RTEMS 6.1-rc4
Macros | Enumerations | Functions
usbhs.h File Reference
#define UHD_PIPE_MAX_TRANS   0x8000
 Maximum transfer size on USB DMA.
#define CHIP_USB_NUMPIPE   10
#define CHIP_USB_DMA_NUMPIPE   7
#define CHIP_USB_PIPE_MAXPACKETSIZE(ep)    ((ep == 0) ? 64 : 1024)
#define CHIP_USB_PIPE_BANKS(ep)   ((ep==0)?1:((ep<=2)?3:2))
#define CHIP_USB_PIPE_HBW(ep)   ((((ep)>=1) &&((ep)<=2))?true:false)
#define CHIP_USB_PIPE_DMA(ep)   ((((ep)>=1)&&((ep)<=7))?true:false)
#define USB_DEVICE_HS_SUPPORT
#define USB_DEVICE_EP_CTRL_SIZE   64
 Control endpoint size.
#define CHIP_USB_UDP
#define CHIP_USB_PULLUP_INTERNAL
#define CHIP_USB_NUMENDPOINTS   10
#define CHIP_USB_ENDPOINTS_MAXPACKETSIZE(ep)    ((ep == 0) ? 64 : 1024)
#define CHIP_USB_ENDPOINTS_BANKS(ep)   ((ep==0)?1:((ep<=2)?3:2))
#define CHIP_USB_ENDPOINTS_HBW(ep)   ((((ep)>=1) &&((ep)<=2))?true:false)
#define CHIP_USB_ENDPOINTS_DMA(ep)   ((((ep)>=1)&&((ep)<=7))?true:false)
#define DMA_MAX_FIFO_SIZE   (65536/1)
#define EPT_VIRTUAL_SIZE   8192
USBHS Host IP properties
Get maximal number of endpoints
#define uhd_get_pipe_max_nbr()   (9)
#define USBHS_EPT_NUM   (uhd_get_pipe_max_nbr()+1)
#define uhd_get_pipe_bank_max_nbr(ep)   ((ep == 0) ? 1 : ((ep <= 2) ? 3 : 2))
 Get maximal number of banks of endpoints.
#define uhd_get_pipe_size_max(ep)   (((ep) == 0) ? 64 : 1024)
 Get maximal size of endpoint (3X, 1024/64)
#define Is_uhd_pipe_dma_supported(ep)   ((((ep) >= 1) && ((ep) <= 7)) ? true : false)
 Get DMA support of endpoints.
#define Is_uhd_pipe_high_bw_supported(ep)   (((ep) >= 2) ? true : false)
 Get High Band Width support of endpoints.
enum  USB_Mode_t { HOST_MODE = 0 , DEVICE_MODE = 1 }
__STATIC_INLINE void USBHS_FreezeClock (Usbhs *pUsbhs)
 Freeze or unfreeze USB clock.
__STATIC_INLINE void USBHS_UnFreezeClock (Usbhs *pUsbhs)
__STATIC_INLINE void USBHS_VBusHWC (Usbhs *pUsbhs, uint8_t Enable)
__STATIC_INLINE void USBHS_UsbEnable (Usbhs *pUsbhs, uint8_t Enable)
 Enables or disables USB.
__STATIC_INLINE void USBHS_UsbMode (Usbhs *pUsbhs, USB_Mode_t Mode)
 Device or Host Mode.
__STATIC_INLINE uint8_t USBHS_ISUsableClock (Usbhs *pUsbhs)
 Check if clock is usable or not.
__STATIC_INLINE uint32_t USBHS_ReadStatus (Usbhs *pUsbhs)
 Raise interrupt for endpoint.
__STATIC_INLINE uint32_t USBHS_GetUsbSpeed (Usbhs *pUsbhs)
 Enable or disable USB address.
__STATIC_INLINE bool USBHS_IsUsbFullSpeed (Usbhs *pUsbhs)
__STATIC_INLINE bool USBHS_IsUsbHighSpeed (Usbhs *pUsbhs)
__STATIC_INLINE bool USBHS_IsUsbLowSpeed (Usbhs *pUsbhs)
__STATIC_INLINE void USBHS_Ack (Usbhs *pUsbhs, uint32_t AckType)
__STATIC_INLINE void USBHS_Set (Usbhs *pUsbhs, uint32_t SetStatus)
__STATIC_INLINE void USBHS_EnableAddress (Usbhs *pUsbhs, uint8_t Enable)
__STATIC_INLINE void USBHS_SetAddress (Usbhs *pUsbhs, uint8_t Addr)
 Configure USB address and enable or disable it.
__STATIC_INLINE uint8_t USBHS_GetAddress (Usbhs *pUsbhs)
 Get USB address.
__STATIC_INLINE void USBHS_DetachUsb (Usbhs *pUsbhs, uint8_t Enable)
 Attach or detach USB.
__STATIC_INLINE void USBHS_ForceLowSpeed (Usbhs *pUsbhs, uint8_t Enable)
 Force Low Speed mode.
__STATIC_INLINE void USBHS_EnableHighSpeed (Usbhs *pUsbhs, uint8_t Enable)
 Disable/Enables High Speed mode.
__STATIC_INLINE void USBHS_SetRemoteWakeUp (Usbhs *pUsbhs)
 Set Remote WakeUp mode.
__STATIC_INLINE void USBHS_EnableTestMode (Usbhs *pUsbhs, uint32_t mode)
 Disable/Enables Test mode.
__STATIC_INLINE void USBHS_EnableHSTestMode (Usbhs *pUsbhs)
 Disable/Enables HS Test mode.
__STATIC_INLINE uint32_t USBHS_ReadIntStatus (Usbhs *pUsbhs, uint32_t IntType)
 Read status for an interrupt.
__STATIC_INLINE uint32_t USBHS_ReadEpIntStatus (Usbhs *pUsbhs, uint8_t EpNum)
 Read status for an Endpoint.
__STATIC_INLINE uint32_t USBHS_ReadDmaIntStatus (Usbhs *pUsbhs, uint8_t DmaNum)
 Read status for a DMA Endpoint.
__STATIC_INLINE void USBHS_AckInt (Usbhs *pUsbhs, uint32_t IntType)
 Acknowledge interrupt for endpoint.
