RTEMS 6.1-rc5
- o -
- o6_sp : Context_Control
- o7 : Context_Control
- OAR1 : I2C_TypeDef
- OAR2 : I2C_TypeDef
- obj : rtems_rtl_tramp_reloc, rtems_rtl_unresolv_reloc
- obj_num : rtems_rtl_obj
- obj_type : drvmgr_bus, drvmgr_dev, drvmgr_drv
- Object : _Thread_Control, Barrier_Control, Dual_ported_memory_Control, Message_queue_Control, Partition_Control, POSIX_Keys_Control, Rate_monotonic_Control, Semaphore_Control, Thread_Proxy_control, Timer_Control
- object_blocks : Objects_Information
- object_create : POSIX_Shm_Object_operations
- object_delete : POSIX_Shm_Object_operations
- object_mmap : POSIX_Shm_Object_operations
- object_read : POSIX_Shm_Object_operations
- object_resize : POSIX_Shm_Object_operations
- object_size : Objects_Information
- objects : rtems_rtl_data
- Objects : Thread_Information
- objects_per_block : Objects_Information
- obtain_status : RtemsSemReqDelete_Context
- obtained : _Regulator_Statistics, rtems_regulator_statistics
- OCFastMode : TIM_OC_InitTypeDef
- ocharcnt : grspwrouter_portstats
- OCIdleState : TIM_OC_InitTypeDef, TIM_OnePulse_InitTypeDef
- OCMode : TIM_OC_InitTypeDef, TIM_OnePulse_InitTypeDef
- OCNIdleState : TIM_OC_InitTypeDef, TIM_OnePulse_InitTypeDef
- OCNPolarity : TIM_OC_InitTypeDef, TIM_OnePulse_InitTypeDef
- OCOLR : DMA2D_TypeDef
- OCPolarity : TIM_OC_InitTypeDef, TIM_OnePulse_InitTypeDef
- OCR : GPT_Type
- Ocram1EndAddress : _mecc_config
- Ocram1StartAddress : _mecc_config
- Ocram2EndAddress : _mecc_config
- Ocram2StartAddress : _mecc_config
- OCRAM_ECC_MULTI_ERROR_ADDR : FLEXRAM_Type
- OCRAM_ECC_MULTI_ERROR_DATA_LSB : FLEXRAM_Type
- OCRAM_ECC_MULTI_ERROR_DATA_MSB : FLEXRAM_Type
- OCRAM_ECC_MULTI_ERROR_INFO : FLEXRAM_Type
- OCRAM_ECC_SINGLE_ERROR_ADDR : FLEXRAM_Type
- OCRAM_ECC_SINGLE_ERROR_DATA_LSB : FLEXRAM_Type
- OCRAM_ECC_SINGLE_ERROR_DATA_MSB : FLEXRAM_Type
- OCRAM_ECC_SINGLE_ERROR_INFO : FLEXRAM_Type
- OCRAM_MAGIC_ADDR : FLEXRAM_Type
- OCRAM_PIPELINE_STATUS : FLEXRAM_Type
- ocramBankNum : _flexram_allocate_ram
- OCTRL : PWM_Type
- ODISR : HRTIM_Common_TypeDef
- ODR : GPIO_TypeDef
- ODSR : HRTIM_Common_TypeDef
- OEM_AppliID : HAL_MMC_CardCIDTypeDef, HAL_SD_CardCIDTypeDef
- OemData : RTEMS_PACKED
- OEMName : msdos_format_request_param_t
- OemProductNamePtr : RTEMS_PACKED
- OemProductRevPtr : RTEMS_PACKED
- OemSoftwareRev : RTEMS_PACKED
- OemStringPtr : RTEMS_PACKED
- OemVendorNamePtr : RTEMS_PACKED
- OENR : HRTIM_Common_TypeDef
- offset : _GmacRxDescriptor::_GmacRxStatus::_GmacRxStatusBM, _mem_align_control_block, _rtems_rfs_inode_handle
- Offset : ADC_ChannelConfTypeDef, DFSDM_Channel_InitTypeDef
