20#ifndef STM32H7xx_HAL_PWR_H
21#define STM32H7xx_HAL_PWR_H
75#define PWR_PVDLEVEL_0 PWR_CR1_PLS_LEV0
77#define PWR_PVDLEVEL_1 PWR_CR1_PLS_LEV1
79#define PWR_PVDLEVEL_2 PWR_CR1_PLS_LEV2
81#define PWR_PVDLEVEL_3 PWR_CR1_PLS_LEV3
83#define PWR_PVDLEVEL_4 PWR_CR1_PLS_LEV4
85#define PWR_PVDLEVEL_5 PWR_CR1_PLS_LEV5
87#define PWR_PVDLEVEL_6 PWR_CR1_PLS_LEV6
89#define PWR_PVDLEVEL_7 PWR_CR1_PLS_LEV7
99#define PWR_PVD_MODE_NORMAL (0x00000000U)
100#define PWR_PVD_MODE_IT_RISING (0x00010001U)
101#define PWR_PVD_MODE_IT_FALLING (0x00010002U)
102#define PWR_PVD_MODE_IT_RISING_FALLING (0x00010003U)
103#define PWR_PVD_MODE_EVENT_RISING (0x00020001U)
104#define PWR_PVD_MODE_EVENT_FALLING (0x00020002U)
105#define PWR_PVD_MODE_EVENT_RISING_FALLING (0x00020003U)
114#define PWR_MAINREGULATOR_ON (0U)
115#define PWR_LOWPOWERREGULATOR_ON PWR_CR1_LPDS
124#define PWR_SLEEPENTRY_WFI (0x01U)
125#define PWR_SLEEPENTRY_WFE (0x02U)
134#define PWR_STOPENTRY_WFI (0x01U)
135#define PWR_STOPENTRY_WFE (0x02U)
144#if defined(PWR_SRDCR_VOS)
145#define PWR_REGULATOR_VOLTAGE_SCALE0 (PWR_SRDCR_VOS_1 | PWR_SRDCR_VOS_0)
146#define PWR_REGULATOR_VOLTAGE_SCALE1 (PWR_SRDCR_VOS_1)
147#define PWR_REGULATOR_VOLTAGE_SCALE2 (PWR_SRDCR_VOS_0)
148#define PWR_REGULATOR_VOLTAGE_SCALE3 (0U)
150#define PWR_REGULATOR_VOLTAGE_SCALE0 (0U)
151#define PWR_REGULATOR_VOLTAGE_SCALE1 (PWR_D3CR_VOS_1 | PWR_D3CR_VOS_0)
152#define PWR_REGULATOR_VOLTAGE_SCALE2 (PWR_D3CR_VOS_1)
153#define PWR_REGULATOR_VOLTAGE_SCALE3 (PWR_D3CR_VOS_0)
164#define PWR_FLAG_STOP (0x01U)
165#if defined (PWR_CPUCR_SBF_D2)
166#define PWR_FLAG_SB_D1 (0x02U)
167#define PWR_FLAG_SB_D2 (0x03U)
169#define PWR_FLAG_SB (0x04U)
170#if defined (DUAL_CORE)
171#define PWR_FLAG_CPU_HOLD (0x05U)
172#define PWR_FLAG_CPU2_HOLD (0x06U)
173#define PWR_FLAG2_STOP (0x07U)
174#define PWR_FLAG2_SB_D1 (0x08U)
175#define PWR_FLAG2_SB_D2 (0x09U)
176#define PWR_FLAG2_SB (0x0AU)
178#define PWR_FLAG_PVDO (0x0BU)
179#define PWR_FLAG_AVDO (0x0CU)
180#define PWR_FLAG_ACTVOSRDY (0x0DU)
181#define PWR_FLAG_ACTVOS (0x0EU)
182#define PWR_FLAG_BRR (0x0FU)
183#define PWR_FLAG_VOSRDY (0x10U)
185#define PWR_FLAG_SMPSEXTRDY (0x11U)
187#define PWR_FLAG_SCUEN (0x11U)
189#if defined (PWR_CSR1_MMCVDO)
190#define PWR_FLAG_MMCVDO (0x12U)