__STATIC_INLINE void USBHS_RaiseInt (Usbhs *pUsbhs, uint32_t IntType)
__STATIC_INLINE void USBHS_RaiseDmaInt (Usbhs *pUsbhs, uint8_t Dma)
 Raise DMA interrupt for endpoint.
__STATIC_INLINE uint32_t USBHS_IsIntEnable (Usbhs *pUsbhs, uint32_t IntType)
 check for interrupt of endpoint.
__STATIC_INLINE uint32_t USBHS_IsIntEnableEP (Usbhs *pUsbhs, uint8_t EpNum)
 Check if endpoint's interrupt is enabled for a given endpoint number.
__STATIC_INLINE uint32_t USBHS_IsDmaIntEnable (Usbhs *pUsbhs, uint8_t DmaNum)
 Check if endpoint's DMA interrupt is enabled for a given endpoint DMA number.
__STATIC_INLINE void USBHS_EnableInt (Usbhs *pUsbhs, uint32_t IntType)
 Enables Interrupt.
__STATIC_INLINE void USBHS_EnableIntEP (Usbhs *pUsbhs, uint8_t EpNum)
 Enables interrupt for a given endpoint.
__STATIC_INLINE void USBHS_EnableDMAIntEP (Usbhs *pUsbhs, uint32_t DmaEp)
 Enables DMA interrupt for a given endpoint.
__STATIC_INLINE void USBHS_DisableInt (Usbhs *pUsbhs, uint32_t IntType)
 Disables interrupt for endpoint.
__STATIC_INLINE void USBHS_DisableIntEP (Usbhs *pUsbhs, uint8_t Ep)
__STATIC_INLINE void USBHS_DisableDMAIntEP (Usbhs *pUsbhs, uint8_t DmaEp)
 Disables DMA interrupt for endpoint.
__STATIC_INLINE void USBHS_EnableEP (Usbhs *pUsbhs, uint8_t Ep, uint8_t Enable)
 Enables or disables endpoint.
__STATIC_INLINE void USBHS_ResetEP (Usbhs *pUsbhs, uint8_t Ep)
 Rests Endpoint.
__STATIC_INLINE uint32_t USBHS_IsEPEnabled (Usbhs *pUsbhs, uint8_t Ep)
 Checks if Endpoint is enable.
__STATIC_INLINE uint8_t USBHS_GetMicroFrameNum (Usbhs *pUsbhs)
 Get MicrFrame number.
__STATIC_INLINE uint8_t USBHS_GetFrameNum (Usbhs *pUsbhs)
 Get Frame number.
__STATIC_INLINE uint8_t USBHS_GetFrameNumCrcErr (Usbhs *pUsbhs)
 Get Frame number CRC error.
__STATIC_INLINE void USBHS_ConfigureEPs (Usbhs *pUsbhs, const uint8_t Ep, const uint8_t Type, const uint8_t Dir, const uint8_t Size, const uint8_t Bank)
__STATIC_INLINE void USBHS_AutoSwitchBankEnable (Usbhs *pUsbhs, uint8_t Ep, uint8_t Enable)
__STATIC_INLINE void USBHS_AllocateMemory (Usbhs *pUsbhs, uint8_t Ep)
__STATIC_INLINE void USBHS_FreeMemory (Usbhs *pUsbhs, uint8_t Ep)
__STATIC_INLINE uint32_t USBHS_GetConfigureEPs (Usbhs *pUsbhs, uint8_t Ep, uint32_t IntType)
__STATIC_INLINE uint8_t USBHS_GetEpType (Usbhs *pUsbhs, uint8_t Ep)
__STATIC_INLINE uint32_t USBHS_GetEpSize (Usbhs *pUsbhs, uint8_t Ep)
__STATIC_INLINE void USBHS_SetIsoTrans (Usbhs *pUsbhs, uint8_t Ep, uint8_t nbTrans)
__STATIC_INLINE uint32_t USBHS_IsEpIntEnable (Usbhs *pUsbhs, uint8_t Ep, uint32_t EpIntType)
__STATIC_INLINE void USBHS_EnableEPIntType (Usbhs *pUsbhs, uint8_t Ep, uint32_t EpInt)
__STATIC_INLINE uint32_t USBHS_IsBankKilled (Usbhs *pUsbhs, uint8_t Ep)
__STATIC_INLINE void USBHS_KillBank (Usbhs *pUsbhs, uint8_t Ep)
__STATIC_INLINE void USBHS_DisableEPIntType (Usbhs *pUsbhs, uint8_t Ep, uint32_t EpInt)
__STATIC_INLINE void USBHS_AckEpInterrupt (Usbhs *pUsbhs, uint8_t Ep, uint32_t EpInt)
__STATIC_INLINE void USBHS_RaiseEPInt (Usbhs *pUsbhs, uint8_t Ep, uint32_t EpInt)
__STATIC_INLINE uint32_t USBHS_ReadEPStatus (Usbhs *pUsbhs, uint8_t Ep, uint32_t EpInt)
__STATIC_INLINE uint8_t USBHS_IsBankFree (Usbhs *pUsbhs, uint8_t Ep)
__STATIC_INLINE uint8_t USBHS_NumOfBanksInUse (Usbhs *pUsbhs, uint8_t Ep)
__STATIC_INLINE uint16_t USBHS_ByteCount (Usbhs *pUsbhs, uint8_t Ep)
__STATIC_INLINE void USBHS_SetDmaNDA (UsbhsDevdma *pUsbDma, uint32_t Desc)
 Sets DMA next descriptor address.
__STATIC_INLINE uint32_t USBHS_GetDmaNDA (UsbhsDevdma *pUsbDma)
 Gets DMA next descriptor address.
__STATIC_INLINE void USBHS_SetDmaBuffAdd (UsbhsDevdma *pUsbDma, uint32_t Addr)
 Sets USBHS's DMA Buffer addresse.
__STATIC_INLINE uint32_t USBHS_GetDmaBuffAdd (UsbhsDevdma *pUsbDma)
 Gets USBHS's DMA Buffer addresse.
__STATIC_INLINE void USBHS_ConfigureDma (UsbhsDevdma *pUsbDma, uint32_t Cfg)
 Setup the USBHS DMA.
