RTEMS 6.1-rc4
testgcovbspreset.c File Reference
This source file contains the implementation of a wrapper for bsp_reset() which dumps the gcov information using rtems_test_gcov_dump_info() before the real bsp_reset() is called. More...
#include <rtems/test-info.h>
#include <rtems/score/cpu.h>
void __real_bsp_reset (rtems_fatal_source source, rtems_fatal_code code)
void __wrap_bsp_reset (rtems_fatal_source source, rtems_fatal_code code)
