RTEMS 6.1-rc5
Files | |
file | _execve.c |
_execve() | |
file | aio_cancel.c |
Cancel Asynchronous I/O Operation. | |
file | aio_error.c |
Returns the error status for the Asynchronous I/O request. | |
file | aio_fsync.c |
Syncing of all Outstanding Asynchronous I/O Operations. | |
file | aio_misc.c |
Private implementation for Asynchronous I/O. | |
file | aio_read.c |
Asynchronous read operation. | |
file | aio_return.c |
Final return status for Asynchronous I/O request. | |
file | aio_suspend.c |
Wait for Asynchronous I/O Request. | |
file | aio_write.c |
Asynchronous write operation. | |
file | alarm.c |
System Generates Signal for process after realtime seconds elapsed. | |
file | barrierattrdestroy.c |
Function shall Destroy a Barrier Attribues Object. | |
file | barrierattrgetpshared.c |
Barrier Attributes Get Process Shared. | |
file | barrierattrinit.c |
Initialize the Barrier Attributes Object. | |
file | barrierattrsetpshared.c |
Set the Process-Shared Attribute of the Barrier Attributes Object. | |
file | cancel.c |
Canceling Execution of a Thread. | |
file | cleanuppush.c |
POSIX Cleanup Support. | |
file | clockgetcpuclockid.c |
Function Returns Clock ID of CPU-time Clock of process specified. | |
file | clockgetres.c |
Function Returns the Resolution of any Clock. | |
file | clockgettime.c |
Retrieves the Specified Clock Time. | |
file | clocknanosleep.c |
Suspends Execution of calling thread until Time elapses. | |
file | clocksettime.c |
Set Time of Clock. | |
file | condattrdestroy.c |
Destroy Condition Attribute. | |
file | condattrgetclock.c |
Get the Clock Condition Variable Attributes. | |
file | condattrgetpshared.c |
Get the Process-Shared Condition Variable Attributes. | |
file | condattrinit.c |
Initialization of Conditional Attributes. | |
file | condattrsetclock.c |
Set the Clock Condition Variable Attributes. | |
file | condattrsetpshared.c |
Set the Process-Shared Condition Variable Attributes. | |
file | condbroadcast.c |
Broadcast a Condition. | |
file | conddefaultattributes.c |
Condition variable Attributes structure. | |
file | conddestroy.c |
Destroy a Condition Variable. | |
file | condinit.c |
Initialize a Condition Variable. | |
file | condsignal.c |
Signal a Condition. | |
file | condsignalsupp.c |
Implements wake up version of the "signal" operation. | |
file | condtimedwait.c |
Waiting on a Condition. | |
file | condwait.c |
file | condwaitsupp.c |
POSIX Condition Variables Wait Support. | |
file | confstr.c |
Implementation for confstr method. | |
file | fork.c |
Inoperable implementation of fork() for POSIX threads. | |
file | getitimer.c |
Function Gets Value of an Interval Timer. | |
file | key.c |
POSIX Keys Information with Zero Objects. | |
file | keycreate.c |
Thread-Specific Data Key Create. | |
file | keydelete.c |
Deletes Thread-specific Data Key Previously Returned by keycreate.c. | |
file | keygetspecific.c |
Thread-Specific Data Management. | |
file | keysetspecific.c |
Set Specific Key. | |
file | kill.c |
Send a Signal to a Process. | |
file | kill_r.c |
file | killinfo.c |
file | lio_listio.c |
Function Initiates a List of I/O Requests with Single Function Call. | |
file | mlock.c |
file | mlockall.c |
file | mmap.c |
file | mprotect.c |
Change Memory Protection. | |
file | mqueue.c |
POSIX Message Queue Information with Zero Objects. | |
file | mqueueclose.c |
Function closes the Message Queue. | |
file | mqueuedeletesupp.c |
POSIX Delete Message Queue. | |