- offset : rtems_fdisk_segment_desc, rtems_fdt_index_entry, rtems_flashdev_region, RTEMS_PACKED, rtems_rfs_block_size_s, rtems_rtl_archive_obj_data, rtems_rtl_obj_cache, rtems_rtl_obj_cpmp, rtems_rtl_obj_sect, rtems_rtl_tls_offset, rtl_unresolved_name_data, section_detail
- Offset : XNandPsu_BadBlockPattern
- OffsetNumber : ADC_ChannelConfTypeDef
- OffsetRightShift : ADC_ChannelConfTypeDef
- OffsetSignedSaturation : ADC_ChannelConfTypeDef
- offsetValue : _adc_offest_config
- OffStateIDLEMode : TIM_BreakDeadTimeConfigTypeDef
- OffStateRunMode : TIM_BreakDeadTimeConfigTypeDef
- OFR1 : ADC_TypeDef
- OFR2 : ADC_TypeDef
- OFR3 : ADC_TypeDef
- OFR4 : ADC_TypeDef
- OFS : ADC_Type
- ofs : drvmgr_list
- old_priority : RtemsSemReqSetPriority_Context, RtemsTaskReqSetPriority_Context
- old_priority_obj : RtemsTaskReqSetPriority_Context
- old_priority_value : RtemsSemReqSetPriority_Context
- OMAR : DMA2D_TypeDef
- oname : rtems_rtl_obj, rtems_rtl_obj_print
- OneBitSampling : SMARTCARD_InitTypeDef, UART_InitTypeDef
- online : RtemsSchedulerReqAddProcessor_Context
- oob_read : rtems_jffs2_flash_control
- oob_write : rtems_jffs2_flash_control
- ooffset : rtems_rtl_obj
- OOR : DMA2D_TypeDef
- op_code : ALT_QSPI_DEV_INST_CONFIG_s
- op_type : rtems_aio_request
- OPACR : AIPSTZ_Type
- OPACR1 : AIPSTZ_Type
- OPACR2 : AIPSTZ_Type
- OPACR3 : AIPSTZ_Type
- OPACR4 : AIPSTZ_Type
- OPD : ENET_Type
- open_entry : rtems_driver_address_table
- operation : _flexspi_xfer, _ssarc_descriptor_config, MPCI_Internal_packet
- Operations : _Scheduler_Control
- operations : CORE_message_queue_Control, Thread_CPU_budget_control, Thread_Wait_information
- OPFCCR : DMA2D_TypeDef
- opktcnt : grspwrouter_portstats
- ops : drvmgr_bus, drvmgr_drv, POSIX_Shm_Object
- OPTCCR : FLASH_TypeDef
- OPTCR : FLASH_TypeDef
- Option : OptionsMap
- option : Thread_Wait_information
- option_set_param : RtemsMessageReqReceive_Context
- option_size : _serial_nor_config_option
- OptionalCmds : __attribute__
- options : rtems_fstab_entry, RtemsIntrReqEntryInstall_Context, tftp_net_config
- Options : XNandPsu_BadBlockPattern
- OptionType : FLASH_OBProgramInitTypeDef
- OPTKEYR : FLASH_TypeDef
- OPTSR2_CUR : FLASH_TypeDef
- OPTSR2_PRG : FLASH_TypeDef
- OPTSR_CUR : FLASH_TypeDef
- OPTSR_PRG : FLASH_TypeDef
- OR : COMPOPT_TypeDef, DTS_TypeDef, RTC_TypeDef, SWPMI_TypeDef
- ORBAR_JR : CAAM_Type
- order : i2c_rtc_base
- original_priority : RtemsRatemonReqCancel_Context, RtemsRatemonReqPeriod_Context
- ORJRR_JR : CAAM_Type
- ORSFR_JR : CAAM_Type
- ORSR_JR : CAAM_Type
- ORWIR_JR : CAAM_Type
- OSC_16M_CTRL : ANADIG_OSC_Type
- OSC_24M_CTRL : ANADIG_OSC_Type
- OSC_400M_CTRL0 : ANADIG_OSC_Type
- OSC_400M_CTRL1 : ANADIG_OSC_Type
- OSC_400M_CTRL2 : ANADIG_OSC_Type
- OSC_48M_CTRL : ANADIG_OSC_Type
