This group contains the Interrupt Manager implementation parts specific to the ARM Generic Interrupt Controller.
More...
#define | ARM_GIC_IRQ_SGI_0 0 |
#define | ARM_GIC_IRQ_SGI_1 1 |
#define | ARM_GIC_IRQ_SGI_2 2 |
#define | ARM_GIC_IRQ_SGI_3 3 |
#define | ARM_GIC_IRQ_SGI_5 5 |
#define | ARM_GIC_IRQ_SGI_6 6 |
#define | ARM_GIC_IRQ_SGI_7 7 |
#define | ARM_GIC_IRQ_SGI_8 8 |
#define | ARM_GIC_IRQ_SGI_9 9 |
#define | ARM_GIC_IRQ_SGI_10 10 |
#define | ARM_GIC_IRQ_SGI_11 11 |
#define | ARM_GIC_IRQ_SGI_12 12 |
#define | ARM_GIC_IRQ_SGI_13 13 |
#define | ARM_GIC_IRQ_SGI_14 14 |
#define | ARM_GIC_IRQ_SGI_15 15 |
#define | ARM_GIC_IRQ_SGI_LAST 15 |
#define | ARM_GIC_IRQ_PPI_LAST 31 |
#define | ARM_GIC_DIST ((volatile gic_dist *) BSP_ARM_GIC_DIST_BASE) |
#define | GIC_ID_TO_ONE_BIT_REG_INDEX(id) ((id) >> 5) |
#define | GIC_ID_TO_ONE_BIT_REG_BIT(id) (1U << ((id) & 0x1fU)) |
#define | GIC_ID_TO_TWO_BITS_REG_INDEX(id) ((id) >> 4) |
#define | GIC_ID_TO_TWO_BITS_REG_OFFSET(id) (((id) & 0xfU) << 1) |
#define | PRIORITY_DEFAULT 127 |
#define | MPIDR_AFFINITY2(val) BSP_FLD64(val, 16, 23) |
#define | MPIDR_AFFINITY2_GET(reg) BSP_FLD64GET(reg, 16, 23) |
#define | MPIDR_AFFINITY2_SET(reg, val) BSP_FLD64SET(reg, val, 16, 23) |
#define | MPIDR_AFFINITY1(val) BSP_FLD64(val, 8, 15) |
#define | MPIDR_AFFINITY1_GET(reg) BSP_FLD64GET(reg, 8, 15) |
#define | MPIDR_AFFINITY1_SET(reg, val) BSP_FLD64SET(reg, val, 8, 15) |
#define | MPIDR_AFFINITY0(val) BSP_FLD64(val, 0, 7) |
#define | MPIDR_AFFINITY0_GET(reg) BSP_FLD64GET(reg, 0, 7) |
#define | MPIDR_AFFINITY0_SET(reg, val) BSP_FLD64SET(reg, val, 0, 7) |
#define | ICC_SGIR_AFFINITY3(val) BSP_FLD64(val, 48, 55) |
#define | ICC_SGIR_AFFINITY3_GET(reg) BSP_FLD64GET(reg, 48, 55) |
#define | ICC_SGIR_AFFINITY3_SET(reg, val) BSP_FLD64SET(reg, val, 48, 55) |
#define | ICC_SGIR_IRM BSP_BIT32(40) |
#define | ICC_SGIR_AFFINITY2(val) BSP_FLD64(val, 32, 39) |
#define | ICC_SGIR_AFFINITY2_GET(reg) BSP_FLD64GET(reg, 32, 39) |
#define | ICC_SGIR_AFFINITY2_SET(reg, val) BSP_FLD64SET(reg, val, 32, 39) |
#define | ICC_SGIR_INTID(val) BSP_FLD64(val, 24, 27) |
#define | ICC_SGIR_INTID_GET(reg) BSP_FLD64GET(reg, 24, 27) |
#define | ICC_SGIR_INTID_SET(reg, val) BSP_FLD64SET(reg, val, 24, 27) |
#define | ICC_SGIR_AFFINITY1(val) BSP_FLD64(val, 16, 23) |
#define | ICC_SGIR_AFFINITY1_GET(reg) BSP_FLD64GET(reg, 16, 23) |
#define | ICC_SGIR_AFFINITY1_SET(reg, val) BSP_FLD64SET(reg, val, 16, 23) |
#define | ICC_SGIR_CPU_TARGET_LIST(val) BSP_FLD64(val, 0, 15) |
#define | ICC_SGIR_CPU_TARGET_LIST_GET(reg) BSP_FLD64GET(reg, 0, 15) |
#define | ICC_SGIR_CPU_TARGET_LIST_SET(reg, val) BSP_FLD64SET(reg, val, 0, 15) |
#define | ICC_IGRPEN0_EL1 "S3_0_C12_C12_6, %0" |
#define | ICC_IGRPEN1_EL1 "S3_0_C12_C12_7, %0" |
#define | ICC_IGRPEN1_EL3 "S3_6_C12_C12_7, %0" |
#define | ICC_IGRPEN0 ICC_IGRPEN0_EL1 |
#define | ICC_IGRPEN1 ICC_IGRPEN1_EL1 |
#define | ICC_PMR "S3_0_C4_C6_0, %0" |
#define | ICC_EOIR1 "S3_0_C12_C12_1, %0" |
#define | ICC_SRE "S3_0_C12_C12_5, %0" |
#define | ICC_BPR0 "S3_0_C12_C8_3, %0" |
#define | ICC_BPR1 "S3_0_C12_C12_3, %0" |
#define | ICC_CTLR "S3_0_C12_C12_4, %0" |
#define | ICC_IAR1 "%0, S3_0_C12_C12_0" |
#define | MPIDR "%0, mpidr_el1" |
#define | MPIDR_AFFINITY3(val) BSP_FLD64(val, 32, 39) |
#define | MPIDR_AFFINITY3_GET(reg) BSP_FLD64GET(reg, 32, 39) |
#define | MPIDR_AFFINITY3_SET(reg, val) BSP_FLD64SET(reg, val, 32, 39) |
#define | ICC_SGI1 "S3_0_C12_C11_5, %0" |
#define | WRITE64_SR(SR_NAME, VALUE) __asm__ volatile("msr " SR_NAME " \n" : : "r" (VALUE) ); |
#define | WRITE_SR(SR_NAME, VALUE) WRITE64_SR(SR_NAME, VALUE) |
#define | READ_SR(SR_NAME) |