file | mqueuegetattr.c |
Message Queue Attributes. | |
file | mqueuenotify.c |
Notify Process that a Message is Available on a Queue. | |
file | mqueueopen.c |
Creates a new POSIX Message Queue or Opens an Existing Queue. | |
file | mqueuereceive.c |
Receive a Message From a Message Queue. | |
file | mqueuerecvsupp.c |
POSIX Message Queue Receive Support. | |
file | mqueuesend.c |
Adds Message Pointed by msg_ptr to Message Queue Reffered by mqdes. | |
file | mqueuesendsupp.c |
POSIX Message Queue and Send Support. | |
file | mqueuesetattr.c |
Set Message Queue Attributes. | |
file | mqueuetimedreceive.c |
Receive Message from Message Queue. | |
file | mqueuetimedsend.c |
Send a Message to a Message Queue. | |
file | mqueueunlink.c |
Remove a Message Queue. | |
file | msync.c |
file | munlock.c |
file | munlockall.c |
file | mutexattrdestroy.c |
Destroy Mutex Attributes Object. | |
file | mutexattrgetprioceiling.c |
Mutex Initialization Scheduling Attributes. | |
file | mutexattrgetprotocol.c |
Get protocol Attribute of Mutex Attribute Obect. | |
file | mutexattrgetpshared.c |
Obtaining process-shared Attribute Value from the Attributes Object. | |
file | mutexattrgettype.c |
Function gets the Mutex Type Attribute. | |
file | mutexattrinit.c |
Mutex Initialization Attribute. | |
file | mutexattrsetprioceiling.c |
file | mutexattrsetprotocol.c |
file | mutexattrsetpshared.c |
Function sets Current pshared Attribute for Mutex Attributes Object. | |
file | mutexattrsettype.c |
Set a Mutex Type. | |
file | mutexdestroy.c |
Initializing and Destroying a Mutex. | |
file | mutexgetprioceiling.c |
Returns the Current Priority Ceiling of the Mutex. | |
file | mutexinit.c |
Initialize a Mutex. | |
file | mutexlock.c |
Call to function enables locking of Mutex Object referenced by mutex. | |
file | mutexlocksupp.c |
Support Call to function Enables Locking of Mutex Object. | |
file | mutexsetprioceiling.c |
Changes the Priority Ceiling of a Mutex and Releases it. | |
file | mutextimedlock.c |
Mutex Timed Lock. | |
file | mutextrylock.c |
Try to Lock Mutex. | |
file | mutexunlock.c |
Locking and Unlocking a Mutex. | |
file | nanosleep.c |
file | pause.c |
Suspend Process Execution. | |
file | pbarrierdestroy.c |
Destroy a Barrier Object. | |
file | pbarrierinit.c |
Call to Function Enables Reinitializing of the Barrier. | |
file | pbarrierwait.c |
Wait at a Barrier. | |
file | posix_madvise.c |
file | prwlockdestroy.c |
Destroy a RWLock. | |
file | prwlockinit.c |
Allocate resources to use the read-write lock and Initialize it. | |
file | prwlockrdlock.c |
Obtain a Read Lock on a RWLock Instance. | |
file | prwlocktimedrdlock.c |
Attempt to Obtain a Read Lock on a RWLock Instance. | |
file | prwlocktimedwrlock.c |
Function applies a Write lock to RWLock referenced by rwlock. | |
file | prwlocktryrdlock.c |
file | prwlocktrywrlock.c |
Attempt to Obtain a Write Lock on a RWLock Instance. | |
file | prwlockunlock.c |
Function Releases a lock held on RWLock object referenced by rwlock. | |
file | prwlockwrlock.c |
Obtain a Write Lock on a RWlock Instance. | |
file | psignal.c |
POSIX Signals Manager Initialization. | |
file | psignalclearprocesssignals.c |
POSIX_signals clear_process_signals. | |
file | psignalclearsignals.c |
POSIX Signals Clear Signals. | |
file | psignalsetprocesssignals.c |
POSIX Signals Set Process Signals. | |
file | psignalunblockthread.c |
POSIX Signals Thread Unlock. | |