- OSC_CONFIG0 : XTALOSC24M_Type
- OSC_CONFIG0_CLR : XTALOSC24M_Type
- OSC_CONFIG0_SET : XTALOSC24M_Type
- OSC_CONFIG0_TOG : XTALOSC24M_Type
- OSC_CONFIG1 : XTALOSC24M_Type
- OSC_CONFIG1_CLR : XTALOSC24M_Type
- OSC_CONFIG1_SET : XTALOSC24M_Type
- OSC_CONFIG1_TOG : XTALOSC24M_Type
- OSC_CONFIG2 : XTALOSC24M_Type
- OSC_CONFIG2_CLR : XTALOSC24M_Type
- OSC_CONFIG2_SET : XTALOSC24M_Type
- OSC_CONFIG2_TOG : XTALOSC24M_Type
- oscillatorSize : _pmu_gpc_body_bias_config
- OscillatorType : RCC_OscInitTypeDef
- OSPEEDR : GPIO_TypeDef
- OTFAD1_KEY_CTRL : KEY_MANAGER_Type
- OTFAD2_KEY_CTRL : KEY_MANAGER_Type
- OTGSC : USB_Type
- other_after : ScoreTqReqEnqueueCeiling_Context, ScoreTqReqEnqueueMrsp_Context, ScoreTqReqEnqueuePriority_Context, ScoreTqReqEnqueuePriorityInherit_Context
- other_before : ScoreTqReqEnqueueCeiling_Context, ScoreTqReqEnqueueMrsp_Context, ScoreTqReqEnqueuePriority_Context, ScoreTqReqEnqueuePriorityInherit_Context
- other_entry : RtemsIntrReqEntryInstall_Context, RtemsIntrReqEntryRemove_Context
- other_installed : RtemsIntrReqEntryInstall_Context, RtemsIntrReqEntryRemove_Context
- other_options : RtemsIntrReqEntryInstall_Context
- other_period_id : RtemsRatemonReqTimeout_Context
- other_ready : ScoreSchedReqYield_Context
- other_sched : RtemsEventReqSendReceive_Context
- other_scheduler : ScoreTqReqTimeoutMrsp_Context, ScoreTqReqTimeoutPriorityInherit_Context
- other_scheduler_id : RtemsSemReqSetPriority_Context
- OTPBL_CUR : FLASH_TypeDef
- OTPBL_PRG : FLASH_TypeDef
- OTR : OPAMP_TypeDef
- OTYPER : GPIO_TypeDef
- out : _asrc_edma_handle, _asrc_handle
- OUT_AS_LRC : PXP_Type
- OUT_AS_ULC : PXP_Type
- OUT_BUF : PXP_Type
- OUT_BUF2 : PXP_Type
- OUT_CTRL : PXP_Type
- OUT_CTRL_CLR : PXP_Type
- OUT_CTRL_SET : PXP_Type
- OUT_CTRL_TOG : PXP_Type
- out_fd : Untar_ChunkContext
- OUT_LRC : PXP_Type
- OUT_PITCH : PXP_Type
- OUT_PS_LRC : PXP_Type
- OUT_PS_ULC : PXP_Type
- OUT_STATUS : OCOTP_Type
- OUT_STATUS_CLR : OCOTP_Type
- OUT_STATUS_SET : OCOTP_Type
- OUT_STATUS_TOG : OCOTP_Type
- outClockSource : _asrc_channel_pair_config
- outData : _asrc_transfer
- outDataAlign : _asrc_channel_pair_config
- outDataSize : _asrc_transfer
- outDataWidth : _asrc_channel_pair_config
- outDmaHandle : _asrc_out_edma_handle
- OUTEN : PWM_Type
- outFifoThreshold : _asrc_channel_pair_config
- outMode : _pxp_lut_config
- output : CPU_Exception_frame, grgpio
- OutPut : RTC_InitTypeDef
- output : RtemsIoReqPutc_Context, RtemsIoReqPutChar_Context
- output_count : RtemsIoReqPutc_Context, RtemsIoReqPutChar_Context
- output_format : _sensor_output
- output_height : _sensor_output
- output_resolution : _sensor_output
- output_setting : _sensor_output
- output_width : _sensor_output
