RTEMS 6.1-rc4
rtems_stack_checker_info Struct Reference
Stack information provided by the stack checker. More...
#include <stackchk.h>
rtems_id id
const char * name
const void * begin
uintptr_t size
const void * current
uintptr_t used
Field Documentation
◆ begin
const void* rtems_stack_checker_info::begin
This member provides the begin address of the stack area.
◆ current
const void* rtems_stack_checker_info::current
This member provides the current stack pointer of the stack.
If the current stack pointer is not available, then the value is set to NULL.
◆ id
rtems_id rtems_stack_checker_info::id
This member contains the object identifier associated with the object using the stack.
For interrupt stacks, the object identifier is the processor index.
◆ name
const char* rtems_stack_checker_info::name
This member provides the object name associated with the object using the stack.
For interrupt stacks, the object name is "Interrupt Stack".
◆ size
uintptr_t rtems_stack_checker_info::size
This member contains the size in bytes of the stack area.
◆ used
uintptr_t rtems_stack_checker_info::used
This member contains the size in bytes of the used stack area.
If the stack checker is not initialized, then the value is set to UINTPTR_MAX.
