RTEMS 6.1-rc4
Test context for spec:/rtems/ratemon/req/cancel test case. More...
Data Fields | |
rtems_id | period_id |
This member contains a valid identifier of a period. | |
rtems_rate_monotonic_period_status | period_status |
This member is used to receive the rtems_rate_monotonic_period_status after the action. | |
rtems_id | id_param |
This member specifies the id parameter for the action. | |
rtems_status_code | status |
This member contains the returned status code of the action. | |
void(* | do_action )(void *ctx) |
This member contains the pointer to the function which executes the action. | |
rtems_id | task_id |
This member contains the task identifier of the owner task. | |
rtems_id | worker_id |
This member contains the task identifier of the worker task (which is not the owner task). | |
rtems_id | original_priority |
This member contains a backup of the task priority before the execution of this test. | |
uint32_t | postponed_jobs_count |
This member contains the number of postponed jobs before the action. | |
rtems_rate_monotonic_period_states | previous_state |
This member contains the state before the action. | |
struct { | |
size_t pci [4] | |
This member defines the pre-condition indices for the next action. | |
size_t pcs [4] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsRatemonReqCancel_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
void(* RtemsRatemonReqCancel_Context::do_action) (void *ctx) |
The action is either executed by the owner task or by the worker task depending on the function pointer used here. argument
is a pointer to this context structure.