__STATIC_INLINE uint32_t USBHS_GetDmaConfiguration (UsbhsDevdma *pUsbDma)
 Get DMA configuration.
__STATIC_INLINE void USBHS_SetDmaStatus (UsbhsDevdma *pUsbDma, uint32_t Status)
 Set DMA status.
__STATIC_INLINE uint32_t USBHS_GetDmaStatus (UsbhsDevdma *pUsbDma)
 Get Dma Status.
__STATIC_INLINE uint16_t USBHS_GetDmaBuffCount (UsbhsDevdma *pUsbDma)
 Get DMA buffer's count.
__STATIC_INLINE void USBHS_SetHostHighSpeed (Usbhs *pUsbhs)
 Sets USB host's speed to Normal , it sets to HS from FS.
__STATIC_INLINE void USBHS_SetHostLowSpeed (Usbhs *pUsbhs)
 Sets USB host's speed to Low speed.
__STATIC_INLINE void USBHS_SetHostForcedFullSpeed (Usbhs *pUsbhs)
 Sets USB host's speed to forced Full speed.
__STATIC_INLINE void USBHS_Reset (void)
 Sets USB host sends reste signal on USB Bus.
__STATIC_INLINE void USBHS_StopReset (void)
__STATIC_INLINE void USBHS_Resume (void)
 Sets USB host send Resume on USB bus.
__STATIC_INLINE void USBHS_EnableSOF (Usbhs *pUsbhs)
 Sets USB host Enable the Generation of Start of Frame.
__STATIC_INLINE uint8_t USBHS_IsEnableSOF (Usbhs *pUsbhs)
__STATIC_INLINE void USBHS_DisableSOF (void)
 Sets USB host disable the Generation of Start of Frame.
__STATIC_INLINE uint32_t USBHS_GetHostStatus (Usbhs *pUsbhs, uint8_t IntType)
 Gets USB host interrupt status.
__STATIC_INLINE uint32_t USBHS_GetHostPipeStatus (Usbhs *pUsbhs, uint8_t PipeInt)
__STATIC_INLINE uint32_t USBHS_GetHostDmaPipeStatus (Usbhs *pUsbhs, uint8_t PipeInt)
__STATIC_INLINE void USBHS_ClearHostStatus (Usbhs *pUsbhs, uint32_t IntType)
__STATIC_INLINE void USBHS_SetHostStatus (Usbhs *pUsbhs, uint32_t IntType)
__STATIC_INLINE void USBHS_SetHostDmaStatus (Usbhs *pUsbhs, uint8_t PipeInt)
__STATIC_INLINE uint8_t USBHS_IsHostIntEnable (Usbhs *pUsbhs, uint8_t IntType)
__STATIC_INLINE uint32_t USBHS_IsHostPipeIntEnable (Usbhs *pUsbhs, uint8_t PipeInt)
__STATIC_INLINE uint32_t USBHS_IsHostDmaIntEnable (Usbhs *pUsbhs, uint8_t PipeInt)
__STATIC_INLINE void USBHS_HostIntDisable (Usbhs *pUsbhs, uint32_t IntType)
__STATIC_INLINE void USBHS_HostPipeIntDisable (Usbhs *pUsbhs, uint8_t PipeInt)
__STATIC_INLINE void USBHS_HostDmaIntDisable (Usbhs *pUsbhs, uint8_t PipeInt)
__STATIC_INLINE void USBHS_HostIntEnable (Usbhs *pUsbhs, uint32_t IntType)
__STATIC_INLINE void USBHS_HostPipeIntEnable (Usbhs *pUsbhs, uint8_t PipeInt)
__STATIC_INLINE void USBHS_HostDmaIntEnable (Usbhs *pUsbhs, uint8_t PipeInt)
__STATIC_INLINE uint16_t USBHS_HostGetSOF (void)
__STATIC_INLINE uint16_t USBHS_HostGetFramePos (void)
__STATIC_INLINE uint16_t USBHS_HostGetMSOF (void)
__STATIC_INLINE void USBHS_HostSetAddr (Usbhs *pUsbhs, uint8_t Pipe, uint8_t Addr)
__STATIC_INLINE uint8_t USBHS_HostGetAddr (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE void USBHS_HostPipeEnable (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE void USBHS_HostPipeDisable (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE uint32_t USBHS_IsHostPipeEnable (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE void USBHS_HostPipeReset (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE void USBHS_HostConfigure (Usbhs *pUsbhs, uint8_t Pipe, uint32_t pipeBank, uint8_t pipeSize, uint32_t pipeType, uint32_t pipeToken, uint8_t pipeEpNum, uint8_t PipeIntFreq)
__STATIC_INLINE void USBHS_HostAllocMem (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE void USBHS_HostFreeMem (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE uint16_t USBHS_HostGetSize (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE void USBHS_HostSetToken (Usbhs *pUsbhs, uint8_t Pipe, uint32_t Token)
__STATIC_INLINE uint32_t USBHS_HostGetToken (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE void USBHS_HostSetPipeType (Usbhs *pUsbhs, uint8_t Pipe, uint8_t PipeType)
__STATIC_INLINE uint32_t USBHS_HostGetPipeType (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE uint8_t USBHS_GetPipeEpAddr (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE void USBHS_HostEnableAutoSw (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE void USBHS_HostDisableAutoSw (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE void USBHS_HostSetIntFreq (Usbhs *pUsbhs, uint8_t Pipe, uint8_t Freq)
__STATIC_INLINE void USBHS_HostEnablePing (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE uint8_t USBHS_HostGetDataTogSeq (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE uint8_t USBHS_HostGetNumOfBusyBank (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE uint8_t USBHS_HostGetCurrentBank (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE uint8_t USBHS_HostGetPipeByteCount (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE uint32_t USBHS_IsHostConfigOk (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE uint32_t USBHS_HostGetIntTypeStatus (Usbhs *pUsbhs, uint8_t Pipe, uint32_t intType)
__STATIC_INLINE void USBHS_HostAckPipeIntType (Usbhs *pUsbhs, uint8_t Pipe, uint32_t intType)
__STATIC_INLINE void USBHS_HostSetPipeIntType (Usbhs *pUsbhs, uint8_t Pipe, uint32_t intType)
__STATIC_INLINE uint32_t USBHS_IsHostPipeIntTypeEnable (Usbhs *pUsbhs, uint8_t Pipe, uint32_t intType)
__STATIC_INLINE void USBHS_HostDisablePipeIntType (Usbhs *pUsbhs, uint8_t Pipe, uint32_t intType)
__STATIC_INLINE void USBHS_HostEnablePipeIntType (Usbhs *pUsbhs, uint8_t Pipe, uint32_t intType)
__STATIC_INLINE void USBHS_HostEnableInReq (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE void USBHS_HostDisableInReq (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE uint8_t USBHS_IsHostInReqEnable (Usbhs *pUsbhs, uint8_t Pipe)
__STATIC_INLINE void USBHS_HostInReq (Usbhs *pUsbhs, uint8_t Pipe, uint8_t InReq)
__STATIC_INLINE void USBHS_HostSetErr (Usbhs *pUsbhs, uint8_t Pipe, uint8_t Err)
__STATIC_INLINE uint8_t USBHS_HostGetErr (Usbhs *pUsbhs, uint8_t Pipe, uint8_t Err)
__STATIC_INLINE void USBHS_HostClearErr (Usbhs *pUsbhs, uint8_t Pipe, uint8_t Err)
__STATIC_INLINE uint8_t USBHS_GetInterruptPipeNum (void)
__STATIC_INLINE void USBHS_SetHostDmaNDA (UsbhsHstdma *pUsbDma, uint32_t Desc)
__STATIC_INLINE uint32_t USBHS_GetHostDmaNDA (UsbhsHstdma *pUsbDma)
__STATIC_INLINE void USBHS_SetHostDmaBuffAdd (UsbhsHstdma *pUsbDma, uint32_t Addr)
__STATIC_INLINE uint32_t USBHS_GetHostDmaBuffAdd (UsbhsHstdma *pUsbDma)
__STATIC_INLINE void USBHS_HostConfigureDma (UsbhsHstdma *pUsbDma, uint32_t Cfg)
__STATIC_INLINE uint32_t USBHS_GetHostDmaConfiguration (UsbhsHstdma *pUsbDma)
__STATIC_INLINE void USBHS_SetHostPipeDmaStatus (UsbhsHstdma *pUsbDma, uint32_t Status)
 Set DMA status.
__STATIC_INLINE uint32_t USBHS_GetHostPipeDmaStatus (UsbhsHstdma *pUsbDma)
 Get Dma Status.
◆ CHIP_USB_DMA_NUMPIPE
Number of USB endpoints
◆ CHIP_USB_ENDPOINTS_BANKS
#define CHIP_USB_ENDPOINTS_BANKS (   ep)    ((ep==0)?1:((ep<=2)?3:2))
Endpoints Number of Bank
◆ CHIP_USB_ENDPOINTS_DMA
#define CHIP_USB_ENDPOINTS_DMA (   ep)    ((((ep)>=1)&&((ep)<=7))?true:false)
Endpoints DMA support
◆ CHIP_USB_ENDPOINTS_MAXPACKETSIZE
#define CHIP_USB_ENDPOINTS_MAXPACKETSIZE (   ep)     ((ep == 0) ? 64 : 1024)
Endpoints max packet size
◆ CHIP_USB_NUMENDPOINTS
◆ CHIP_USB_NUMPIPE
◆ CHIP_USB_PIPE_BANKS
#define CHIP_USB_PIPE_BANKS (   ep)    ((ep==0)?1:((ep<=2)?3:2))
◆ CHIP_USB_PIPE_DMA
#define CHIP_USB_PIPE_DMA (   ep)    ((((ep)>=1)&&((ep)<=7))?true:false)
◆ CHIP_USB_PIPE_MAXPACKETSIZE
#define CHIP_USB_PIPE_MAXPACKETSIZE (   ep)     ((ep == 0) ? 64 : 1024)
Endpoints max paxcket size
◆ CHIP_USB_PULLUP_INTERNAL
Indicates chip has an internal pull-up.
◆ CHIP_USB_UDP
Indicates chip has an UDP High Speed.
◆ DMA_MAX_FIFO_SIZE
Max size of the FMA FIFO
◆ EPT_VIRTUAL_SIZE
fifo space size in DW
◆ USB_DEVICE_HS_SUPPORT
addtogroup usbd_hal
◆ USBHS_Ack()
__STATIC_INLINE void USBHS_Ack ( Usbhs pUsbhs,
uint32_t  AckType
Parameters
pUsbhsPointer to an USBHS instance.
