RTEMS 6.1-rc4
Test context for spec:/rtems/clock/req/get-tod test case. More...
Data Fields | |
rtems_status_code | set_tod_status |
rtems_time_of_day | set_tod_value |
rtems_time_of_day * | get_tod_ref |
rtems_time_of_day | get_tod_value |
rtems_status_code | get_tod_status |
bool | isDef |
struct { | |
size_t pcs [2] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsClockReqGetTod_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
