56#ifndef _RTEMS_EXTENSION_H
57#define _RTEMS_EXTENSION_H
This header file provides types used by the Classic API.
rtems_status_code
Definition: status.h:85
uint32_t rtems_name
This type represents Classic API object names.
Definition: types.h:226
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
rtems_status_code rtems_extension_delete(rtems_id id)
Deletes the extension set.
Definition: extensiondelete.c:45
rtems_status_code rtems_extension_ident(rtems_name name, rtems_id *id)
Identifies an extension set by the object name.
Definition: extensionident.c:45
User_extensions_thread_exitted_extension rtems_task_exitted_extension
Task exitted extensions are invoked when a task entry returns.
Definition: extension.h:481
User_extensions_thread_switch_extension rtems_task_switch_extension
Task switch extensions are invoked when a thread switch from an executing thread to a heir thread tak...
Definition: extension.h:608
User_extensions_thread_begin_extension rtems_task_begin_extension
Task begin extensions are invoked when a task begins execution.
Definition: extension.h:353
User_extensions_thread_restart_extension rtems_task_restart_extension
Task restart extensions are invoked when a task restarts.
Definition: extension.h:518
Internal_errors_t rtems_fatal_code
This integer type represents system termination codes.
Definition: extension.h:162
User_extensions_Table rtems_extensions_table
The extensions table contains a set of extensions which may be registered in the system through the C...
Definition: extension.h:238
User_extensions_thread_delete_extension rtems_task_delete_extension
Task delete extensions are invoked when a task is deleted.
Definition: extension.h:460
User_extensions_thread_create_extension rtems_task_create_extension
Task create extensions are invoked when a task is created.
Definition: extension.h:410
User_extensions_thread_terminate_extension rtems_task_terminate_extension
Task terminate extensions are invoked when a task terminates.
Definition: extension.h:644
User_extensions_fatal_extension rtems_fatal_extension
Fatal extensions are invoked when the system should terminate.
Definition: extension.h:147
User_extensions_thread_start_extension rtems_task_start_extension
Task start extensions are invoked when a task was made ready for the first time.
Definition: extension.h:550
Internal_errors_Source rtems_fatal_source
This enumeration represents system termination sources.
Definition: extension.h:175
rtems_status_code rtems_extension_create(rtems_name name, const rtems_extensions_table *extension_table, rtems_id *id)
Creates an extension set.
Definition: extensioncreate.c:48
This type lists the possible sources from which an error can be reported.
Definition: interr.h:63
void(* User_extensions_thread_begin_extension)(struct _Thread_Control *executing)
Task begin extension.
Definition: userext.h:192
bool(* User_extensions_thread_create_extension)(struct _Thread_Control *executing, struct _Thread_Control *created)
Task create extension.
Definition: userext.h:92
void(* User_extensions_thread_start_extension)(struct _Thread_Control *executing, struct _Thread_Control *started)
Task start extension.
Definition: userext.h:132
void(* User_extensions_thread_restart_extension)(struct _Thread_Control *executing, struct _Thread_Control *restarted)
Task restart extension.
Definition: userext.h:154
void(* User_extensions_thread_delete_extension)(struct _Thread_Control *executing, struct _Thread_Control *deleted)
Task delete extension.
Definition: userext.h:112
void(* User_extensions_thread_switch_extension)(struct _Thread_Control *executing, struct _Thread_Control *heir)
Task switch extension.
Definition: userext.h:177
void(* User_extensions_thread_terminate_extension)(struct _Thread_Control *terminated)
Task termination extension.
Definition: userext.h:246
void(* User_extensions_fatal_extension)(Internal_errors_Source source, bool always_set_to_false, Internal_errors_t code)
Fatal error extension.
Definition: userext.h:224
void(* User_extensions_thread_exitted_extension)(struct _Thread_Control *executing)
Task exitted extension.
Definition: userext.h:206
This header file provides the interfaces of the Internal Error Handler.
This header file provides the status codes of Classic API directives and support functions.
User extension table.
Definition: userext.h:253
This header file provides data structures used by the implementation and the Application Configuratio...