AckTypeInterrupt Acknowledge type
◆ USBHS_AckEpInterrupt()
__STATIC_INLINE void USBHS_AckEpInterrupt ( Usbhs pUsbhs,
uint8_t  Ep,
uint32_t  EpInt
Clears register/acknowledge for a given endpoint
◆ USBHS_AckInt()
__STATIC_INLINE void USBHS_AckInt ( Usbhs pUsbhs,
uint32_t  IntType
Parameters
IntTypeInterrupt Type
◆ USBHS_AllocateMemory()
__STATIC_INLINE void USBHS_AllocateMemory ( Usbhs pUsbhs,
uint8_t  Ep
Allocate Endpoint memory
◆ USBHS_AutoSwitchBankEnable()
__STATIC_INLINE void USBHS_AutoSwitchBankEnable ( Usbhs pUsbhs,
uint8_t  Ep,
uint8_t  Enable
Enable or disable Auto switch of banks
◆ USBHS_ByteCount()
__STATIC_INLINE uint16_t USBHS_ByteCount ( Usbhs pUsbhs,
uint8_t  Ep
Read endpoint's byte count of the FIFO
◆ USBHS_ClearHostStatus()
__STATIC_INLINE void USBHS_ClearHostStatus ( Usbhs pUsbhs,
uint32_t  IntType
Parameters
pUsbhsUSBHS host instance
◆ USBHS_ConfigureDma()
__STATIC_INLINE void USBHS_ConfigureDma ( UsbhsDevdma pUsbDma,
uint32_t  Cfg
Parameters
pUsbDmaUSBHS device DMA instance
CfgDMA's configuration
◆ USBHS_ConfigureEPs()
__STATIC_INLINE void USBHS_ConfigureEPs ( Usbhs pUsbhs,
const uint8_t  Ep,
const uint8_t  Type,
const uint8_t  Dir,
const uint8_t  Size,
const uint8_t  Bank
Set Endpoints configuration Bank size, type and direction
◆ USBHS_DetachUsb()
__STATIC_INLINE void USBHS_DetachUsb ( Usbhs pUsbhs,
uint8_t  Enable
Parameters
EnableAttachs or detach USB device
◆ USBHS_DisableDMAIntEP()
__STATIC_INLINE void USBHS_DisableDMAIntEP ( Usbhs pUsbhs,
uint8_t  DmaEp
Parameters
DmaEpEndpoint's DMA number
◆ USBHS_DisableEPIntType()
__STATIC_INLINE void USBHS_DisableEPIntType ( Usbhs pUsbhs,
uint8_t  Ep,
uint32_t  EpInt
Disables an interrupt type for a given endpoint
◆ USBHS_DisableInt()
__STATIC_INLINE void USBHS_DisableInt ( Usbhs pUsbhs,
uint32_t  IntType
Parameters
IntTypeInt type
◆ USBHS_DisableIntEP()
__STATIC_INLINE void USBHS_DisableIntEP ( Usbhs pUsbhs,
uint8_t  Ep
Parameters
EpEndpoint number
◆ USBHS_DisableSOF()
__STATIC_INLINE void USBHS_DisableSOF ( void  )
Parameters
◆ USBHS_EnableAddress()
__STATIC_INLINE void USBHS_EnableAddress ( Usbhs pUsbhs,
uint8_t  Enable
Parameters
SetStatusSet USB status
◆ USBHS_EnableDMAIntEP()
__STATIC_INLINE void USBHS_EnableDMAIntEP ( Usbhs pUsbhs,
uint32_t  DmaEp
Parameters
DmaEpEndpoint's DMA interrupt number
◆ USBHS_EnableEP()
__STATIC_INLINE void USBHS_EnableEP ( Usbhs pUsbhs,
uint8_t  Ep,
uint8_t  Enable
Parameters
EnableEnable/disable endpoint
◆ USBHS_EnableEPIntType()
__STATIC_INLINE void USBHS_EnableEPIntType ( Usbhs pUsbhs,
uint8_t  Ep,
uint32_t  EpInt
Enables an interrupt type for a given endpoint
◆ USBHS_EnableHighSpeed()
__STATIC_INLINE void USBHS_EnableHighSpeed ( Usbhs pUsbhs,
uint8_t  Enable
Parameters
EnableEnables/disable option
◆ USBHS_EnableHSTestMode()
__STATIC_INLINE void USBHS_EnableHSTestMode ( Usbhs pUsbhs)
Parameters
◆ USBHS_EnableInt()
__STATIC_INLINE void USBHS_EnableInt ( Usbhs pUsbhs,
uint32_t  IntType
Enables Interrupt.
Parameters
◆ USBHS_EnableIntEP()
__STATIC_INLINE void USBHS_EnableIntEP ( Usbhs pUsbhs,
uint8_t  EpNum
Parameters
DmaNumEndpoint's DMA number
◆ USBHS_EnableSOF()
__STATIC_INLINE void USBHS_EnableSOF ( Usbhs pUsbhs)
Parameters
◆ USBHS_EnableTestMode()
__STATIC_INLINE void USBHS_EnableTestMode ( Usbhs pUsbhs,
uint32_t  mode
Parameters
modeEnables/disable option
◆ USBHS_ForceLowSpeed()
__STATIC_INLINE void USBHS_ForceLowSpeed ( Usbhs pUsbhs,
uint8_t  Enable
Parameters
EnableEnables the Full speed
◆ USBHS_FreeMemory()
__STATIC_INLINE void USBHS_FreeMemory ( Usbhs pUsbhs,
uint8_t  Ep
Free allocated Endpoint memory
◆ USBHS_FreezeClock()
__STATIC_INLINE void USBHS_FreezeClock ( Usbhs pUsbhs)
USBHS_CTRL
Parameters
EnableEnable or disable
◆ USBHS_GetAddress()
__STATIC_INLINE uint8_t USBHS_GetAddress ( Usbhs pUsbhs)
Get USB address.
Parameters
◆ USBHS_GetConfigureEPs()
__STATIC_INLINE uint32_t USBHS_GetConfigureEPs ( Usbhs pUsbhs,
uint8_t  Ep,
uint32_t  IntType
Get Endpoint configuration
◆ USBHS_GetDmaBuffAdd()
__STATIC_INLINE uint32_t USBHS_GetDmaBuffAdd ( UsbhsDevdma pUsbDma)
Parameters
Returns
DMA addrs
◆ USBHS_GetDmaBuffCount()
__STATIC_INLINE uint16_t USBHS_GetDmaBuffCount ( UsbhsDevdma pUsbDma)
Parameters
Returns
Buffer count
◆ USBHS_GetDmaConfiguration()
__STATIC_INLINE uint32_t USBHS_GetDmaConfiguration ( UsbhsDevdma pUsbDma)
Parameters
Returns
DMA control setup
◆ USBHS_GetDmaNDA()
__STATIC_INLINE uint32_t USBHS_GetDmaNDA ( UsbhsDevdma pUsbDma)
Parameters
Returns
Next DMA descriptor
◆ USBHS_GetDmaStatus()
__STATIC_INLINE uint32_t USBHS_GetDmaStatus ( UsbhsDevdma pUsbDma)
Get Dma Status.
Parameters
Returns
Dma status
◆ USBHS_GetEpSize()
__STATIC_INLINE uint32_t USBHS_GetEpSize ( Usbhs pUsbhs,
uint8_t  Ep
Get Endpoint Size
◆ USBHS_GetEpType()
__STATIC_INLINE uint8_t USBHS_GetEpType ( Usbhs pUsbhs,
uint8_t  Ep
Get Endpoint Type
◆ USBHS_GetFrameNum()
__STATIC_INLINE uint8_t USBHS_GetFrameNum ( Usbhs pUsbhs)
Get Frame number.