192#define PWR_FLAG_USB33RDY (0x13U)
193#define PWR_FLAG_TEMPH (0x14U)
194#define PWR_FLAG_TEMPL (0x15U)
195#define PWR_FLAG_VBATH (0x16U)
196#define PWR_FLAG_VBATL (0x17U)
199#define PWR_FLAG_WKUP1 PWR_WKUPCR_WKUPC1
200#define PWR_FLAG_WKUP2 PWR_WKUPCR_WKUPC2
201#define PWR_FLAG_WKUP3 PWR_WKUPCR_WKUPC3
202#define PWR_FLAG_WKUP4 PWR_WKUPCR_WKUPC4
203#define PWR_FLAG_WKUP5 PWR_WKUPCR_WKUPC5
204#define PWR_FLAG_WKUP6 PWR_WKUPCR_WKUPC6
213#define PWR_EWUP_MASK (0x0FFF3F3FU)
258#if defined (PWR_SRDCR_VOS)
259#define __HAL_PWR_VOLTAGESCALING_CONFIG(__REGULATOR__) \
261 __IO uint32_t tmpreg = 0x00; \
263 MODIFY_REG(PWR->SRDCR, PWR_SRDCR_VOS, (__REGULATOR__)); \
265 tmpreg = READ_BIT(PWR->SRDCR, PWR_SRDCR_VOS); \
269#if defined(SYSCFG_PWRCR_ODEN)
270#define __HAL_PWR_VOLTAGESCALING_CONFIG(__REGULATOR__) \
272 __IO uint32_t tmpreg = 0x00; \
274 if((__REGULATOR__) == PWR_REGULATOR_VOLTAGE_SCALE0) \
277 MODIFY_REG(PWR->D3CR, PWR_D3CR_VOS, PWR_REGULATOR_VOLTAGE_SCALE1); \
279 tmpreg = READ_BIT(PWR->D3CR, PWR_D3CR_VOS); \
281 SET_BIT(SYSCFG->PWRCR, SYSCFG_PWRCR_ODEN); \
283 tmpreg = READ_BIT(SYSCFG->PWRCR, SYSCFG_PWRCR_ODEN); \
288 CLEAR_BIT(SYSCFG->PWRCR, SYSCFG_PWRCR_ODEN); \
290 tmpreg = READ_BIT(SYSCFG->PWRCR, SYSCFG_PWRCR_ODEN); \
292 MODIFY_REG(PWR->D3CR, PWR_D3CR_VOS, (__REGULATOR__)); \
294 tmpreg = READ_BIT(PWR->D3CR, PWR_D3CR_VOS); \
299#define __HAL_PWR_VOLTAGESCALING_CONFIG(__REGULATOR__) \
301 __IO uint32_t tmpreg = 0x00; \
303 MODIFY_REG (PWR->D3CR, PWR_D3CR_VOS, (__REGULATOR__)); \
305 tmpreg = READ_BIT(PWR->D3CR, PWR_D3CR_VOS); \
388#if defined (DUAL_CORE)
389#define __HAL_PWR_GET_FLAG(__FLAG__) \
390(((__FLAG__) == PWR_FLAG_PVDO) ? ((PWR->CSR1 & PWR_CSR1_PVDO) == PWR_CSR1_PVDO) :\
391 ((__FLAG__) == PWR_FLAG_AVDO) ? ((PWR->CSR1 & PWR_CSR1_AVDO) == PWR_CSR1_AVDO) :\
392 ((__FLAG__) == PWR_FLAG_ACTVOSRDY) ? ((PWR->CSR1 & PWR_CSR1_ACTVOSRDY) == PWR_CSR1_ACTVOSRDY) :\
393 ((__FLAG__) == PWR_FLAG_VOSRDY) ? ((PWR->D3CR & PWR_D3CR_VOSRDY) == PWR_D3CR_VOSRDY) :\
394 ((__FLAG__) == PWR_FLAG_SMPSEXTRDY) ? ((PWR->CR3 & PWR_CR3_SMPSEXTRDY) == PWR_CR3_SMPSEXTRDY) :\
395 ((__FLAG__) == PWR_FLAG_BRR) ? ((PWR->CR2 & PWR_CR2_BRRDY) == PWR_CR2_BRRDY) :\
396 ((__FLAG__) == PWR_FLAG_CPU_HOLD) ? ((PWR->CPU2CR & PWR_CPU2CR_HOLD1F) == PWR_CPU2CR_HOLD1F) :\
