RTEMS 6.1-rc4
_enet_buffer_config Struct Reference
Defines the receive buffer descriptor configuration structure. More...
#include <fsl_enet.h>
uint16_t rxBdNumber
uint16_t txBdNumber
uint16_t rxBuffSizeAlign
uint16_t txBuffSizeAlign
volatile enet_rx_bd_struct_trxBdStartAddrAlign
volatile enet_tx_bd_struct_ttxBdStartAddrAlign
uint8_t * rxBufferAlign
uint8_t * txBufferAlign
bool rxMaintainEnable
bool txMaintainEnable
enet_frame_info_ttxFrameInfo
Note that for the internal DMA requirements, the buffers have a corresponding alignment requirements.
  1. The aligned receive and transmit buffer size must be evenly divisible by ENET_BUFF_ALIGNMENT. when the data buffers are in cacheable region when cache is enabled, all those size should be aligned to the maximum value of "ENET_BUFF_ALIGNMENT" and the cache line size.
  2. The aligned transmit and receive buffer descriptor start address must be at least 64 bit aligned. However, it's recommended to be evenly divisible by ENET_BUFF_ALIGNMENT. buffer descriptors should be put in non-cacheable region when cache is enabled.
  3. The aligned transmit and receive data buffer start address must be evenly divisible by ENET_BUFF_ALIGNMENT. Receive buffers should be continuous with the total size equal to "rxBdNumber * rxBuffSizeAlign". Transmit buffers should be continuous with the total size equal to "txBdNumber * txBuffSizeAlign". when the data buffers are in cacheable region when cache is enabled, all those size should be aligned to the maximum value of "ENET_BUFF_ALIGNMENT" and the cache line size.
