uint32_t)(((uint32_t)(x)) << MU_CR_RIEn_SHIFT)) & MU_CR_RIEn_MASK)
RIEn - RIEn 0b0000..Disables Processor B Receive Interrupt n. (default) 0b0001..Enables Processor B Receive Interrupt n.
◆ MU_CR_RIEn [2/2]
RIEn - RIEn 0b0000..Disables Processor A Receive Interrupt n. (default) 0b0001..Enables Processor A Receive Interrupt n.
◆ MU_CR_TIEn [1/2]
#define MU_CR_TIEn (   x)    (((uint32_t)(((uint32_t)(x)) << MU_CR_TIEn_SHIFT)) & MU_CR_TIEn_MASK)
TIEn - TIEn 0b0000..Disables Processor B Transmit Interrupt n. (default) 0b0001..Enables Processor B Transmit Interrupt n.
◆ MU_CR_TIEn [2/2]
TIEn - TIEn 0b0000..Disables Processor A Transmit Interrupt n. (default) 0b0001..Enables Processor A Transmit Interrupt n.
◆ MU_RR_DATA [1/2]
#define MU_RR_DATA (   x)    (((uint32_t)(((uint32_t)(x)) << MU_RR_DATA_SHIFT)) & MU_RR_DATA_MASK)
DATA - RR3
◆ MU_RR_DATA [2/2]
DATA - RR3
◆ MU_SR_EP [1/2]
#define MU_SR_EP (   x)    (((uint32_t)(((uint32_t)(x)) << MU_SR_EP_SHIFT)) & MU_SR_EP_MASK)
EP - EP 0b0..The Processor B-side event is not pending (default). 0b1..The Processor B-side event is pending.
◆ MU_SR_EP [2/2]
EP - EP 0b0..The Processor A-side event is not pending (default). 0b1..The Processor A-side event is pending.
◆ MU_SR_Fn [1/2]
#define MU_SR_Fn (   x)    (((uint32_t)(((uint32_t)(x)) << MU_SR_Fn_SHIFT)) & MU_SR_Fn_MASK)
Fn - Fn 0b000..ABFn bit in MUA.CR register is written 0 (default). 0b001..ABFn bit in MUA.CR register is written 1.
◆ MU_SR_Fn [2/2]
Fn - Fn 0b000..BAFn bit in MUB.CR register is written 0 (default). 0b001..BAFn bit in MUB.CR register is written 1.
◆ MU_SR_FUP [1/2]
#define MU_SR_FUP (   x)    (((uint32_t)(((uint32_t)(x)) << MU_SR_FUP_SHIFT)) & MU_SR_FUP_MASK)
FUP - FUP 0b0..No flags updated, initiated by the Processor B, in progress (default) 0b1..Processor B initiated flags update, processing
◆ MU_SR_FUP [2/2]
FUP - FUP 0b0..No flags updated, initiated by the Processor A, in progress (default) 0b1..Processor A initiated flags update, processing
◆ MU_SR_GIPn [1/2]
#define MU_SR_GIPn (   x)    (((uint32_t)(((uint32_t)(x)) << MU_SR_GIPn_SHIFT)) & MU_SR_GIPn_MASK)
GIPn - GIPn 0b0000..Processor B general purpose interrupt n is not pending. (default) 0b0001..Processor B general purpose interrupt n is pending.
◆ MU_SR_GIPn [2/2]
GIPn - GIPn 0b0000..Processor A general purpose interrupt n is not pending. (default) 0b0001..Processor A general purpose interrupt n is pending.
◆ MU_SR_RFn [1/2]
#define MU_SR_RFn (   x)    (((uint32_t)(((uint32_t)(x)) << MU_SR_RFn_SHIFT)) & MU_SR_RFn_MASK)
RFn - RFn 0b0000..MUB.RRn register is not full (default). 0b0001..MUB.RRn register has received data from MUA.TRn register and is ready to be read by the Processor B.
◆ MU_SR_RFn [2/2]
RFn - RFn 0b0000..MUA.RRn register is not full (default). 0b0001..MUA.RRn register has received data from MUB.TRn register and is ready to be read by the Processor A.
◆ MU_SR_RS [1/2]
#define MU_SR_RS (   x)    (((uint32_t)(((uint32_t)(x)) << MU_SR_RS_SHIFT)) & MU_SR_RS_MASK)
RS - RS 0b0..The Processor A or the Processor A-side of the MU is not in reset. 0b1..The Processor A or the Processor A-side of the MU is in reset.
◆ MU_SR_RS [2/2]
RS - RS 0b0..The Processor B-side of the MU is not in reset. 0b1..The Processor B-side of the MU is in reset.
◆ MU_SR_TEn [1/2]
#define MU_SR_TEn (   x)    (((uint32_t)(((uint32_t)(x)) << MU_SR_TEn_SHIFT)) & MU_SR_TEn_MASK)
TEn - TEn 0b0000..MUB.TRn register is not empty. 0b0001..MUB.TRn register is empty (default).
◆ MU_SR_TEn [2/2]
TEn - TEn 0b0000..MUA.TRn register is not empty. 0b0001..MUA.TRn register is empty (default).
◆ MU_TR_DATA [1/2]
#define MU_TR_DATA (   x)    (((uint32_t)(((uint32_t)(x)) << MU_TR_DATA_SHIFT)) & MU_TR_DATA_MASK)
DATA - TR3
◆ MU_TR_DATA [2/2]
DATA - TR3
