RTEMS 6.1-rc4
_sai_transfer_format Struct Reference
sai transfer format More...
#include <fsl_sai.h>
uint32_t sampleRate_Hz
uint32_t bitWidth
sai_mono_stereo_t stereo
uint8_t channel
uint8_t channelMask
uint8_t endChannel
uint8_t channelNums
sai_protocol_t protocol
bool isFrameSyncCompact
sai transfer format
Field Documentation
◆ bitWidth
uint32_t _sai_transfer_format::bitWidth
Data length of audio data, usually 8/16/24/32 bits
◆ channel
uint8_t _sai_transfer_format::channel
Transfer start channel
◆ channelMask
uint8_t _sai_transfer_format::channelMask
enabled channel mask value, reference _sai_channel_mask
◆ channelNums
uint8_t _sai_transfer_format::channelNums
Total enabled channel numbers
◆ endChannel
uint8_t _sai_transfer_format::endChannel
end channel number
◆ isFrameSyncCompact
bool _sai_transfer_format::isFrameSyncCompact
True means Frame sync length is configurable according to bitWidth, false means frame sync length is 64 times of bit clock.
◆ protocol
sai_protocol_t _sai_transfer_format::protocol
Which audio protocol used
◆ sampleRate_Hz
uint32_t _sai_transfer_format::sampleRate_Hz
Sample rate of audio data
◆ stereo
sai_mono_stereo_t _sai_transfer_format::stereo
Mono or stereo