397 ((__FLAG__) == PWR_FLAG_CPU2_HOLD) ? ((PWR->CPUCR & PWR_CPUCR_HOLD2F) == PWR_CPUCR_HOLD2F) :\
398 ((__FLAG__) == PWR_FLAG_SB) ? ((PWR->CPUCR & PWR_CPUCR_SBF) == PWR_CPUCR_SBF) :\
399 ((__FLAG__) == PWR_FLAG2_SB) ? ((PWR->CPU2CR & PWR_CPU2CR_SBF) == PWR_CPU2CR_SBF) :\
400 ((__FLAG__) == PWR_FLAG_STOP) ? ((PWR->CPUCR & PWR_CPUCR_STOPF) == PWR_CPUCR_STOPF) :\
401 ((__FLAG__) == PWR_FLAG2_STOP) ? ((PWR->CPU2CR & PWR_CPU2CR_STOPF) == PWR_CPU2CR_STOPF) :\
402 ((__FLAG__) == PWR_FLAG_SB_D1) ? ((PWR->CPUCR & PWR_CPUCR_SBF_D1) == PWR_CPUCR_SBF_D1) :\
403 ((__FLAG__) == PWR_FLAG2_SB_D1) ? ((PWR->CPU2CR & PWR_CPU2CR_SBF_D1) == PWR_CPU2CR_SBF_D1) :\
404 ((__FLAG__) == PWR_FLAG_SB_D2) ? ((PWR->CPUCR & PWR_CPUCR_SBF_D2) == PWR_CPUCR_SBF_D2) :\
405 ((__FLAG__) == PWR_FLAG2_SB_D2) ? ((PWR->CPU2CR & PWR_CPU2CR_SBF_D2) == PWR_CPU2CR_SBF_D2) :\
406 ((__FLAG__) == PWR_FLAG_USB33RDY) ? ((PWR->CR3 & PWR_CR3_USB33RDY) == PWR_CR3_USB33RDY) :\
407 ((__FLAG__) == PWR_FLAG_TEMPH) ? ((PWR->CR2 & PWR_CR2_TEMPH) == PWR_CR2_TEMPH) :\
408 ((__FLAG__) == PWR_FLAG_TEMPL) ? ((PWR->CR2 & PWR_CR2_TEMPL) == PWR_CR2_TEMPL) :\
409 ((__FLAG__) == PWR_FLAG_VBATH) ? ((PWR->CR2 & PWR_CR2_VBATH) == PWR_CR2_VBATH) :\
410 ((PWR->CR2 & PWR_CR2_VBATL) == PWR_CR2_VBATL))
412#if defined (PWR_CPUCR_SBF_D2)
414#define __HAL_PWR_GET_FLAG(__FLAG__) \
415(((__FLAG__) == PWR_FLAG_PVDO) ? ((PWR->CSR1 & PWR_CSR1_PVDO) == PWR_CSR1_PVDO) :\
416 ((__FLAG__) == PWR_FLAG_AVDO) ? ((PWR->CSR1 & PWR_CSR1_AVDO) == PWR_CSR1_AVDO) :\
417 ((__FLAG__) == PWR_FLAG_ACTVOSRDY) ? ((PWR->CSR1 & PWR_CSR1_ACTVOSRDY) == PWR_CSR1_ACTVOSRDY) :\
418 ((__FLAG__) == PWR_FLAG_VOSRDY) ? ((PWR->D3CR & PWR_D3CR_VOSRDY) == PWR_D3CR_VOSRDY) :\
419 ((__FLAG__) == PWR_FLAG_SMPSEXTRDY) ? ((PWR->CR3 & PWR_FLAG_SMPSEXTRDY) == PWR_FLAG_SMPSEXTRDY) :\
420 ((__FLAG__) == PWR_FLAG_BRR) ? ((PWR->CR2 & PWR_CR2_BRRDY) == PWR_CR2_BRRDY) :\
421 ((__FLAG__) == PWR_FLAG_SB) ? ((PWR->CPUCR & PWR_CPUCR_SBF) == PWR_CPUCR_SBF) :\
422 ((__FLAG__) == PWR_FLAG_STOP) ? ((PWR->CPUCR & PWR_CPUCR_STOPF) == PWR_CPUCR_STOPF) :\
423 ((__FLAG__) == PWR_FLAG_SB_D1) ? ((PWR->CPUCR & PWR_CPUCR_SBF_D1) == PWR_CPUCR_SBF_D1) :\
424 ((__FLAG__) == PWR_FLAG_SB_D2) ? ((PWR->CPUCR & PWR_CPUCR_SBF_D2) == PWR_CPUCR_SBF_D2) :\
