RTEMS 6.1-rc4
Test context for spec:/rtems/message/req/construct test case. More...
rtems_status_code status
const rtems_message_queue_configconfig
rtems_message_queue_config config_obj
rtems_idid
rtems_id id_obj
void * seized_objects
uint32_t storage_free_counter
uint32_t expected_storage_free_counter
struct {
   size_t   pcs [9]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsMessageReqConstruct_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