- OutputClock : DFSDM_Channel_InitTypeDef
- outputConf : _sensor_profile
- outputCurrent : _pmu_static_bandgap_config
- OutputDataInversionMode : CRC_InitTypeDef
- OutputDrive : SAI_InitTypeDef
- outputLogic : _gpio_pin_config
- outputPixelFormat : _flexio_mculcd_smartdma_config
- OutputPol : COMP_InitTypeDef
- OutPutPolarity : RTC_InitTypeDef
- OutPutRemap : RTC_InitTypeDef
- OutPutType : RTC_InitTypeDef
- outputVoltage : _pmu_static_bandgap_config
- outSignExtension : _asrc_channel_pair_config
- outSourceClock_Hz : _asrc_channel_pair_config
- OUTxR : HRTIM_Timerx_TypeDef
- OverCurrentThreshold : _dcdc_detection_config
- override : grclkgate
- Overrun : ADC_InitTypeDef
- OverrunDisable : SMARTCARD_AdvFeatureInitTypeDef, UART_AdvFeatureInitTypeDef
- Oversampling : ADC_InitTypeDef, DFSDM_Channel_AwdTypeDef, DFSDM_Filter_FilterParamTypeDef
- OverSampling : UART_InitTypeDef
- OversamplingMode : ADC_InitTypeDef
- OversamplingStopReset : ADC_OversamplingTypeDef
- ow : tlb_sfsr_reg
- OwnAddress1 : I2C_InitTypeDef, SMBUS_InitTypeDef
- OwnAddress2 : I2C_InitTypeDef, SMBUS_InitTypeDef
- OwnAddress2Masks : I2C_InitTypeDef, SMBUS_InitTypeDef
- owned : RtemsSchedulerReqRemoveProcessor_Context
- owner : _rtems_rfs_inode, Rate_monotonic_Control, rtems_rate_monotonic_period_status, Scheduler_Node, Thread_queue_Queue
- owner_after : ScoreMtxReqSeizeTry_Context, ScoreMtxReqSeizeWait_Context, ScoreMtxReqSurrender_Context
- owner_caller : ScoreMtxReqSeizeTry_Context, ScoreMtxReqSeizeWait_Context, ScoreMtxReqSurrender_Context
- owner_check : TQMtxContext
- owner_helper_release : ScoreTqReqTimeoutPriorityInherit_Context
- owner_node : ScoreTqReqTimeoutPriorityInherit_Context
- owner_obtain : ScoreTqReqEnqueuePriorityInherit_Context, ScoreTqReqTimeoutPriorityInherit_Context
- owner_other : ScoreMtxReqSeizeTry_Context, ScoreMtxReqSeizeWait_Context, ScoreMtxReqSurrender_Context
- owner_owner_helper_release : ScoreTqReqTimeoutPriorityInherit_Context
- owner_owner_node : ScoreTqReqTimeoutPriorityInherit_Context
- owner_owner_priority : ScoreTqReqEnqueuePriorityInherit_Context, ScoreTqReqTimeoutPriorityInherit_Context
- owner_owner_priority_after : ScoreTqReqTimeoutPriorityInherit_Context
- owner_priority : ScoreTqReqEnqueuePriorityInherit_Context, ScoreTqReqTimeoutPriorityInherit_Context
- owner_priority_after : ScoreTqReqTimeoutPriorityInherit_Context
- owner_queue_helper_release : ScoreTqReqTimeoutPriorityInherit_Context
- owner_queue_node : ScoreTqReqTimeoutPriorityInherit_Context
- owner_queue_priority : ScoreTqReqTimeoutPriorityInherit_Context
- owner_release : ScoreTqReqEnqueuePriorityInherit_Context, ScoreTqReqTimeoutPriorityInherit_Context