425 ((__FLAG__) == PWR_FLAG_USB33RDY) ? ((PWR->CR3 & PWR_CR3_USB33RDY) == PWR_CR3_USB33RDY) :\
426 ((__FLAG__) == PWR_FLAG_TEMPH) ? ((PWR->CR2 & PWR_CR2_TEMPH) == PWR_CR2_TEMPH) :\
427 ((__FLAG__) == PWR_FLAG_TEMPL) ? ((PWR->CR2 & PWR_CR2_TEMPL) == PWR_CR2_TEMPL) :\
428 ((__FLAG__) == PWR_FLAG_VBATH) ? ((PWR->CR2 & PWR_CR2_VBATH) == PWR_CR2_VBATH) :\
429 ((PWR->CR2 & PWR_CR2_VBATL) == PWR_CR2_VBATL))
431#define __HAL_PWR_GET_FLAG(__FLAG__) \
432(((__FLAG__) == PWR_FLAG_PVDO) ? ((PWR->CSR1 & PWR_CSR1_PVDO) == PWR_CSR1_PVDO) :\
433 ((__FLAG__) == PWR_FLAG_AVDO) ? ((PWR->CSR1 & PWR_CSR1_AVDO) == PWR_CSR1_AVDO) :\
434 ((__FLAG__) == PWR_FLAG_ACTVOSRDY) ? ((PWR->CSR1 & PWR_CSR1_ACTVOSRDY) == PWR_CSR1_ACTVOSRDY) :\
435 ((__FLAG__) == PWR_FLAG_VOSRDY) ? ((PWR->D3CR & PWR_D3CR_VOSRDY) == PWR_D3CR_VOSRDY) :\
436 ((__FLAG__) == PWR_FLAG_SCUEN) ? ((PWR->CR3 & PWR_CR3_SCUEN) == PWR_CR3_SCUEN) :\
437 ((__FLAG__) == PWR_FLAG_BRR) ? ((PWR->CR2 & PWR_CR2_BRRDY) == PWR_CR2_BRRDY) :\
438 ((__FLAG__) == PWR_FLAG_SB) ? ((PWR->CPUCR & PWR_CPUCR_SBF) == PWR_CPUCR_SBF) :\
439 ((__FLAG__) == PWR_FLAG_STOP) ? ((PWR->CPUCR & PWR_CPUCR_STOPF) == PWR_CPUCR_STOPF) :\
440 ((__FLAG__) == PWR_FLAG_SB_D1) ? ((PWR->CPUCR & PWR_CPUCR_SBF_D1) == PWR_CPUCR_SBF_D1) :\
441 ((__FLAG__) == PWR_FLAG_SB_D2) ? ((PWR->CPUCR & PWR_CPUCR_SBF_D2) == PWR_CPUCR_SBF_D2) :\
442 ((__FLAG__) == PWR_FLAG_USB33RDY) ? ((PWR->CR3 & PWR_CR3_USB33RDY) == PWR_CR3_USB33RDY) :\
443 ((__FLAG__) == PWR_FLAG_TEMPH) ? ((PWR->CR2 & PWR_CR2_TEMPH) == PWR_CR2_TEMPH) :\
444 ((__FLAG__) == PWR_FLAG_TEMPL) ? ((PWR->CR2 & PWR_CR2_TEMPL) == PWR_CR2_TEMPL) :\
445 ((__FLAG__) == PWR_FLAG_VBATH) ? ((PWR->CR2 & PWR_CR2_VBATH) == PWR_CR2_VBATH) :\
446 ((PWR->CR2 & PWR_CR2_VBATL) == PWR_CR2_VBATL))
450#define __HAL_PWR_GET_FLAG(__FLAG__) \
451(((__FLAG__) == PWR_FLAG_PVDO) ? ((PWR->CSR1 & PWR_CSR1_PVDO) == PWR_CSR1_PVDO) :\
452 ((__FLAG__) == PWR_FLAG_AVDO) ? ((PWR->CSR1 & PWR_CSR1_AVDO) == PWR_CSR1_AVDO) :\
453 ((__FLAG__) == PWR_FLAG_ACTVOSRDY) ? ((PWR->CSR1 & PWR_CSR1_ACTVOSRDY) == PWR_CSR1_ACTVOSRDY) :\
454 ((__FLAG__) == PWR_FLAG_BRR) ? ((PWR->CR2 & PWR_CR2_BRRDY) == PWR_CR2_BRRDY) :\
455 ((__FLAG__) == PWR_FLAG_VOSRDY) ? ((PWR->SRDCR & PWR_SRDCR_VOSRDY) == PWR_SRDCR_VOSRDY) :\
