RTEMS 6.1-rc4
Tests system termination procedure. More...
Files | |
file | tc-terminate.c |
file | tc-userext.h |
This header file provides functions used by corresponding test suite. | |
struct | FatalInfo |
void * | __real__CPU_Thread_Idle_body (void *arg) |
void * | __wrap__CPU_Thread_Idle_body (void *arg) |
void | FatalExtension0 (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
void | FatalExtension1 (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
T_TEST_CASE (ScoreInterrValTerminate) | |
This test case performs the following actions:
