RTEMS 6.1-rc4
Test context for spec:/rtems/task/req/create-errors test case. More...
rtems_status_code status
rtems_idid
rtems_id id_value
bool create_extension_status
uint32_t create_extension_calls
uint32_t delete_extension_calls
rtems_name name
rtems_task_priority initial_priority
size_t stack_size
rtems_attribute attributes
rtems_id extension_id
void * seized_objects
struct {
   size_t   pcs [7]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsTaskReqCreateErrors_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