456 ((__FLAG__) == PWR_FLAG_STOP) ? ((PWR->CPUCR & PWR_CPUCR_STOPF) == PWR_CPUCR_STOPF) :\
457 ((__FLAG__) == PWR_FLAG_SB) ? ((PWR->CPUCR & PWR_CPUCR_SBF) == PWR_CPUCR_SBF) :\
458 ((__FLAG__) == PWR_FLAG_MMCVDO) ? ((PWR->CSR1 & PWR_CSR1_MMCVDO) == PWR_CSR1_MMCVDO) :\
459 ((__FLAG__) == PWR_FLAG_SMPSEXTRDY) ? ((PWR->CR3 & PWR_CR3_SMPSEXTRDY) == PWR_CR3_SMPSEXTRDY) :\
460 ((__FLAG__) == PWR_FLAG_USB33RDY) ? ((PWR->CR3 & PWR_CR3_USB33RDY) == PWR_CR3_USB33RDY) :\
461 ((__FLAG__) == PWR_FLAG_TEMPH) ? ((PWR->CR2 & PWR_CR2_TEMPH) == PWR_CR2_TEMPH) :\
462 ((__FLAG__) == PWR_FLAG_TEMPL) ? ((PWR->CR2 & PWR_CR2_TEMPL) == PWR_CR2_TEMPL) :\
463 ((__FLAG__) == PWR_FLAG_VBATH) ? ((PWR->CR2 & PWR_CR2_VBATH) == PWR_CR2_VBATH) :\
464 ((PWR->CR2 & PWR_CR2_VBATL) == PWR_CR2_VBATL))
466#define __HAL_PWR_GET_FLAG(__FLAG__) \
467(((__FLAG__) == PWR_FLAG_PVDO) ? ((PWR->CSR1 & PWR_CSR1_PVDO) == PWR_CSR1_PVDO) :\
468 ((__FLAG__) == PWR_FLAG_AVDO) ? ((PWR->CSR1 & PWR_CSR1_AVDO) == PWR_CSR1_AVDO) :\
469 ((__FLAG__) == PWR_FLAG_ACTVOSRDY) ? ((PWR->CSR1 & PWR_CSR1_ACTVOSRDY) == PWR_CSR1_ACTVOSRDY) :\
470 ((__FLAG__) == PWR_FLAG_BRR) ? ((PWR->CR2 & PWR_CR2_BRRDY) == PWR_CR2_BRRDY) :\
471 ((__FLAG__) == PWR_FLAG_VOSRDY) ? ((PWR->SRDCR & PWR_SRDCR_VOSRDY) == PWR_SRDCR_VOSRDY) :\
472 ((__FLAG__) == PWR_FLAG_SCUEN) ? ((PWR->CR3 & PWR_CR3_SCUEN) == PWR_CR3_SCUEN) :\
473 ((__FLAG__) == PWR_FLAG_STOP) ? ((PWR->CPUCR & PWR_CPUCR_STOPF) == PWR_CPUCR_STOPF) :\
474 ((__FLAG__) == PWR_FLAG_SB) ? ((PWR->CPUCR & PWR_CPUCR_SBF) == PWR_CPUCR_SBF) :\
475 ((__FLAG__) == PWR_FLAG_MMCVDO) ? ((PWR->CSR1 & PWR_CSR1_MMCVDO) == PWR_CSR1_MMCVDO) :\
476 ((__FLAG__) == PWR_FLAG_USB33RDY) ? ((PWR->CR3 & PWR_CR3_USB33RDY) == PWR_CR3_USB33RDY) :\
477 ((__FLAG__) == PWR_FLAG_TEMPH) ? ((PWR->CR2 & PWR_CR2_TEMPH) == PWR_CR2_TEMPH) :\
478 ((__FLAG__) == PWR_FLAG_TEMPL) ? ((PWR->CR2 & PWR_CR2_TEMPL) == PWR_CR2_TEMPL) :\
479 ((__FLAG__) == PWR_FLAG_VBATH) ? ((PWR->CR2 & PWR_CR2_VBATH) == PWR_CR2_VBATH) :\
480 ((PWR->CR2 & PWR_CR2_VBATL) == PWR_CR2_VBATL))
498#define __HAL_PWR_GET_WAKEUPFLAG(__FLAG__) ((PWR->WKUPFR & (__FLAG__)) ? 0 : 1)
500#if defined (DUAL_CORE)
511#define __HAL_PWR_CLEAR_FLAG(__FLAG__) \
513 SET_BIT(PWR->CPUCR, PWR_CPUCR_CSSF); \
514 SET_BIT(PWR->CPU2CR, PWR_CPU2CR_CSSF); \
