RTEMS 6.1-rc4
Test context for spec:/rtems/scheduler/req/get-maximum-priority test case. More...
rtems_id scheduler_id
 This member contains the identifier of a scheduler.
rtems_task_priority priority_obj
 This member provides the object referenced by the priority parameter.
rtems_status_code status
 This member contains the return value of the rtems_scheduler_get_maximum_priority() call.
rtems_id id
 This member specifies if the scheduler_id parameter value.
rtems_task_prioritypriority
 This member specifies if the priority parameter value.
struct {
   size_t   pcs [2]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsSchedulerReqGetMaximumPriority_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
