RTEMS 6.1-rc4
test-printer.h
2
11/*
12 * Copyright (C) 2014, 2023 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef _RTEMS_TEST_PRINTER_H
37#define _RTEMS_TEST_PRINTER_H
38
39#include <rtems/printer.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
55
61int rtems_test_printf( const char *format, ... ) RTEMS_PRINTFLIKE( 1, 2 );
62
65#ifdef __cplusplus
66}
67#endif /* __cplusplus */
68
69#endif /* _RTEMS_TEST_PRINTER_H */
#define RTEMS_PRINTFLIKE(_format_pos, _ap_pos)
Tells the compiler in a declaration that this function expects printf()-like arguments.
Definition: basedefs.h:772
rtems_printer rtems_test_printer
Provides an RTEMS printer for tests.
Definition: testprinter.c:44
int rtems_test_printf(const char *format,...) RTEMS_PRINTFLIKE(1
Prints via the RTEMS test printer.
User print interface to the bspIO print plug in.
Definition: mknod-pack_dev.c:254
Definition: printer.h:76