file | pspindestroy.c |
Destroy a Spinlock. | |
file | pspininit.c |
POSIX Function Initializes a Spinlock Instance. | |
file | pspinlock.c |
Wait at a Spinlock. | |
file | pspinunlock.c |
Function Unlocks a Spin Lock Object. | |
file | psxnametoid.c |
POSIX Name to ID. | |
file | psxpriorityisvalid.c |
POSIX Is Priority Valid. | |
file | psxsemaphore.c |
POSIX Semaphore Information with Zero Objects. | |
file | psxtimercreate.c |
Create a Per-Process Timer. | |
file | psxtimerdelete.c |
Deletes a POSIX Interval Timer. | |
file | psxtransschedparam.c |
Translate sched_param into SuperCore Terms. | |
file | pthread.c |
Private Support Information for POSIX Threads. | |
file | pthreadatfork.c |
Register Fork Handlers. | |
file | pthreadattrdefault.c |
file | pthreadattrdestroy.c |
Thread Creation Attributes. | |
file | pthreadattrgetaffinitynp.c |
Pthread Attribute Get Affinity. | |
file | pthreadattrgetdetachstate.c |
Function gets the detachstate Attribute in the attr Object. | |
file | pthreadattrgetguardsize.c |
file | pthreadattrgetinheritsched.c |
Thread Creation Scheduling Attributes. | |
file | pthreadattrgetschedparam.c |
Returns Scheduling Parameter Attributes of Thread Attributes Object. | |
file | pthreadattrgetschedpolicy.c |
Get The Schedpolicy Attribute. | |
file | pthreadattrgetscope.c |
Function gets the Contentionscope Attribute in the attr object. | |
file | pthreadattrgetstack.c |
Function Gets the Thread Creation Stack Attributes in the attr. | |
file | pthreadattrgetstackaddr.c |
file | pthreadattrgetstacksize.c |
file | pthreadattrinit.c |
Thread Attributes Creation. | |
file | pthreadattrsetaffinitynp.c |
Pthread Attribute Set Affinity. | |
file | pthreadattrsetdetachstate.c |
file | pthreadattrsetguardsize.c |
file | pthreadattrsetinheritsched.c |
Function sets the inheritsched Attribute in the attr Argument. | |
file | pthreadattrsetschedparam.c |
Thread Creation Scheduling Parameters. | |
file | pthreadattrsetschedpolicy.c |
Sets Scheduling policy Attributes of Thread Attributes Object. | |
file | pthreadattrsetscope.c |
Function Sets the Contentionscope Attribute in the attr Object. | |
file | pthreadattrsetstack.c |
Function Sets Thread Creation Stack Attributes in the attr object. | |
file | pthreadattrsetstackaddr.c |
Sets the Thread Creation stackaddr Attribute in the attr Object. | |
file | pthreadattrsetstacksize.c |
Sets the Thread Creation Stacksize Attribute in the attr object. | |
file | pthreadconcurrency.c |
Pthread Get/Set Concurrency. | |
file | pthreadcreate.c |
Function Starts a New Thread in The Calling Process. | |
file | pthreaddetach.c |
Detaching a Thread. | |
file | pthreadequal.c |
Compare Thread IDs. | |
file | pthreadexit.c |
POSIX Thread Exit Shared Helper. | |
file | pthreadgetaffinitynp.c |
Pthread Get Affinity. | |
file | pthreadgetattrnp.c |
Pthread Get Attribute. | |
file | pthreadgetcpuclockid.c |
Returns Clock ID for CPU time clock of the thread. | |
file | pthreadgetschedparam.c |
Gets Scheduling Policy and Parameters of Individual Threads. | |
file | pthreadinitthreads.c |
POSIX Threads Initialize User Threads Body. | |
file | pthreadjoin.c |
Suspends Execution of Calling Thread until Target Thread Terminates. | |
file | pthreadkill.c |
Sends a signal Asynchronously directed to a thread. | |
file | pthreadonce.c |
Call to function by Thread will call init_routine with no Arguments. | |
file | pthreadsetaffinitynp.c |
Pthread Set Affinity. | |