Parameters
pUsbhsPointer to an USBHS instance. \retruns frame number
◆ USBHS_GetFrameNumCrcErr()
__STATIC_INLINE uint8_t USBHS_GetFrameNumCrcErr ( Usbhs pUsbhs)
Parameters
pUsbhsPointer to an USBHS instance. \retruns Frame number error status
◆ USBHS_GetHostDmaBuffAdd()
__STATIC_INLINE uint32_t USBHS_GetHostDmaBuffAdd ( UsbhsHstdma pUsbDma)
Parameters
Returns
DMA addrs
◆ USBHS_GetHostDmaConfiguration()
__STATIC_INLINE uint32_t USBHS_GetHostDmaConfiguration ( UsbhsHstdma pUsbDma)
Parameters
Returns
DMA control setup
◆ USBHS_GetHostDmaNDA()
__STATIC_INLINE uint32_t USBHS_GetHostDmaNDA ( UsbhsHstdma pUsbDma)
Parameters
Returns
Next DMA descriptor
◆ USBHS_GetHostDmaPipeStatus()
__STATIC_INLINE uint32_t USBHS_GetHostDmaPipeStatus ( Usbhs pUsbhs,
uint8_t  PipeInt
Parameters
◆ USBHS_GetHostPipeDmaStatus()
__STATIC_INLINE uint32_t USBHS_GetHostPipeDmaStatus ( UsbhsHstdma pUsbDma)
Get Dma Status.
Parameters
Returns
Dma status
◆ USBHS_GetHostPipeStatus()
__STATIC_INLINE uint32_t USBHS_GetHostPipeStatus ( Usbhs pUsbhs,
uint8_t  PipeInt
Parameters
◆ USBHS_GetHostStatus()
__STATIC_INLINE uint32_t USBHS_GetHostStatus ( Usbhs pUsbhs,
uint8_t  IntType
Parameters
◆ USBHS_GetMicroFrameNum()
__STATIC_INLINE uint8_t USBHS_GetMicroFrameNum ( Usbhs pUsbhs)
Parameters
pUsbhsPointer to an USBHS instance. \retruns Micro frame number
◆ USBHS_GetUsbSpeed()
__STATIC_INLINE uint32_t USBHS_GetUsbSpeed ( Usbhs pUsbhs)
Parameters
Returns
USB speed status
◆ USBHS_HostAckPipeIntType()
__STATIC_INLINE void USBHS_HostAckPipeIntType ( Usbhs pUsbhs,
uint8_t  Pipe,
uint32_t  intType
Parameters
◆ USBHS_HostAllocMem()
__STATIC_INLINE void USBHS_HostAllocMem ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostClearErr()
__STATIC_INLINE void USBHS_HostClearErr ( Usbhs pUsbhs,
uint8_t  Pipe,
uint8_t  Err
Parameters
◆ USBHS_HostConfigure()
__STATIC_INLINE void USBHS_HostConfigure ( Usbhs pUsbhs,
uint8_t  Pipe,
uint32_t  pipeBank,
uint8_t  pipeSize,
uint32_t  pipeType,
uint32_t  pipeToken,
uint8_t  pipeEpNum,
uint8_t  PipeIntFreq
Parameters
◆ USBHS_HostConfigureDma()
__STATIC_INLINE void USBHS_HostConfigureDma ( UsbhsHstdma pUsbDma,
uint32_t  Cfg
Parameters
◆ USBHS_HostDisableAutoSw()
__STATIC_INLINE void USBHS_HostDisableAutoSw ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostDisableInReq()
__STATIC_INLINE void USBHS_HostDisableInReq ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostDisablePipeIntType()
__STATIC_INLINE void USBHS_HostDisablePipeIntType ( Usbhs pUsbhs,
uint8_t  Pipe,
uint32_t  intType
Parameters
◆ USBHS_HostDmaIntDisable()
__STATIC_INLINE void USBHS_HostDmaIntDisable ( Usbhs pUsbhs,
uint8_t  PipeInt
Parameters
◆ USBHS_HostDmaIntEnable()
__STATIC_INLINE void USBHS_HostDmaIntEnable ( Usbhs pUsbhs,
uint8_t  PipeInt
Parameters
◆ USBHS_HostEnableAutoSw()
__STATIC_INLINE void USBHS_HostEnableAutoSw ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostEnableInReq()
__STATIC_INLINE void USBHS_HostEnableInReq ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostEnablePing()
__STATIC_INLINE void USBHS_HostEnablePing ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostEnablePipeIntType()
__STATIC_INLINE void USBHS_HostEnablePipeIntType ( Usbhs pUsbhs,
uint8_t  Pipe,
uint32_t  intType
Parameters
◆ USBHS_HostFreeMem()
__STATIC_INLINE void USBHS_HostFreeMem ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostGetCurrentBank()
__STATIC_INLINE uint8_t USBHS_HostGetCurrentBank ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostGetDataTogSeq()
__STATIC_INLINE uint8_t USBHS_HostGetDataTogSeq ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostGetErr()
__STATIC_INLINE uint8_t USBHS_HostGetErr ( Usbhs pUsbhs,
uint8_t  Pipe,
uint8_t  Err
Parameters
◆ USBHS_HostGetFramePos()
__STATIC_INLINE uint16_t USBHS_HostGetFramePos ( void  )
Parameters
◆ USBHS_HostGetIntTypeStatus()
__STATIC_INLINE uint32_t USBHS_HostGetIntTypeStatus ( Usbhs pUsbhs,
uint8_t  Pipe,
uint32_t  intType
Parameters
◆ USBHS_HostGetMSOF()
__STATIC_INLINE uint16_t USBHS_HostGetMSOF ( void  )
Parameters
◆ USBHS_HostGetNumOfBusyBank()