527#define __HAL_PWR_CLEAR_FLAG(__FLAG__) SET_BIT(PWR->CPUCR, PWR_CPUCR_CSSF)
543#define __HAL_PWR_CLEAR_WAKEUPFLAG(__FLAG__) SET_BIT(PWR->WKUPCR, (__FLAG__))
549#define __HAL_PWR_PVD_EXTI_ENABLE_IT() SET_BIT(EXTI->IMR1, PWR_EXTI_LINE_PVD)
551#if defined (DUAL_CORE)
556#define __HAL_PWR_PVD_EXTID2_ENABLE_IT() SET_BIT(EXTI_D2->IMR1, PWR_EXTI_LINE_PVD)
563#define __HAL_PWR_PVD_EXTI_DISABLE_IT() CLEAR_BIT(EXTI->IMR1, PWR_EXTI_LINE_PVD)
565#if defined (DUAL_CORE)
570#define __HAL_PWR_PVD_EXTID2_DISABLE_IT() CLEAR_BIT(EXTI_D2->IMR1, PWR_EXTI_LINE_PVD)
577#define __HAL_PWR_PVD_EXTI_ENABLE_EVENT() SET_BIT(EXTI->EMR1, PWR_EXTI_LINE_PVD)
579#if defined (DUAL_CORE)
584#define __HAL_PWR_PVD_EXTID2_ENABLE_EVENT() SET_BIT(EXTI_D2->EMR1, PWR_EXTI_LINE_PVD)
591#define __HAL_PWR_PVD_EXTI_DISABLE_EVENT() CLEAR_BIT(EXTI->EMR1, PWR_EXTI_LINE_PVD)
593#if defined (DUAL_CORE)
598#define __HAL_PWR_PVD_EXTID2_DISABLE_EVENT() CLEAR_BIT(EXTI_D2->EMR1, PWR_EXTI_LINE_PVD)
605#define __HAL_PWR_PVD_EXTI_ENABLE_RISING_EDGE() SET_BIT(EXTI->RTSR1, PWR_EXTI_LINE_PVD)
611#define __HAL_PWR_PVD_EXTI_DISABLE_RISING_EDGE() CLEAR_BIT(EXTI->RTSR1, PWR_EXTI_LINE_PVD)
617#define __HAL_PWR_PVD_EXTI_ENABLE_FALLING_EDGE() SET_BIT(EXTI->FTSR1, PWR_EXTI_LINE_PVD)
623#define __HAL_PWR_PVD_EXTI_DISABLE_FALLING_EDGE() CLEAR_BIT(EXTI->FTSR1, PWR_EXTI_LINE_PVD)
629#define __HAL_PWR_PVD_EXTI_ENABLE_RISING_FALLING_EDGE() \
631 __HAL_PWR_PVD_EXTI_ENABLE_RISING_EDGE(); \
632 __HAL_PWR_PVD_EXTI_ENABLE_FALLING_EDGE(); \
639#define __HAL_PWR_PVD_EXTI_DISABLE_RISING_FALLING_EDGE() \
641 __HAL_PWR_PVD_EXTI_DISABLE_RISING_EDGE(); \
642 __HAL_PWR_PVD_EXTI_DISABLE_FALLING_EDGE(); \
649#define __HAL_PWR_PVD_EXTI_GET_FLAG() ((READ_BIT(EXTI->PR1, PWR_EXTI_LINE_PVD) == PWR_EXTI_LINE_PVD) ? 1UL : 0UL)
651#if defined (DUAL_CORE)
656#define __HAL_PWR_PVD_EXTID2_GET_FLAG() ((READ_BIT(EXTI_D2->PR1, PWR_EXTI_LINE_PVD) == PWR_EXTI_LINE_PVD) ? 1UL : 0UL)
663#define __HAL_PWR_PVD_EXTI_CLEAR_FLAG() SET_BIT(EXTI->PR1, PWR_EXTI_LINE_PVD)
665#if defined (DUAL_CORE)
670#define __HAL_PWR_PVD_EXTID2_CLEAR_FLAG() SET_BIT(EXTI_D2->PR1, PWR_EXTI_LINE_PVD)
677#define __HAL_PWR_PVD_EXTI_GENERATE_SWIT() SET_BIT(EXTI->SWIER1, PWR_EXTI_LINE_PVD)
694void HAL_PWR_DeInit (
void);
695void HAL_PWR_EnableBkUpAccess (
void);
696void HAL_PWR_DisableBkUpAccess (
