RTEMS 6.1-rc4
_dsi_config Struct Reference
MIPI DSI controller configuration. More...
#include <fsl_mipi_dsi.h>
uint8_t numLanes
bool enableNonContinuousHsClk
bool enableTxUlps
bool autoInsertEoTp
uint8_t numExtraEoTp
uint32_t htxTo_ByteClk
uint32_t lrxHostTo_ByteClk
uint32_t btaTo_ByteClk
Field Documentation
◆ autoInsertEoTp
bool _dsi_config::autoInsertEoTp
Insert an EoTp short package when switching from HS to LP.
◆ btaTo_ByteClk
uint32_t _dsi_config::btaTo_ByteClk
Bus turn around timeout count (TA_TO) in byte clock.
◆ enableNonContinuousHsClk
bool _dsi_config::enableNonContinuousHsClk
In enabled, the high speed clock will enter low power mode between transmissions.
◆ enableTxUlps
bool _dsi_config::enableTxUlps
Enable the TX ULPS.
◆ htxTo_ByteClk
uint32_t _dsi_config::htxTo_ByteClk
HS TX timeout count (HTX_TO) in byte clock.
◆ lrxHostTo_ByteClk
uint32_t _dsi_config::lrxHostTo_ByteClk
LP RX host timeout count (LRX-H_TO) in byte clock.
◆ numExtraEoTp
uint8_t _dsi_config::numExtraEoTp
How many extra EoTp to send after the end of a packet.
◆ numLanes
uint8_t _dsi_config::numLanes
Number of lanes.