__STATIC_INLINE uint8_t USBHS_HostGetNumOfBusyBank ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostGetPipeByteCount()
__STATIC_INLINE uint8_t USBHS_HostGetPipeByteCount ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostGetPipeType()
__STATIC_INLINE uint32_t USBHS_HostGetPipeType ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostGetSize()
__STATIC_INLINE uint16_t USBHS_HostGetSize ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostGetSOF()
__STATIC_INLINE uint16_t USBHS_HostGetSOF ( void  )
Parameters
◆ USBHS_HostGetToken()
__STATIC_INLINE uint32_t USBHS_HostGetToken ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostInReq()
__STATIC_INLINE void USBHS_HostInReq ( Usbhs pUsbhs,
uint8_t  Pipe,
uint8_t  InReq
Parameters
◆ USBHS_HostIntDisable()
__STATIC_INLINE void USBHS_HostIntDisable ( Usbhs pUsbhs,
uint32_t  IntType
Parameters
◆ USBHS_HostIntEnable()
__STATIC_INLINE void USBHS_HostIntEnable ( Usbhs pUsbhs,
uint32_t  IntType
Parameters
◆ USBHS_HostPipeDisable()
__STATIC_INLINE void USBHS_HostPipeDisable ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostPipeEnable()
__STATIC_INLINE void USBHS_HostPipeEnable ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostPipeIntDisable()
__STATIC_INLINE void USBHS_HostPipeIntDisable ( Usbhs pUsbhs,
uint8_t  PipeInt
Parameters
◆ USBHS_HostPipeIntEnable()
__STATIC_INLINE void USBHS_HostPipeIntEnable ( Usbhs pUsbhs,
uint8_t  PipeInt
Parameters
◆ USBHS_HostPipeReset()
__STATIC_INLINE void USBHS_HostPipeReset ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_HostSetErr()
__STATIC_INLINE void USBHS_HostSetErr ( Usbhs pUsbhs,
uint8_t  Pipe,
uint8_t  Err
Parameters
◆ USBHS_HostSetIntFreq()
__STATIC_INLINE void USBHS_HostSetIntFreq ( Usbhs pUsbhs,
uint8_t  Pipe,
uint8_t  Freq
Parameters
◆ USBHS_HostSetPipeIntType()
__STATIC_INLINE void USBHS_HostSetPipeIntType ( Usbhs pUsbhs,
uint8_t  Pipe,
uint32_t  intType
Parameters
◆ USBHS_HostSetPipeType()
__STATIC_INLINE void USBHS_HostSetPipeType ( Usbhs pUsbhs,
uint8_t  Pipe,
uint8_t  PipeType
Parameters
◆ USBHS_HostSetToken()
__STATIC_INLINE void USBHS_HostSetToken ( Usbhs pUsbhs,
uint8_t  Pipe,
uint32_t  Token
Parameters
◆ USBHS_IsBankFree()
__STATIC_INLINE uint8_t USBHS_IsBankFree ( Usbhs pUsbhs,
uint8_t  Ep
Check if given endpoint's bank is free
◆ USBHS_IsBankKilled()
__STATIC_INLINE uint32_t USBHS_IsBankKilled ( Usbhs pUsbhs,
uint8_t  Ep
◆ USBHS_IsDmaIntEnable()
__STATIC_INLINE uint32_t USBHS_IsDmaIntEnable ( Usbhs pUsbhs,
uint8_t  DmaNum
Parameters
◆ USBHS_IsEnableSOF()
__STATIC_INLINE uint8_t USBHS_IsEnableSOF ( Usbhs pUsbhs)
Parameters
◆ USBHS_IsEPEnabled()
__STATIC_INLINE uint32_t USBHS_IsEPEnabled ( Usbhs pUsbhs,
uint8_t  Ep
Parameters
EpEndpoint Number
◆ USBHS_IsEpIntEnable()
__STATIC_INLINE uint32_t USBHS_IsEpIntEnable ( Usbhs pUsbhs,
uint8_t  Ep,
uint32_t  EpIntType
Check for interrupt types enabled for a given endpoint
◆ USBHS_IsHostConfigOk()
__STATIC_INLINE uint32_t USBHS_IsHostConfigOk ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_IsHostDmaIntEnable()
__STATIC_INLINE uint32_t USBHS_IsHostDmaIntEnable ( Usbhs pUsbhs,
uint8_t  PipeInt
Parameters
◆ USBHS_IsHostInReqEnable()
__STATIC_INLINE uint8_t USBHS_IsHostInReqEnable ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_IsHostIntEnable()
__STATIC_INLINE uint8_t USBHS_IsHostIntEnable ( Usbhs pUsbhs,
uint8_t  IntType
Parameters
◆ USBHS_IsHostPipeEnable()
__STATIC_INLINE uint32_t USBHS_IsHostPipeEnable ( Usbhs pUsbhs,
uint8_t  Pipe
Parameters
◆ USBHS_IsHostPipeIntEnable()
__STATIC_INLINE uint32_t USBHS_IsHostPipeIntEnable ( Usbhs pUsbhs,
uint8_t  PipeInt
Parameters
◆ USBHS_IsHostPipeIntTypeEnable()
__STATIC_INLINE uint32_t USBHS_IsHostPipeIntTypeEnable ( Usbhs pUsbhs,
uint8_t  Pipe,
uint32_t  intType
Parameters
◆ USBHS_IsIntEnable()
__STATIC_INLINE uint32_t USBHS_IsIntEnable ( Usbhs pUsbhs,
uint32_t  IntType
Parameters
◆ USBHS_IsIntEnableEP()
__STATIC_INLINE uint32_t USBHS_IsIntEnableEP ( Usbhs pUsbhs,
uint8_t  EpNum
Parameters
EpNumEndpoint number
◆ USBHS_ISUsableClock()
__STATIC_INLINE uint8_t USBHS_ISUsableClock ( Usbhs pUsbhs)
Parameters
Returns
1 if USB clock is usable
◆ USBHS_IsUsbFullSpeed()
