RTEMS 6.1-rc4
_dsi_dphy_config Struct Reference
MIPI DSI D-PHY configuration. More...
#include <fsl_mipi_dsi.h>
uint32_t txHsBitClk_Hz
uint8_t tClkPre_ByteClk
uint8_t tClkPost_ByteClk
uint8_t tHsExit_ByteClk
uint32_t tWakeup_EscClk
uint8_t tHsPrepare_HalfEscClk
uint8_t tClkPrepare_HalfEscClk
uint8_t tHsZero_ByteClk
uint8_t tClkZero_ByteClk
uint8_t tHsTrail_ByteClk
uint8_t tClkTrail_ByteClk
Field Documentation
◆ tClkPost_ByteClk
uint8_t _dsi_dphy_config::tClkPost_ByteClk
TCLK-POST + T_CLK-TRAIL in byte clock. Set how long the controller will wait before putting clock lane into LP mode after data lanes detected in stop state.
◆ tClkPre_ByteClk
uint8_t _dsi_dphy_config::tClkPre_ByteClk
TLPX + TCLK-PREPARE + TCLK-ZERO + TCLK-PRE in byte clock. Set how long the controller will wait after enabling clock lane for HS before enabling data lanes for HS.
◆ tClkPrepare_HalfEscClk
uint8_t _dsi_dphy_config::tClkPrepare_HalfEscClk
TCLK-PREPARE in clk_esc/2. Set how long to drive the LP-00 state before HS transmissions, available values are 2, 3.
◆ tClkTrail_ByteClk
uint8_t _dsi_dphy_config::tClkTrail_ByteClk
TCLK-TRAIL + 4*UI in clk_byte. Set the time of the flipped differential state after last payload data bit of HS transmission burst. Available values are 0, 1, ..., 15.
◆ tClkZero_ByteClk
uint8_t _dsi_dphy_config::tClkZero_ByteClk
TCLK-ZERO in clk_byte. Set how long that controller drives clock lane HS-0 state before transmit the Sync sequence. Available values are 3, 4, ..., 66.
◆ tHsExit_ByteClk
uint8_t _dsi_dphy_config::tHsExit_ByteClk
THS-EXIT in byte clock. Set how long the controller will wait after the clock lane has been put into LP mode before enabling clock lane for HS again.
◆ tHsPrepare_HalfEscClk
uint8_t _dsi_dphy_config::tHsPrepare_HalfEscClk
THS-PREPARE in clk_esc/2. Set how long to drive the LP-00 state before HS transmissions, available values are 2, 3, 4, 5.
◆ tHsTrail_ByteClk
uint8_t _dsi_dphy_config::tHsTrail_ByteClk
THS-TRAIL + 4*UI in clk_byte. Set the time of the flipped differential state after last payload data bit of HS transmission burst. Available values are 0, 1, ..., 15.
◆ tHsZero_ByteClk
uint8_t _dsi_dphy_config::tHsZero_ByteClk
THS-ZERO in clk_byte. Set how long that controller drives data lane HS-0 state before transmit the Sync sequence. Available values are 6, 7, ..., 37.
◆ tWakeup_EscClk
uint32_t _dsi_dphy_config::tWakeup_EscClk
Number of clk_esc clock periods to keep a clock or data lane in Mark-1 state after exiting ULPS.
◆ txHsBitClk_Hz
uint32_t _dsi_dphy_config::txHsBitClk_Hz
The generated HS TX bit clock in Hz.
