RTEMS 6.1-rc4
PwmCh_num Struct Reference
PwmCh_num hardware registers. More...
#include <component_pwm.h>
__IO uint32_t PWM_CMR
 (PwmCh_num Offset: 0x0) PWM Channel Mode Register
__IO uint32_t PWM_CDTY
 (PwmCh_num Offset: 0x4) PWM Channel Duty Cycle Register
__O uint32_t PWM_CDTYUPD
 (PwmCh_num Offset: 0x8) PWM Channel Duty Cycle Update Register
__IO uint32_t PWM_CPRD
 (PwmCh_num Offset: 0xC) PWM Channel Period Register
__O uint32_t PWM_CPRDUPD
 (PwmCh_num Offset: 0x10) PWM Channel Period Update Register
__I uint32_t PWM_CCNT
 (PwmCh_num Offset: 0x14) PWM Channel Counter Register
__IO uint32_t PWM_DT
 (PwmCh_num Offset: 0x18) PWM Channel Dead Time Register
__O uint32_t PWM_DTUPD
 (PwmCh_num Offset: 0x1C) PWM Channel Dead Time Update Register
The documentation for this struct was generated from the following files:
