RTEMS 6.1-rc4
_sai_serial_data Struct Reference
sai serial data configurations More...
#include <fsl_sai.h>
sai_data_order_t dataOrder
uint8_t dataWord0Length
uint8_t dataWordNLength
uint8_t dataWordLength
uint8_t dataFirstBitShifted
uint8_t dataWordNum
uint32_t dataMaskedWord
Field Documentation
◆ dataFirstBitShifted
uint8_t _sai_serial_data::dataFirstBitShifted
Configure the bit index for the first bit transmitted for each word in the frame
◆ dataMaskedWord
uint32_t _sai_serial_data::dataMaskedWord
configure whether the transmit word is masked
◆ dataOrder
sai_data_order_t _sai_serial_data::dataOrder
configure whether the LSB or MSB is transmitted first
◆ dataWord0Length
uint8_t _sai_serial_data::dataWord0Length
configure the number of bits in the first word in each frame
◆ dataWordLength
uint8_t _sai_serial_data::dataWordLength
used to record the data length for dma transfer
◆ dataWordNLength
uint8_t _sai_serial_data::dataWordNLength
configure the number of bits in the each word in each frame, except the first word
◆ dataWordNum
uint8_t _sai_serial_data::dataWordNum
configure the number of words in each frame