void);
707void HAL_PWR_EnablePVD (
void);
708void HAL_PWR_DisablePVD (
void);
711void HAL_PWR_EnableWakeUpPin (uint32_t WakeUpPinPolarity);
712void HAL_PWR_DisableWakeUpPin (uint32_t WakeUpPinx);
715void HAL_PWR_EnterSTOPMode (uint32_t Regulator, uint8_t STOPEntry);
716void HAL_PWR_EnterSLEEPMode (uint32_t Regulator, uint8_t SLEEPEntry);
717void HAL_PWR_EnterSTANDBYMode (
void);
720void HAL_PWR_PVD_IRQHandler (
void);
721void HAL_PWR_PVDCallback (
void);
724void HAL_PWR_EnableSleepOnExit (
void);
725void HAL_PWR_DisableSleepOnExit (
void);
726void HAL_PWR_EnableSEVOnPend (
void);
727void HAL_PWR_DisableSEVOnPend (
void);
748#define PWR_EXTI_LINE_PVD EXTI_IMR1_IM16
768#define IS_PWR_PVD_LEVEL(LEVEL) (((LEVEL) == PWR_PVDLEVEL_0) ||\
769 ((LEVEL) == PWR_PVDLEVEL_1) ||\
770 ((LEVEL) == PWR_PVDLEVEL_2) ||\
771 ((LEVEL) == PWR_PVDLEVEL_3) ||\
772 ((LEVEL) == PWR_PVDLEVEL_4) ||\
773 ((LEVEL) == PWR_PVDLEVEL_5) ||\
774 ((LEVEL) == PWR_PVDLEVEL_6) ||\
775 ((LEVEL) == PWR_PVDLEVEL_7))
778#define IS_PWR_PVD_MODE(MODE) (((MODE) == PWR_PVD_MODE_IT_RISING) ||\
779 ((MODE) == PWR_PVD_MODE_IT_FALLING) ||\
780 ((MODE) == PWR_PVD_MODE_IT_RISING_FALLING) ||\
781 ((MODE) == PWR_PVD_MODE_EVENT_RISING) ||\
782 ((MODE) == PWR_PVD_MODE_EVENT_FALLING) ||\
783 ((MODE) == PWR_PVD_MODE_EVENT_RISING_FALLING) ||\
784 ((MODE) == PWR_PVD_MODE_NORMAL))
787#define IS_PWR_REGULATOR(REGULATOR) (((REGULATOR) == PWR_MAINREGULATOR_ON) ||\
788 ((REGULATOR) == PWR_LOWPOWERREGULATOR_ON))
791#define IS_PWR_SLEEP_ENTRY(ENTRY) (((ENTRY) == PWR_SLEEPENTRY_WFI) ||\
792 ((ENTRY) == PWR_SLEEPENTRY_WFE))
795#define IS_PWR_STOP_ENTRY(ENTRY) (((ENTRY) == PWR_STOPENTRY_WFI) ||\
796 ((ENTRY) == PWR_STOPENTRY_WFE))
799#define IS_PWR_REGULATOR_VOLTAGE(VOLTAGE) (((VOLTAGE) == PWR_REGULATOR_VOLTAGE_SCALE0) || \
800 ((VOLTAGE) == PWR_REGULATOR_VOLTAGE_SCALE1) || \
801 ((VOLTAGE) == PWR_REGULATOR_VOLTAGE_SCALE2) || \
802 ((VOLTAGE) == PWR_REGULATOR_VOLTAGE_SCALE3))
This file contains HAL common defines, enumeration, macros and structures definitions.
Header file of PWR HAL Extension module.
PWR PVD configuration structure definition.
Definition: stm32h7xx_hal_pwr.h:49
uint32_t PVDLevel
Definition: stm32h7xx_hal_pwr.h:50
uint32_t Mode
Definition: stm32h7xx_hal_pwr.h:55
