RTEMS 6.1-rc4
_lpspi_master_config Struct Reference
LPSPI master configuration structure. More...
#include <fsl_lpspi.h>
uint32_t baudRate
uint32_t bitsPerFrame
lpspi_clock_polarity_t cpol
lpspi_clock_phase_t cpha
lpspi_shift_direction_t direction
uint32_t pcsToSckDelayInNanoSec
uint32_t lastSckToPcsDelayInNanoSec
uint32_t betweenTransferDelayInNanoSec
lpspi_which_pcs_t whichPcs
lpspi_pcs_polarity_config_t pcsActiveHighOrLow
lpspi_pin_config_t pinCfg
lpspi_data_out_config_t dataOutConfig
bool enableInputDelay
Field Documentation
◆ baudRate
uint32_t _lpspi_master_config::baudRate
Baud Rate for LPSPI.
◆ betweenTransferDelayInNanoSec
uint32_t _lpspi_master_config::betweenTransferDelayInNanoSec
After the SCK delay time with nanoseconds, setting to 0 sets the minimum delay. It sets the boundary value if out of range.
◆ bitsPerFrame
uint32_t _lpspi_master_config::bitsPerFrame
Bits per frame, minimum 8, maximum 4096.
◆ cpha
lpspi_clock_phase_t _lpspi_master_config::cpha
Clock phase.
◆ cpol
lpspi_clock_polarity_t _lpspi_master_config::cpol
Clock polarity.
◆ dataOutConfig
lpspi_data_out_config_t _lpspi_master_config::dataOutConfig
Configures if the output data is tristated between accesses (LPSPI_PCS is negated).
◆ direction
lpspi_shift_direction_t _lpspi_master_config::direction
MSB or LSB data shift direction.
◆ enableInputDelay
bool _lpspi_master_config::enableInputDelay
Enable master to sample the input data on a delayed SCK. This can help improve slave setup time. Refer to device data sheet for specific time length.
◆ lastSckToPcsDelayInNanoSec
uint32_t _lpspi_master_config::lastSckToPcsDelayInNanoSec
Last SCK to PCS delay time in nanoseconds, setting to 0 sets the minimum delay. It sets the boundary value if out of range.
◆ pcsActiveHighOrLow
lpspi_pcs_polarity_config_t _lpspi_master_config::pcsActiveHighOrLow
Desired PCS active high or low
◆ pcsToSckDelayInNanoSec
uint32_t _lpspi_master_config::pcsToSckDelayInNanoSec
PCS to SCK delay time in nanoseconds, setting to 0 sets the minimum delay. It sets the boundary value if out of range.
◆ pinCfg
lpspi_pin_config_t _lpspi_master_config::pinCfg
Configures which pins are used for input and output data during single bit transfers.
◆ whichPcs
lpspi_which_pcs_t _lpspi_master_config::whichPcs
Desired Peripheral Chip Select (PCS).
