RTEMS 6.1-rc4
rtems_nvdisk_config Struct Reference
#include <nvdisk.h>
uint32_t block_size
uint32_t device_count
const rtems_nvdisk_device_descdevices
uint32_t flags
uint32_t info_level
RTEMS Non-Volatile Disk configuration table used to initialise the driver.
Field Documentation
◆ block_size
uint32_t rtems_nvdisk_config::block_size
The block size.
◆ device_count
uint32_t rtems_nvdisk_config::device_count
The number of devices.
◆ devices
const rtems_nvdisk_device_desc* rtems_nvdisk_config::devices
The device descriptions.
◆ flags
uint32_t rtems_nvdisk_config::flags
Set of flags to control driver.
◆ info_level
uint32_t rtems_nvdisk_config::info_level
Default info level.
