RTEMS 6.1-rc4
_pwm_signal_param Struct Reference
Structure for the user to define the PWM signal characteristics. More...
#include <fsl_pwm.h>
pwm_channels_t pwmChannel
uint8_t dutyCyclePercent
pwm_level_select_t level
uint16_t deadtimeValue
pwm_fault_state_t faultState
bool pwmchannelenable
Field Documentation
◆ deadtimeValue
uint16_t _pwm_signal_param::deadtimeValue
The deadtime value; only used if channel pair is operating in complementary mode
◆ dutyCyclePercent
uint8_t _pwm_signal_param::dutyCyclePercent
PWM pulse width, value should be between 0 to 100 0=inactive signal(0% duty cycle)... 100=always active signal (100% duty cycle)
◆ faultState
pwm_fault_state_t _pwm_signal_param::faultState
PWM output fault status
◆ level
pwm_level_select_t _pwm_signal_param::level
PWM output active level select
◆ pwmChannel
pwm_channels_t _pwm_signal_param::pwmChannel
PWM channel being configured; PWM A or PWM B
◆ pwmchannelenable
bool _pwm_signal_param::pwmchannelenable
Enable PWM output
