RTEMS 6.1-rc4
This header file provides functions used by corresponding test suite. More...
void | ThreadBeginExtension0 (rtems_tcb *executing) |
bool | ThreadCreateExtension0 (rtems_tcb *executing, rtems_tcb *created) |
void | ThreadDeleteExtension0 (rtems_tcb *executing, rtems_tcb *deleted) |
void | ThreadExittedExtension0 (rtems_tcb *executing) |
void | ThreadRestartExtension0 (rtems_tcb *executing, rtems_tcb *restarted) |
void | ThreadStartExtension0 (rtems_tcb *executing, rtems_tcb *started) |
void | ThreadSwitchExtension0 (rtems_tcb *executing, rtems_tcb *heir) |
void | ThreadTerminateExtension0 (rtems_tcb *executing) |
void | FatalExtension0 (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
void | ThreadBeginExtension1 (rtems_tcb *executing) |
bool | ThreadCreateExtension1 (rtems_tcb *executing, rtems_tcb *created) |
void | ThreadDeleteExtension1 (rtems_tcb *executing, rtems_tcb *deleted) |
void | ThreadExittedExtension1 (rtems_tcb *executing) |
void | ThreadRestartExtension1 (rtems_tcb *executing, rtems_tcb *restarted) |
void | ThreadStartExtension1 (rtems_tcb *executing, rtems_tcb *started) |
void | ThreadSwitchExtension1 (rtems_tcb *executing, rtems_tcb *heir) |
void | ThreadTerminateExtension1 (rtems_tcb *executing) |
void | FatalExtension1 (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
