RTEMS 6.1-rc4
Test context for spec:/rtems/task/req/wake-after test case. More...
Data Fields | |
T_scheduler_log_4 | scheduler_log |
This member provides the scheduler operation records. | |
uint64_t | now |
This member contains the clock tick value before the rtems_task_wake_after() call. | |
rtems_id | worker_id |
This member contains the worker task identifier. | |
bool | suspended |
If this member is true, then the worker shall be suspended during the rtems_task_wake_after() call. | |
TaskTimerInfo | timer_info |
This member contains the timer information of the worker task. | |
rtems_status_code | status |
This member contains the return value of the rtems_task_wake_after() call. | |
rtems_interval | ticks |
This member specifies the ticks parameter value. | |
struct { | |
size_t pcs [2] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsTaskReqWakeAfter_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