file | pthreadsetschedparam.c |
Function sets scheduling policy and parameters of the thread. | |
file | pthreadsigmask.c |
Examine and/or change the calling thread's signal mask. | |
file | ptimer.c |
POSIX Timer Information with Zero Objects. | |
file | rwlockattrdestroy.c |
Function Destroys a read-write lock Attributes object. | |
file | rwlockattrgetpshared.c |
Get the Process-Shared Attribute of the RWLock. | |
file | rwlockattrinit.c |
Initialises a RWLock Attributes object attr with the default value. | |
file | rwlockattrsetpshared.c |
RWLock Attributes Set Process Shared. | |
file | sched_getparam.c |
Set Scheduling Parameters. | |
file | sched_getprioritymax.c |
Returns the Appropriate Maximum for Scheduling policy. | |
file | sched_getprioritymin.c |
Get the Minimum Priority Limit. | |
file | sched_getscheduler.c |
Function Returns Scheduling Policy of the process specified by pid. | |
file | sched_rr_get_interval.c |
Limits for Scheduling Parameter. | |
file | sched_setparam.c |
Sets Scheduling Parameters Associated with Scheduling Policies. | |
file | sched_setscheduler.c |
Set Scheduling Policy and Scheduling Parameters. | |
file | sched_yield.c |
Yield Processor. | |
file | semaphoredeletesupp.c |
POSIX Delete Semaphore. | |
file | semclose.c |
Close a Named Semaphore. | |
file | semdestroy.c |
Destroy an Unnamed Semaphore. | |
file | semgetvalue.c |
Get the Value of a Semaphore. | |
file | seminit.c |
Initializing of an Unnamed Semaphore. | |
file | semopen.c |
Function Creates New POSIX semaphore or Opens an existing Semaphore. | |
file | sempost.c |
Unlock a Semaphore. | |
file | semtimedwait.c |
Lock a Semaphore. | |
file | semtrywait.c |
file | semunlink.c |
Remove a Named Semaphore. | |
file | semwait.c |
file | setcancelstate.c |
Setting Cancelability State. | |
file | setcanceltype.c |
Sets the Cancelability Type of Calling Thread to value given in type. | |
file | setitimer.c |
Set the Timer. | |
file | shm.c |
POSIX Shared Memory Information with Zero Objects. | |
file | shmheap.c |
file | shmopen.c |
file | shmunlink.c |
file | shmwkspace.c |
file | sigaction.c |
Allows calling process to examine action of a Specific Signal. | |
file | sigaddset.c |
Function Adds Signal from Set. | |
file | sigdelset.c |
Deleted Signal from Set. | |
file | sigemptyset.c |
Manipulate Signal Sets. | |
file | sigfillset.c |
file | sigismember.c |
file | signal_2.c |
POSIX Function Installs signal Handler. | |
file | sigpending.c |
Examine Pending Signals. | |
file | sigprocmask.c |
Examine and Change Blocked Signals. | |
file | sigqueue.c |
Queue a Signal to a Process. | |
file | sigsuspend.c |
Replacing signal mask with *sigmask and suspending calling process. | |
file | sigtimedwait.c |
Wait for Queued Signals. | |
file | sigwait.c |
Synchronously Accept a Signal. | |
file | sigwaitinfo.c |
Suspends Execution of Calling Thread until Signals in set Delivered. | |
file | sysconf.c |
Get Configurable System Variables. | |
file | testcancel.c |
Setting test on Cancelability State. | |
file | timergetoverrun.c |
Get Overrun Count for a POSIX Per-Process Timer. | |
file | timergettime.c |
Function Fetches State of POSIX Per-Process Timers. | |
file | timersettime.c |
Function Arms or Disarms the Timer Identified by timerid. | |
file | ualarm.c |
Schedule Alarm. | |
file | vfork.c |
Creates Child process Of The Calling process. | |
file | wait.c |
Wait for Process to Change State. | |
file | waitpid.c |
