This header file provides the default validation test suite runner and application configuration.
More...
#define | MAX_TLS_SIZE TEST_MAXIMUM_TLS_SIZE |
#define | MAX_TASKS ( TEST_MAXIMUM_TASKS - 1 ) |
#define | TASK_ATTRIBUTES RTEMS_FLOATING_POINT |
#define | TASK_STORAGE_SIZE |
#define | CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER |
#define | CONFIGURE_MINIMUM_TASK_STACK_SIZE TEST_MINIMUM_STACK_SIZE |
#define | CONFIGURE_INTERRUPT_STACK_SIZE TEST_INTERRUPT_STACK_SIZE |
#define | CONFIGURE_MAXIMUM_BARRIERS TEST_MAXIMUM_BARRIERS |
#define | CONFIGURE_MAXIMUM_MESSAGE_QUEUES TEST_MAXIMUM_MESSAGE_QUEUES |
#define | CONFIGURE_MAXIMUM_PARTITIONS TEST_MAXIMUM_PARTITIONS |
#define | CONFIGURE_MAXIMUM_PERIODS TEST_MAXIMUM_PERIODS |
#define | CONFIGURE_MAXIMUM_SEMAPHORES TEST_MAXIMUM_SEMAPHORES |
#define | CONFIGURE_MAXIMUM_TASKS TEST_MAXIMUM_TASKS |
#define | CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE CONFIGURE_MAXIMUM_TASKS |
#define | CONFIGURE_MAXIMUM_TIMERS TEST_MAXIMUM_TIMERS |
#define | CONFIGURE_MAXIMUM_USER_EXTENSIONS TEST_MAXIMUM_USER_EXTENSIONS |
#define | CONFIGURE_MICROSECONDS_PER_TICK TEST_MICROSECONDS_PER_TICK |
#define | CONFIGURE_TICKS_PER_TIMESLICE TEST_TICKS_PER_TIMESLICE |
#define | CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0 |
#define | CONFIGURE_DISABLE_NEWLIB_REENTRANCY |
#define | CONFIGURE_APPLICATION_DISABLE_FILESYSTEM |
#define | CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE MAX_TLS_SIZE |
#define | CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE |
#define | CONFIGURE_TASK_STACK_ALLOCATOR test_task_stack_allocate |
#define | CONFIGURE_TASK_STACK_DEALLOCATOR test_task_stack_deallocate |
#define | CONFIGURE_RTEMS_INIT_TASKS_TABLE |
#define | CONFIGURE_INIT_TASK_ARGUMENTS TEST_RUNNER_ARGUMENT |
#define | CONFIGURE_INIT_TASK_ATTRIBUTES ( RTEMS_SYSTEM_TASK | TASK_ATTRIBUTES ) |
#define | CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE TASK_STORAGE_SIZE |
#define | CONFIGURE_INIT_TASK_ENTRY_POINT Runner |
#define | CONFIGURE_INIT_TASK_INITIAL_MODES TEST_RUNNER_INITIAL_MODES |
#define | CONFIGURE_INIT_TASK_NAME TEST_RUNNER_NAME |
#define | CONFIGURE_INIT_TASK_PRIORITY 0 |
#define | CONFIGURE_INITIAL_EXTENSIONS { .fatal = FatalInitialExtension } |
#define | CONFIGURE_MAXIMUM_PROCESSORS 1 |
#define | SCHEDULER_PRIORITY_ENTRY_POINTS T_SCHEDULER_ENTRY_POINTS |
#define | CONFIGURE_SCHEDULER_PRIORITY |
#define | CONFIGURE_SCHEDULER_NAME TEST_SCHEDULER_A_NAME |
#define | CONFIGURE_MAXIMUM_PRIORITY 127 |
#define | CONFIGURE_IDLE_TASK_STACK_SIZE TEST_IDLE_STACK_SIZE |
#define | CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE test_idle_task_stack_allocate |
#define | CONFIGURE_INIT |