__STATIC_INLINE bool USBHS_IsUsbFullSpeed ( Usbhs pUsbhs)
Parameters
Returns
USB speed status
◆ USBHS_IsUsbHighSpeed()
__STATIC_INLINE bool USBHS_IsUsbHighSpeed ( Usbhs pUsbhs)
Parameters
Returns
USB speed status
◆ USBHS_IsUsbLowSpeed()
__STATIC_INLINE bool USBHS_IsUsbLowSpeed ( Usbhs pUsbhs)
Parameters
Returns
USB speed status
◆ USBHS_KillBank()
__STATIC_INLINE void USBHS_KillBank ( Usbhs pUsbhs,
uint8_t  Ep
◆ USBHS_NumOfBanksInUse()
__STATIC_INLINE uint8_t USBHS_NumOfBanksInUse ( Usbhs pUsbhs,
uint8_t  Ep
Read endpoint's bank number in use
◆ USBHS_RaiseDmaInt()
__STATIC_INLINE void USBHS_RaiseDmaInt ( Usbhs pUsbhs,
uint8_t  Dma
Parameters
◆ USBHS_RaiseEPInt()
__STATIC_INLINE void USBHS_RaiseEPInt ( Usbhs pUsbhs,
uint8_t  Ep,
uint32_t  EpInt
Sets/Raise register for a given endpoint
◆ USBHS_RaiseInt()
__STATIC_INLINE void USBHS_RaiseInt ( Usbhs pUsbhs,
uint32_t  IntType
Parameters
◆ USBHS_ReadDmaIntStatus()
__STATIC_INLINE uint32_t USBHS_ReadDmaIntStatus ( Usbhs pUsbhs,
uint8_t  DmaNum
Parameters
DmaNumDMA Endpoint
◆ USBHS_ReadEpIntStatus()
__STATIC_INLINE uint32_t USBHS_ReadEpIntStatus ( Usbhs pUsbhs,
uint8_t  EpNum
Parameters
EpNumEndpoint
◆ USBHS_ReadEPStatus()
__STATIC_INLINE uint32_t USBHS_ReadEPStatus ( Usbhs pUsbhs,
uint8_t  Ep,
uint32_t  EpInt
Gets interrupt status for a given EP
◆ USBHS_ReadIntStatus()
__STATIC_INLINE uint32_t USBHS_ReadIntStatus ( Usbhs pUsbhs,
uint32_t  IntType
Parameters
IntTypeInterrupt type
◆ USBHS_ReadStatus()
__STATIC_INLINE uint32_t USBHS_ReadStatus ( Usbhs pUsbhs)
Parameters
Returns
USB status
◆ USBHS_Reset()
__STATIC_INLINE void USBHS_Reset ( void  )
Parameters
◆ USBHS_ResetEP()
__STATIC_INLINE void USBHS_ResetEP ( Usbhs pUsbhs,
uint8_t  Ep
Rests Endpoint.
Parameters
EpEndpoint Number
◆ USBHS_Resume()
__STATIC_INLINE void USBHS_Resume ( void  )
Parameters
◆ USBHS_Set()
__STATIC_INLINE void USBHS_Set ( Usbhs pUsbhs,
uint32_t  SetStatus
Parameters
◆ USBHS_SetAddress()
__STATIC_INLINE void USBHS_SetAddress ( Usbhs pUsbhs,
uint8_t  Addr
Parameters
AddrUSB device status
◆ USBHS_SetDmaBuffAdd()
__STATIC_INLINE void USBHS_SetDmaBuffAdd ( UsbhsDevdma pUsbDma,
uint32_t  Addr
Parameters
AddrDMA's buffer Addrs
◆ USBHS_SetDmaNDA()
__STATIC_INLINE void USBHS_SetDmaNDA ( UsbhsDevdma pUsbDma,
uint32_t  Desc
Parameters
DescNDA address
◆ USBHS_SetDmaStatus()
__STATIC_INLINE void USBHS_SetDmaStatus ( UsbhsDevdma pUsbDma,
uint32_t  Status
Set DMA status.
Parameters
pUsbDmaUSBHS device DMA instance \Status Set DMA status
◆ USBHS_SetHostDmaBuffAdd()
__STATIC_INLINE void USBHS_SetHostDmaBuffAdd ( UsbhsHstdma pUsbDma,
uint32_t  Addr
Parameters
◆ USBHS_SetHostDmaNDA()
__STATIC_INLINE void USBHS_SetHostDmaNDA ( UsbhsHstdma pUsbDma,
uint32_t  Desc
Parameters
DescNDA addrs
◆ USBHS_SetHostDmaStatus()
__STATIC_INLINE void USBHS_SetHostDmaStatus ( Usbhs pUsbhs,
uint8_t  PipeInt
Parameters
◆ USBHS_SetHostForcedFullSpeed()
__STATIC_INLINE void USBHS_SetHostForcedFullSpeed ( Usbhs pUsbhs)
Parameters
◆ USBHS_SetHostHighSpeed()
__STATIC_INLINE void USBHS_SetHostHighSpeed ( Usbhs pUsbhs)
Parameters
◆ USBHS_SetHostLowSpeed()
__STATIC_INLINE void USBHS_SetHostLowSpeed ( Usbhs pUsbhs)
Parameters
◆ USBHS_SetHostPipeDmaStatus()
__STATIC_INLINE void USBHS_SetHostPipeDmaStatus ( UsbhsHstdma pUsbDma,
uint32_t  Status
Set DMA status.
Parameters
◆ USBHS_SetHostStatus()
__STATIC_INLINE void USBHS_SetHostStatus ( Usbhs pUsbhs,
uint32_t  IntType
Parameters
◆ USBHS_SetIsoTrans()
__STATIC_INLINE void USBHS_SetIsoTrans ( Usbhs pUsbhs,
uint8_t  Ep,
uint8_t  nbTrans
Sets ISO endpoint's Number of Transfer for High Speed
◆ USBHS_SetRemoteWakeUp()
__STATIC_INLINE void USBHS_SetRemoteWakeUp ( Usbhs pUsbhs)
Parameters
◆ USBHS_StopReset()
__STATIC_INLINE void USBHS_StopReset ( void  )
Parameters
◆ USBHS_UnFreezeClock()
__STATIC_INLINE void USBHS_UnFreezeClock ( Usbhs pUsbhs)
Parameters
◆ USBHS_UsbEnable()
__STATIC_INLINE void USBHS_UsbEnable ( Usbhs pUsbhs,
uint8_t  Enable
Parameters
◆ USBHS_UsbMode()
__STATIC_INLINE void USBHS_UsbMode ( Usbhs pUsbhs,
USB_Mode_t  Mode
Parameters
ModeDevice or Host Mode
◆ USBHS_VBusHWC()
__STATIC_INLINE void USBHS_VBusHWC ( Usbhs pUsbhs,
uint8_t  Enable
Parameters
